08-05-2012, 08:55 AM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Gear noise
The (well greased) overdrive front gears are pretty noisy, which I assume means I have heavy mesh engagement. It gets quiet if I pull the pinion full back and I could make it stay there with a shim between the outer pinion gear and the driveshaft hub. But heavy mesh ensures no tooth skip, so which do you guys find more important -- heavy but noisy mesh, or quieter with less mesh? |
08-05-2012, 10:11 AM | #2 |
| Re: Gear noise
No tooth skip. The gears will break in and quiet down. With that said, I've never had an issue with those gears... |
08-18-2012, 06:58 PM | #3 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: Gear noise
are they new gears? if they are new they are loud until they break in, if they are old and worn then replace them... either way there will be some noise...... so just turn up the music and have another beer!!! haha |
Gear noise - Similar Threads | ||||
7955 gear noise... a little different | mudn_1 | Electronics | 1 | 02-10-2012 10:20 PM |
Wraith Gear noise | cumminsdzl | Axial Wraith | 7 | 08-12-2011 09:15 PM |
Gear noise | elitecrawler | HPI Wheely King | 8 | 06-29-2010 11:26 AM |
Metal Gear Noise | MaxxBronco | Duratrax Cliff Climber | 10 | 01-05-2010 04:45 AM |
gear noise? | 93'wrangler | Axial AX-10 Scorpion | 7 | 12-08-2008 11:36 AM |
