05-16-2012, 01:14 PM | #1 |
Newbie Join Date: Aug 2011 Location: Israel
| double drag link steering
hi i've got an AX10 RTR. the one with all plastic - i am a newbie. i am having lots of fun with it! lately i'm getting disturbed by its clumsy steering, i've already got rid of that servo saver and using a normal servo horn (still plastic). what i'e noticed now is that the plastic tie-rod is very flexi and sometimes it makes my wheel face each other like so: / --- \ so i've started looking at some rigid steering setup and noticed that everybody is using the drag-link + tie-rod combination... got me wandering... why? why not use two drag-links and eliminate the tie-rod? get some round servo horn and attach 2 drag-link to both wheels! this will eliminate the "middle man" = the tie-rod. am i missing something? why not? |
05-16-2012, 01:19 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
| Re: double drag link steering
Your not missing anything. I have aluminum steering links. Short one goes from servo to steering knuckle. Long one connects both knuckles together
05-16-2012, 01:40 PM | #3 | |
| Re: double drag link steering Quote:
And to anser the OP, no real reason not to run it like you mention, but unless the servo hron is centered in the axle, the wheels will not turn in equal amounts and the side with the shorter drag link will move less than the side with the longer drag link. | |
05-16-2012, 01:52 PM | #4 |
I ran a setup like that for awhile, but didn't care for it much. Using a tie-rod keeps both wheels turning the same no matter what. When you have a drag link going to each knuckle, the amount each tire turns changes as the horn rotates because it moves in an arc. It's hard to explain, but if you try it, you'll see what I'm saying. |
05-16-2012, 02:34 PM | #5 |
Quarry Creeper Join Date: Feb 2012 Location: Adams, MA and Florida, MA
One of the people who runs a bully (can't remember his name) ran a setup like that and it worked out ok. If you scroll through the bully steering thread, you'll see it.
05-22-2012, 11:54 PM | #6 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
05-23-2012, 02:02 PM | #7 |
| Re: double drag link steering That's assuming that you can mount the tie rods to the servo horn in the exact same spot....which you cant physically do.
05-23-2012, 04:21 PM | #8 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
It's possible, it would just look goofy and be harder to Fab than a tierod setup...
05-23-2012, 04:33 PM | #9 | |
See here: another ax10 build, it's a 2.2 esse | |
05-23-2012, 04:38 PM | #10 |
| Re: double drag link steering |
05-23-2012, 06:13 PM | #11 |
05-23-2012, 06:34 PM | #12 |
I didn't say it couldn't be done, just that I didn't like it. I think there is a reason tie-rods are pretty much the standard over dual drag-links.
05-23-2012, 08:40 PM | #13 |
05-23-2012, 10:01 PM | #14 |
| Re: double drag link steering I think the issue is the way the servo horn rotates (on a normal comp rig). It doesn't matter what knuckles are used, the servo horn moves each knuckle a different distance as it travels through it's arc. I have no doubt that a dual drag-link can work, but I don't believe it can ever duplicate the benefit of having both wheels locked together with a tie-rod. I've tried it, Jeremy says he has tried it, and I'm sure there are many others who can say the same. That's why I said there is a reason that almost everyone runs a tie-rod. Out of curiosity, do you run a tie-rod or dual drag-links? |
05-23-2012, 10:34 PM | #15 | |
05-24-2012, 12:02 AM | #16 |
So you had better performance with dual drag-links?
05-24-2012, 12:44 AM | #17 |
I had less reverse ackerman at lock while having less toe out at rest. This is with near true ackerman knuckles. Having the 'right' amount of reverse ackerman to fit my caster and shock placement gave me more turning.
05-24-2012, 09:33 AM | #18 |
05-24-2012, 09:34 AM | #19 |
05-24-2012, 09:43 AM | #20 |
I'd be willing to try it again if I had the time, but from what I remember it wasn't for me. I'd be curious to see what would happen if the horn rotated with the knuckles instead of on a different plane. Right now though I have too many other projects on my plate. |
double drag link steering - Similar Threads | ||||
Steering link and drag link - what's the best bang for the buck? | Matthewboerner | Axial Wraith | 29 | 10-25-2011 10:25 AM |
Double drag link no tie rod? | day215 | General Crawlers | 10 | 07-02-2011 09:11 PM |
Longer Steering Drag Link vs. Shorter Drag Link? | mann0mann | Newbie General | 7 | 05-08-2008 04:14 PM |
