Thread: My shafty build
Old 06-25-2012, 09:28 PM   #81
Default Re: My shafty build
Originally Posted by ROLANDROCKSHOP View Post
Wow! It seemed like it took much longer than that.
mmatthews is offline   Reply With Quote
Old 07-06-2012, 10:31 PM   #82
Great thread bro! Apparently I've been too busy since I haven't posted here. We need to get this thing worked out ASAP!!!
WooPigSooie is offline   Reply With Quote
Old 07-07-2012, 07:18 AM   #83
I need to get some measurements and put up here as requested. It's been so damn hot I've not done much. My Dremel died and I stopped where I was at. Need to save some cash to change some things up. There will be updates coming...
Old 07-09-2012, 06:43 PM   #84
Need some ideas on mounting weight on the front axle...
Old 07-09-2012, 08:04 PM   #85
Knuckle weights
Hittman is offline   Reply With Quote
Old 07-10-2012, 08:08 AM   #86
sweet build man does that chassis work good?
tn crawlin is offline   Reply With Quote
Old 07-10-2012, 08:12 AM   #87
So far my first test showed I need some weight and needed to adjust the rear pinion angle. I've not got the weight yet, so no new test info.
Old 07-10-2012, 04:19 PM   #88
I ordered some Bluemonkey knuckle weights with extra weights today. Working on sanding sidewalls and I've already trimmed up the tread blocks. I've got to fix the corded dremel, it's taking forever sanding these damn things...
Old 07-10-2012, 06:19 PM   #89
Look at this thread.....
http://www.crawlanz.com/viewtopic.php?f=20&t=2866
It is faster to use grinder with flap disc or sanding disc. Use the dremel to do the finer details. It is a messy job.
Colgout is offline   Reply With Quote
Old 07-10-2012, 07:24 PM   #90
Crawl ANZ - View topic - I am Shaven!!!
Too late. just finished with the dremel.
Old 07-10-2012, 07:53 PM   #91
Sanded sidewalls
Cut tread
Shortened upper rear link
Changed upper rear link mount
Waiting on knuckle weights
Need some big bore shocks
it's getting there...
Old 07-10-2012, 08:29 PM   #92
nice. thanks for that measurement.
looking good. i cant wait tell mines up and running.
ninja turtle is offline   Reply With Quote
Old 07-11-2012, 06:11 AM   #93
that pinion angle looks much better!
ROLANDROCKSHOP is offline   Reply With Quote
Old 07-11-2012, 06:39 AM   #94
Pic makes your width look like its about 11 1/2. I would try to slim that closer to 11, because it will give you a little more room for squeezing between cones.
Tgreer is offline   Reply With Quote
Old 07-11-2012, 06:44 AM   #95
The wheelbase looks a little short, you want as close to 12.5 (without going over) fully compressed. Otherwise its looking good
billj is offline   Reply With Quote
Old 07-12-2012, 09:09 PM   #96
Looking good buddy!!!
Old 07-14-2012, 12:19 AM   #97
nice crawler
123nanez is offline   Reply With Quote
Old 07-16-2012, 05:44 PM   #98
Knuckle weights on. Ready for another try at this crawling shit. ordered wrong knuckles but nothing a little Dremel couldn't fix.
Old 08-15-2012, 02:14 AM   #99
And then.....
Old 08-15-2012, 04:59 AM   #100
Originally Posted by WooPigSooie View Post
And then.....
And then global warming struck and I'm too much of a ***** to play in the heat. It's only had one time on the rocks... I suck.
My shafty build - Similar Threads
Try to keep the shafty alive build. Frikenwoodro Team Losi Comp Crawler 39 08-07-2012 11:29 AM
MOA vs Shafty. which build for comps soutthpaw Newbie General 19 11-08-2011 12:43 PM
Vp Incision Shafty Build...3...2...1 Sneed Team Losi Comp Crawler 44 07-21-2011 07:02 PM
Vanquish Shafty Build Lookin4rock Axial AX-10 Scorpion 16 02-09-2010 11:54 PM
Shafty or MOA Losi build? Mikeney Team Losi Comp Crawler 8 12-26-2009 08:12 PM
