03-17-2013, 07:34 PM | #41 | |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: ===The NEW CreationFab PREMIUM Delrin Tubes!!!=== Quote:
Just try to elaborate on this one, if you are using Vp locker, it is better to use 2 long side XR shaft, shave the flange and make a longer flats, this way you can have positive engagement of the set screw. if you use 2 short side, the flat is only half engaged by the set screw. | |
09-17-2013, 11:38 AM | #42 |
im in need of a set of narrowed wraith axles and thought about using these. anyone know if the splines on these fit wraith C's? and is the tube OD the right size to fit inside wraith cases? (length not an issue) |
09-17-2013, 11:53 AM | #43 | |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
I would just shorten the long tube in the middle, use a piece of carbon tube or brass tube as an insert. Glue it together with some CA, and use a couple set screws for insurance. TOM | |
09-17-2013, 07:37 PM | #44 | |
09-20-2013, 01:30 PM | #45 |
Rock Crawler Join Date: Feb 2013 Location: york
| Look at MRCrackheads ugly betty thread and you will see a great way to achieve what you want. And its beef dude I've seen his rig take a beating
09-20-2013, 04:09 PM | #46 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Took possession of 2 sets of ax/xr axles from Chris today. These sets are sick. There is a thread in general crawlers if you care to have a look at the 2 very different directions I went with these. Thanks again Chris!
04-06-2014, 08:25 PM | #47 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Finally got around to putting my set together....... Wanted to make sure to leave feedback here with that I Love them, easy install and fitment!
06-04-2014, 08:41 AM | #48 |
Rock Stacker Join Date: Mar 2013 Location: Amsterdam
Does anybody know where I can get 2 short XR shafts ? They seem to be sold out everywhere !
06-04-2014, 09:40 PM | #49 |
I'd hit up Chris. Maybe he has some.
06-04-2014, 10:32 PM | #50 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: ===The NEW CreationFab PREMIUM Delrin Tubes!!!=== |
06-04-2014, 10:50 PM | #51 |
If I were to redo my sporty, I'd probably just keep the rear axle stock width. Both lighter, and SCX rear shafts are plentiful. Just use hubs or offset wheels to even you up.
06-05-2014, 10:39 AM | #52 |
| Re: ===The NEW CreationFab PREMIUM Delrin Tubes!!!=== My suggestion would be to go with 2 long side.. But by the time you buy 2 sets of axles, mod them, and mess with them. The best bet is CreeperBob ti rear axle shafts.. On sale right now for 65$ a set! Bolt in and go option!
06-09-2014, 08:59 AM | #53 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
And Creeper Bob shafts are lighter than the stock ones as well
04-16-2015, 12:23 PM | #54 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
hey Chris, are you still making these? didn't see the "premium" versions on your website. thanks
04-21-2015, 09:53 PM | #55 |
Pebble Pounder Join Date: Mar 2013 Location: Vancouver
I 2nd that Chris..... |
06-24-2015, 12:33 AM | #56 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Sorry for the extremely delayed response. The Premium is the new norm. There is nothing less then this version. Another small update. Here is a copy and paste from my Facebook page: This is something that I have been working towards for a while now. A better splining tool. With any luck, this will open the door to Aluminum and Brass splined tubes as well. The "Test" tool works great for Delrin, but I will need to revise it a bit for metals. In the below picture, you can see the difference in quality, The one on the right is an older version. It worked well, but they werent as nice, and the chubs tended to fit a little tight. The latest version on the left is much nicer looking, and a set of factory Axial aluminum chubs fit perfect. You can also see I took a sacrificial Berg tube, and splined it. This is a service I am hoping to offer in the near future for all those Berg builders on a budget |
===The NEW CreationFab PREMIUM Delrin Tubes!!!=== - Similar Threads | ||||
CreationFab Delrin AX10 Tubes =NEW STYLES= *NOW TAKING ORDERS* | Chris_The_Battery_Man | Axles, Trannys, T-case | 136 | 10-11-2015 10:48 PM |
CreationFab Delrin tubes! Put XR shafts AND AX10 R&P in your axle... | Chris_The_Battery_Man | Venom Creeper | 13 | 08-06-2012 12:11 PM |
CreationFab Delrin SCX10 upper spring retainers! | Chris_The_Battery_Man | Chassis and Suspension | 7 | 08-06-2012 11:13 AM |
CreationFab SCX10 Delrin upper spring retainer! | Chris_The_Battery_Man | General Crawlers | 10 | 06-26-2012 09:18 AM |
CreationFab delrin SCX10 upper spring retainer | Chris_The_Battery_Man | Axial XR10 | 15 | 06-25-2012 10:59 PM |
