06-25-2012, 06:36 AM | #41 |
Newbie Join Date: Apr 2012 Location: China
| Re: My shafty build
Are those homemade wheel weights? I made some from brass, it is heavier than both steel and stainless steel, and then it is easier to machine too and will not rust. Cant wait to see what this crawler will do.
06-25-2012, 06:47 AM | #42 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: My shafty build
video is done... just have to upload..should be up by tonite.. 6+hrs of building compressed into 4 mins.. |
06-25-2012, 06:54 AM | #43 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
| Re: My shafty build Got the washers from WooPigSooie. I thought the rust added flavor. Really he was helping me out with some tires and wheels. I'll save up and a nice set of wheels down the road but, this will get me going for now.
06-25-2012, 08:26 AM | #44 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: My shafty build |
06-25-2012, 08:46 AM | #45 |
| Re: My shafty build By feel it seems that way. I've not ran it on the rocks yet to find out, plus I don't know what the hell I'm doing yet. |
06-25-2012, 09:13 AM | #46 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
| Re: My shafty build Mainly, what it does is allow you to keep the cross braces stationary, but move the shock mounts around. This is essential for somebody using a Gunner style body mount.
06-25-2012, 09:44 AM | #47 |
| Re: My shafty build
Glad it to see it put together Mike! Looks great. On the rear upper links. It looks like they are a little long right now. The rear axle pinion angle is kicked up too much. The truck can do funky things with it like that. I know it's probably kicked up for clearance but making it flatter will help with the overall drivetrain system. Might see if you can shorten the the rear uppers a little. Also, with the rod ends turned sideways, that might cause some binding when the truck tries to suck down. The rod end will be limited by the rod end ball. Looks like they are close to their down travel limit right now. Shortening the rear uppers should help with this and the pinion angle. But that's just me looking at the pictures. |
06-25-2012, 10:07 AM | #48 | |
| Re: My shafty build Quote:
06-25-2012, 10:10 AM | #49 | |
ah that makes sense. | |
06-25-2012, 10:17 AM | #50 | |
... Last edited by Szczerba; 06-25-2012 at 10:20 AM. | |
06-25-2012, 10:17 AM | #51 | |
06-25-2012, 10:23 AM | #52 | |
06-25-2012, 10:26 AM | #53 |
| Re: My shafty build
What is your WB at? If it is slightly too short, then you might have those spacers at the rear axle link mount in the wrong spot. It might need to go: shock (inside of outer mount), spacer, link (inside of inner mount). That would slightly shorten your WB and rotate the pinion down some. I looked, but I cant find any other builds with a closeup of the way the spacer sits....so I could be wrong. |
06-25-2012, 10:30 AM | #54 | |
06-25-2012, 10:31 AM | #55 |
| Re: My shafty build
I edited my post....read it again. I was typing faster than my brain was thinking... |
06-25-2012, 10:31 AM | #56 |
| Re: My shafty build
I do know RTR weight was 4lb 7oz.
06-25-2012, 10:33 AM | #57 |
| Re: My shafty build
we had to run the shocks on the outside because they were rubbing on the links.. michael,i think once you trim those uppers a few mm it should all be good to go. his wheelbase is at 12 1/4in when we were done building i checked.. |
06-25-2012, 10:34 AM | #58 |
| Re: My shafty build Before you trim those links, I would try moving them to the inside of the mount and maybe just use a longer spacer to span the entire width between to the pieces of plastic that make up the amount. I bet that'd put your WB at a full 12.5" and flatten out that pinion angle nicely.
06-25-2012, 10:34 AM | #59 |
06-25-2012, 10:44 AM | #60 |
| Re: My shafty build It was the best place for mounting the shocks for clearance. As for the post spanning across the chassis, I think you would want them even if you didn't use the Gunner style body mounts. It definitely stiffens the chassis up. Before installing the outer post you could easily squeeze the ends of the chassis quite a bit. Not a knock on the chassis but it's a good distance out there to the outer ends and you really couldn't expect not to have some flex without the cross post installed.
My shafty build - Similar Threads | ||||
Try to keep the shafty alive build. | Frikenwoodro | Team Losi Comp Crawler | 39 | 08-07-2012 11:29 AM |
MOA vs Shafty. which build for comps | soutthpaw | Newbie General | 19 | 11-08-2011 12:43 PM |
Vp Incision Shafty Build...3...2...1 | Sneed | Team Losi Comp Crawler | 44 | 07-21-2011 07:02 PM |
Vanquish Shafty Build | Lookin4rock | Axial AX-10 Scorpion | 16 | 02-09-2010 11:54 PM |
Shafty or MOA Losi build? | Mikeney | Team Losi Comp Crawler | 8 | 12-26-2009 08:12 PM |
