Thread: speed
Old 08-06-2012, 04:13 AM   #1
Default speed
Hi everyone
I have looking and reading posts here for a sometime, but this is my first post.
I’m looking to get a bit more speed out of my ax10.
At the moment I have a 35T motor 14 pinion. I like this set up for crawling, but sometimes I it would be nice to have more speed when not crawling.
Should I have a second motor, 20T with the same 14 pinion. Or keep the 35T and then gear it down ? Buying a second faster truck in not an option at the moment.
Any help would be gratefully received. Steve
kayak1 is offline   Reply With Quote
Old 08-06-2012, 05:32 AM   #2
I joined the Band!
Default Re: speed
how bout a 2 speed transmission? that is the route im going to go..
i have a 27T and it does ok.. id like a 35T but there isnt much to crawl over around here... so my solution will be a 2 speed.. best of both worlds..
RootBreaker is offline   Reply With Quote
Old 08-06-2012, 06:14 AM   #3
Default Re: speed
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho
JeremyH is offline   Reply With Quote
Old 08-06-2012, 07:13 AM   #4
Try to Bend it
Highlucks's Avatar
Default Re: speed
How about just running a larger pinion?
BTW welcome to RCC check out the local action at www.crawlanz.com
Highlucks is offline   Reply With Quote
Old 08-06-2012, 07:18 AM   #5
Default Re: speed
the cheapest option would be buying a 27 turn motor. i just took one out of my ax10 becuase i wanted to make it slower. the 27t does pretty good for crawling but you have speed when you need it
theloudone is offline   Reply With Quote
Old 08-07-2012, 03:01 AM   #6
Default Re: speed
Thanks for the replys.
I got a 20T motor today with a 17 T pinion, so we will see how it goes later in the week.
Old 08-09-2012, 04:53 AM   #7
Default Re: speed
Well i tried the 20T motor today and it was faster, but a little more speed would be better. So i going to try a 20 T pinion next week.
Old 08-09-2012, 05:00 AM   #8
I joined the Band!
Default Re: speed
original guy i got my ax10 from had a 19turn motor and 20 tooth pinion and the motor got really hot.. guessing not geared well..... but that is me... remember... faster you go the less of a crawler it is.... well from my understanding.. what if you went with 3s lipo?
speed - Similar Threads
More speed ROCKST*R Axial XR10 0 03-08-2012 10:24 AM
Overall Speed DRN Newbie General 7 04-16-2010 12:48 PM
F350 3 speed to single speed conversion, tips/ideas needed please neo 1.9 Scale Rigs 10 02-11-2010 02:49 PM
single speed setup vs. speed control traxxas junky Electronics 18 08-28-2007 11:28 PM
