05-07-2012, 12:05 PM | #1 |
Newbie Join Date: Feb 2012 Location: garrison
| FF-4 Driveshaft
For those who have built up a FF-4 what are you using for a front driveshaft? Thanks Chris |
05-07-2012, 12:18 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: FF-4 Driveshaft
I used Traxxas half shafts, and stampede universals, with axial drive shaft rings. MIP's will also work. The standard AX10 ones. Look up DickyT's fastback. Fastback and FF-4 are the same basic chassis, just one has a body, one doesn't. |
05-07-2012, 12:37 PM | #3 |
| Re: FF-4 Driveshaft
I cut down and re-welded a Junfac shaft. I kept popping Pede driveshaft ears even with Axial drive shaft rings and a 90t spur.
05-07-2012, 09:41 PM | #4 |
| Re: FF-4 Driveshaft
Where did you get an FF-4?!? I don't even have one |
05-07-2012, 09:49 PM | #5 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
| Re: FF-4 Driveshaft LOL I've got one too that I am building right now. I talked to Manning and he said the front is tight but is a straight drop in for a stampede shaft and the rear is two females and a section of male super glued into one of the females. I might try this but I do happen to have some MIP's laying around I'll see if that works too.
05-07-2012, 10:10 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| Re: FF-4 Driveshaft
for my fastback i used the mip driveshaft kit for an ax10 WITH DIG. use the short dig shaft in front, used the longer shaft for the rear. i also used an mip wraith driveshaft end that is longer to help with the length of the rear.
05-08-2012, 05:15 AM | #7 | |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
| Re: FF-4 Driveshaft Quote:
Did this same thing and i also have done this on my 2 FF-4 builds i did for some buddies. I know a guy with about 3 diff ones if you really want one :P | |
05-08-2012, 06:08 AM | #8 |
| Re: FF-4 Driveshaft |
05-08-2012, 06:46 AM | #9 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
05-08-2012, 07:29 AM | #10 | |
You will get it back when......... chirp... chirp..... shhhhhh I think with him having the cad file and a mill in his basement, if it was that big of deal he would make himself one Last edited by DickyT; 05-08-2012 at 07:32 AM. | |
05-08-2012, 11:29 AM | #11 |
| Re: FF-4 Driveshaft
Speaking of the ff-4 will the FBII front shock mount fit that i havent gotten to try it yet but i figure someone has ?
05-08-2012, 11:59 AM | #12 | |
I don't believe so, plus it would put the front shocks in a weird place. you would need to drop to a 3.5"-3.75" eye to eye shock to try and make it work. | |
05-08-2012, 12:24 PM | #13 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
| Re: FF-4 Driveshaft MIP CVD™ C-Drive Spline Kit for Dig (Rear) #09137*-*Miscellaneous*-*-Geartrain - Axles - Driveline*-*The Crawlers Store LLC this will work and is bullet proof. |
05-08-2012, 01:53 PM | #14 | |
I got so caught up in the after original post talk I missed the original question.. That is exactly what I used on both my FF-4 and Fastback | |
05-08-2012, 04:31 PM | #15 |
05-08-2012, 06:16 PM | #16 |
| Re: FF-4 Driveshaft
ordered up a set of MIP's for a Traxxas Slash that should work. the guys at MIP are great. Very helpfull when you call them. Still might have to cut down the male end but should be right there, Thanks all for the help. Just finished up the XR conversaion. I will get some pics up soon. Chris |
FF-4 Driveshaft - Similar Threads | ||||
driveshaft | GearLoDriveSlo | Team Losi Comp Crawler | 2 | 11-02-2009 09:48 PM |
Which driveshaft? | Vicious-peanut | HPI Wheely King | 3 | 08-02-2008 08:55 PM |
driveshaft | MAX climber | Newbie General | 9 | 05-10-2007 05:15 PM |
driveshaft ? | yamaharider308a | General Crawlers | 6 | 02-21-2007 07:30 PM |
Help with driveshaft.. | rc4lyfe | Tamiya TLT Crawlers | 22 | 08-02-2006 10:34 AM |
