![]() | #21 |
Rock Stacker Join Date: Sep 2008 Location: Williamsport
Looking at the prices of stuff, if you decided to go with the stock XR10 plastic, you are almost better off buying a whole XR10 kit and hoping you can part the rest of it out and make some money back. It crossed my mind after I placed my order for my parts!
![]() | #22 |
Try to Bend it ![]() Join Date: Aug 2009 Location: Perth Australia
Great post. But my preference is wraith knuckles. |
![]() | #23 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
I used the STRC wraith hubs and knuckles. They work well.
![]() | #24 |
Newbie Join Date: May 2009 Location: NOR*CAL
The longer beef tubes still availible?
![]() | #25 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
![]() | #26 |
I did the narrow XR-10 mod awhile back, and loved the steering. After driving my Ridgecrest for awhile, I was looking to decrease some scrub radius and I'm now doing a second front axle with the wide Beef Tubes and Vanquish Wraith knuckles and C's. I plan to decrease the backspace on my SLW's with shorter hubs. Question for those who have done this same setup...is your C's loose on the ends of the Beef Tubes? Is this because the Tubes were originally meant for AX-10 C's instead of XR-10? I may have to save these tubes for use with my 8* Vanquish C's and make something else for this mod. I don't like all the slop. |
![]() | #27 | |
Rock Crawler ![]() Join Date: Jul 2010 Location: St. Albans
| ![]() Quote:
![]() | #28 |
Quarry Creeper ![]() Join Date: Jul 2007 Location: WA
I just installed my long tubes as well and found the stock plastic xr chubs fight really tight but the aluminum versions are sloppy as we all know. So to remedy this I found a brass tube from the hobby shop that fit the inside of the aluminum xr chub. Inside diameter of the brass was too small but some work with a drum sander on the dremel made short work. Notched out the brass tube for the caster adjustments and its a nice tight fit now. The tube was 17/32" OD and I believe it says .030" on the thickness from k&s. Happy with the results for sure. I should mention that I bought the st racing chubs and not sure if they fit the inside of the other brand chubs. Had a buddy try it and didn't fit the hr chubs as well as the st racing ones.
![]() | #29 | |
| ![]() Quote:
![]() | #30 |
I decided to machine new tubes out of aluminum, and make the OD a slip fit for the VP C's.
![]() | #31 |
Nice! I hope to have that capability soon.
![]() | #32 |
Newbie Join Date: Aug 2012 Location: Chino Valley
Hey guys, where does the "xr10 axle on ax10" start? I want to get to the starting point and build. Please help? Thanks! |
![]() | #33 |
Could you point me to abuild on the axle end swapping? Thanks! |
![]() | #34 |
Its a HARDKNOCKZ Life... ![]() Join Date: Feb 2011 Location: Southern Kali...
![]() | #35 |
| ![]() The first thing you need is a set of ax10 axles or if you are building from scratch like I did you will need axle housings. Then you need to decide on what gears you want, beef tubes (some do this mod without them), axle shafts, etc. I didn't actually put the axle pictures on my thread for some reason but I'll put them on here or on my build thread when I get back home.
![]() | #36 |
![]() | #37 |
Thanks this list has been helpful... thanks!!
![]() | #38 |
yeah.. double...TRIPLE thanks ![]() |
![]() | #39 |
No problem ![]() |
![]() | #40 |
Pebble Pounder ![]() Join Date: Jan 2011 Location: Red Hill, Pa
Okay i ordered 2 sets of the longer Beef tubes last week, one for my shafty and one for my C3. I am very used to AX10 axles but new to XR10 parts, and have a few questions. First, I'm wondering if the width of the new upgraded axles is the same as stock XR10's, so that I can use a VP tierod - Axial XR-10 bent titanium tie rod Second question(s) is about the fittment of the c hubs. From what I read the stock plastic hubs are the only ones that fit the steel beeftubes snugly, but who wants to use cheepo plastics after doing a pricey upgrade like this? So do any of the aluminum hubs fit "well" without shimming (the brass 17/32" x .030 tube fix) ? Why dont the vendors machine them a hair wider to solve this? |
newbie need help parts list for overdrive mod on mrc pro | hammer29 | Losi Mini-Rock Crawler | 22 | 06-21-2015 02:20 PM |
Axial parts list for scratch XR10 build? | jubilee | Axial XR10 | 7 | 04-11-2012 08:42 PM |
X-Factor axles - PARTS LIST!!! | cman_1500w | XTM Crawler | 15 | 10-24-2004 11:44 PM |
