09-25-2012, 09:30 PM | #101 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
10-01-2012, 08:48 AM | #102 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Re: AX10 Class 3 scaler Bronco build, cont'd
The Wraith body came a couple days ago. I started doing some cutting to see how it was going to fit. I plan to take the rubber fender flares off the old Bronco body and put them on this body. So far, I like the size of the new body; I think it is going to work out well. That being said, there are a lot of steps between now and "finished" - body trimming and paint, cage work, and interior. Trying to be patient. |
10-01-2012, 09:18 AM | #103 | |
| Re: AX10 Class 3 scaler Bronco build, cont'd Quote:
I just ran across this, and wasn't sure if you found what you are looking for yet. Since you already have the torch, you could grab this from your local Ace for under $20. I bought this once out of curiosity, and it works great. More than enough to do a full chassis' worth of trail armor, and the flux is better than Harris. Alpha FryŽ Specialty Brazing Kit (53500) - Solder - Ace Hardware | |
10-01-2012, 09:53 AM | #104 |
That's a nice price, thanks!
10-01-2012, 12:59 PM | #105 |
Rock Crawler Join Date: Oct 2011 Location: Warren
That body looks crazy even though I know that there will be a cage it is hard to see it right now. However, as with everything else I am sure that it will be top notch when you are done with it. I have seen that solder to by the way. They sell it at my local hard ware store. I didnt think that it looked like enought to do a chassis and my brazing rod that I bought was cheaper than it so I went that way. |
10-01-2012, 01:23 PM | #106 |
Thanks man, I hope you're right! Just for fun, here's a photo.....with the cage |
10-01-2012, 05:57 PM | #107 |
Very nice. I will be waiting
10-01-2012, 07:42 PM | #108 | |
Sent from my DROIDX using Tapatalk 2 | |
10-01-2012, 07:46 PM | #109 |
So could I. But, that would be no fun for josh.
10-01-2012, 08:13 PM | #110 |
10-02-2012, 06:40 PM | #111 |
I took the flares off the old body today. Thank you, RC4WD, for using screws smaller than a flea.
10-03-2012, 11:35 AM | #112 |
Finished trimming the new body. Time for washing, masking, then paint. I cut out the solid doors, planning to use those.
10-03-2012, 12:38 PM | #113 |
Are opening doors extra points? Sent from my DROIDX using Tapatalk 2 |
10-03-2012, 03:53 PM | #114 |
They might be one point; I'm not certain without checking the rules. To be honest......they will probably be glued to the body. Thanks for the idea though The idea of hinges and magnets sounds really cool, but at least for now I just want to press on and get through the projects before the 27th. Need to finish the body, then do the cage and interior. I did finish trimming the body today and washed it. Hopefully tonight or tomorrow I'll do masking and start on paint. Also, if you look at the front bumper in one of the prior photos, there is that piece that comes up from behind the bumper and has the fairlead on it. I did away with that piece and mounted the fairlead to the bumper itself inbetween where the stinger goes through the bumper. I also plan to move the bumper back a little farther, in order to keep it a little more behind the front of the front tires. The new body is a little shorter, so it allows some extra space for this compared to the prior body. So far so good |
10-04-2012, 06:23 PM | #115 |
I got the body painted (still need to put the flares on) and mounted. I also painted the front bumper and stinger, because the rest of the tube work will be black, not silver: Rear body mounts: Tire and toolbox mock-up: |
10-04-2012, 07:42 PM | #116 |
Nice. Love the color choice.
10-04-2012, 08:45 PM | #117 |
Pebble Pounder Join Date: Sep 2012 Location: San Francisco Bay Area
Really liking the color as well. Can't wait to see the body complete..
10-04-2012, 09:55 PM | #118 |
Oops. I forgot about those seats we talked about. Sent from my DROIDX using Tapatalk 2 |
10-04-2012, 09:55 PM | #119 |
Oh and its looking good. Sent from my DROIDX using Tapatalk 2 |
10-05-2012, 06:52 AM | #120 |
Thanks guys, appreciate it. It's nice to see the body painted and on the truck. I'm looking forward to getting more time to work on it, hopefully soon.
AX10 Class 3 scaler Bronco build, cont'd - Similar Threads | ||||
LNC class 2 scaler build thread | Josh_Br | Team Losi Comp Crawler | 78 | 03-27-2014 08:49 AM |
RCROCIN's Class 3 Bronco Build | RCROCIN' | 2.2 Scale Rigs | 24 | 07-17-2012 01:59 PM |
PinchFlat's Reign Labs Bronco Class-2 / Trail Build | PinchFlat | 1.9 Scale Rigs | 84 | 03-20-2011 12:39 AM |
Bronco 2.2 Scaler X trail chassis build | crawlbe4youwalk | 2.2 Scale Rigs | 20 | 10-09-2008 12:42 AM |
DTrail12 C-Channel Scaler build... 'The New Bronco' | Cake Eater | 2.2 Scale Rigs | 44 | 10-29-2006 03:57 PM |
