05-24-2012, 01:47 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Kingsport
| Driveshaft issues on AX10 with VP Dig setup
I've been having issues with the driveshafts coming off the outdrive of the VP dig unit. I have changed the front to the pinned outdrives and they work great. Does anybody have suggestions for fixing the rear? I have double grub screws already in place and used lock tight but it still comes off after about an hour of running. |
05-24-2012, 02:01 PM | #2 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Driveshaft issues on AX10 with VP Dig setup
you can drill a lil relief hole in the output shaft so the screws will bite a lil better. are you letting the loctite dry for 24hrs before using it? |
05-24-2012, 02:04 PM | #3 |
Rock Crawler Join Date: Sep 2011 Location: truckee
this works if you are using loctite by the directions it shouldnt come loose imo. |
Driveshaft issues on AX10 with VP Dig setup - Similar Threads | ||||
MIP Driveshaft VF Dig Issues | dr.chop | Axial AX-10 Scorpion | 4 | 07-07-2008 08:05 AM |
