07-23-2014, 02:28 PM | #221 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
It's been a while since I've updated this topic. Car is having a little makeover.. A new body with the super nice skins from Krawler Konceptz... Thanks again Michelle.. To ad I have to cut it to be comp worthy.. Maybe I keep my old body and put this on the shelf.. |
07-31-2015, 08:29 AM | #222 |
| Re: Dutch AX10 sporty build / Tomi chassis
Well, It has been a while. The car was good, the driver not so.. But we had some love hate and fun.. But now, after so many years, I found it was time for a rebuild.. As I did design de SuDu one and I still drove a prototype v2 from Tomi, I thought it was time to change it to the most recent version, de FL. I also made a change from axles.. Now I go to the wraith axle with some dlux parts on them.. And last but not least... The new one piece gearbox/skidplate from Dravtech.. I dealt with Tobias before and do some things and ideas together so I knew this was the best to do... I trusted his skill on this gearbox.. I already drove the ncd version. Which is a open design on a loose skid. Now I can fill those loud rc4wd gears with some grease.. Lol. Well I hope to update some more pics soon... Now it's only this. |
07-31-2015, 12:12 PM | #223 |
DravTech Join Date: Aug 2012 Location: Sweden
I am glad they arrived safetly and now start building. I want to see more pictures Last edited by Dravpnir; 07-31-2015 at 12:15 PM. |
07-31-2015, 02:36 PM | #224 |
Rear axle almost done. Fitted with underdrive and some nice spools... Only need to change the screws of the link mounts.. These things are so nice.. |
08-01-2015, 06:26 AM | #225 |
Update.. Build the front axle today.. Need to change the servo.. My 7980 won't fit the dlux truss like I wanted.. Also build the chassis... As I'm a bit familiar with the SuDu chassis (Tomi and my brainchild) this was a easy build. The tranny fits awesome.... Great work Tobias... Now time to build up the links... |
09-22-2015, 02:38 PM | #226 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
Very nice !! Does the new closed tranny use the exact same gears as the old open one ? |
09-22-2015, 03:57 PM | #227 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Dutch AX10 sporty build |
09-22-2015, 04:24 PM | #228 |
RCC Addict Join Date: Jun 2009 Location: Australia
Just send me the 7980 Douwe. Ill put to go use for you. Looks good by the way mate. |
09-22-2015, 05:23 PM | #229 |
Rock Crawler Join Date: May 2012 Location: Australia
I know you have the dlux sporty truss, I was in the same position. I love using the 7980 servos. I couldn't find an easy mod to fit the bigger servo into this truss. What I did find, is if you use the ultra 4 truss you can drill a hole through the truss and mount a 7980 without any mods to the servo. Then you can just trim the truss to your desired length. I've done this on the front and rear of my C3 rig. Let me know if you needs pictures. It's worth mentioning, because it's cheaper then buying a new servo. The mod also helps when you have to remove the servo. No need to remove the links and anything above it. |
09-23-2015, 01:52 PM | #230 |
I just had a championship with this rig.. The Dutch/Belgium championship.. I came second (the winner used my car, lol) Little video of my friend driving the car https://youtu.be/De76MmZRmiI And yes Jens, It has the same gears in it.... |
09-24-2015, 12:38 AM | #231 |
Well done to both you and Serge again mate
11-29-2015, 05:45 AM | #232 |
Pebble Pounder Join Date: May 2015 Location: The Rocky maintains
Very nice. What driveshafts can be used with the Sudu one?
11-29-2015, 11:27 AM | #233 |
I use some sdi driveshafts for the rear and some old Junfac ones in front Verstuurd vanaf mijn D6503 met Tapatalk |
Dutch AX10 sporty build - Similar Threads | ||||
WaCkAdOoDlE Sporty build | Chris_The_Battery_Man | Axial AX-10 Scorpion | 55 | 02-19-2015 11:46 PM |
1st build - Sporty | AWDPete | Axial AX-10 Scorpion | 28 | 10-02-2012 04:45 PM |
my ax10 swx sporty rig | peterk | Axial AX-10 Scorpion | 7 | 05-10-2012 07:22 PM |
Dutch AX-10 build | steyn2 | Axial AX-10 Scorpion | 12 | 10-13-2007 01:12 PM |
