02-03-2013, 05:54 PM | #61 | |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
My braces are aluminum. | |
02-03-2013, 05:55 PM | #62 |
02-06-2013, 06:13 PM | #63 |
Rock Crawler Join Date: Jul 2010 Location: St. Albans
| Re: RcBros Sporty Begins
Nice setup. I have the same chassis and mine sits at about 1/2" taller than yours. Are you running 4" shocks
02-06-2013, 10:10 PM | #64 |
| Re: RcBros Sporty Begins |
02-06-2013, 11:23 PM | #65 |
Rock Stacker Join Date: Jan 2009 Location: Calgary
02-07-2013, 06:48 PM | #66 |
Wonder why he suggested that. I have Losi 4" shocks on mine.
02-07-2013, 07:26 PM | #67 |
Rock Crawler Join Date: May 2011 Location: SoCal
The guys I know who prefer the SCX 3.5" over the big bore 3.5" say it's because of the threaded spring perches which allow easy adjustment of preload. Otherwise the big bores are highly regarded.
02-07-2013, 07:31 PM | #68 |
Honestly I use to think big bores were the best, but with these uber light trucks it's almost night and day with the scx10's. The shocks when built correctly are extremely smooth and predictable and for some reason work alot better. I've switch to these shocks on both my 2.2 rigs |
02-07-2013, 08:32 PM | #69 | |
| Re: RcBros Sporty Begins Quote:
02-14-2013, 09:33 AM | #70 |
This truck will be seeing a minor facelift In the next couple of days. I had Neal at freq-e-skins make me a custom Parma inside skin. I wanted somthing different and sent him some examples. I like it and can't wait to have them! |
02-14-2013, 10:37 AM | #71 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: RcBros Sporty Begins What is included in "built correctly"? Obviously fluid and spring choice, and maybe custom extended perch if using short springs. What else?
02-14-2013, 10:53 AM | #72 |
Ideally the egressor delrin shock bodies, new seals and deburring of the parts tree piston so it slides smooth. Adding a thin coat of green slime to the shaft and seals and these are butter smooth. For this build I am trying the stock shock bodies. I've heard of leaking issues but so far so good. I do have the delrin bodies on my berg and they are more consistent and smooth on the stroke but these should hold fine on my budget sporty. |
02-18-2013, 01:58 PM | #73 |
Well I got all the VP 8* goodies back on the front and swiss cheezed my front mount to get the CG a little lower. Other then adding some knuckle weights, motor and body this thing is ready to rock! |
02-26-2013, 09:59 PM | #74 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Nice Build. A query if I may. Have you spaced the servo plate up to fit the servo, or is it sitting straight on the axle posts? Did you have to do any work to the pumpkin servo side to accommodate the steerer? I've tried to spot it from the photos, but can't quite pick it. I have a Kush build about to commence, I may use some of your cues for my build Downunder. |
02-26-2013, 10:01 PM | #75 | |
No spacers underneath the post. I am using our RcBros servo posts which set the servo flush n the mount. | |
02-26-2013, 11:33 PM | #76 |
OK, Thanks, I might need to add a set of the servo posts to our next lot of weights. I'll have a yarn to Highlucks about adding them... |
02-27-2013, 08:02 AM | #77 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Very nice. I like your front end setup, similar to mine. I managed to squeeze everything on the front axle. |
03-17-2013, 09:57 PM | #78 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Here's some pics from today |
03-17-2013, 10:01 PM | #79 |
haha poor truck.. I drove the whole last course broke like the bottom picture and still finished with just a reverse penalty and a dumb gate lol. Thanks for the pics Everett!
03-21-2013, 08:33 PM | #80 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
I seen in your pics that you ar still running the three link, how's that working out with this set up?
RcBros Sporty Begins - Similar Threads | ||||
and so it begins | Slyp Dawg | Axial SCX-10 | 2 | 03-02-2011 11:05 PM |
ad it begins!!! | STEEL_CITY_CRAWLER | Chit Chat | 23 | 01-11-2011 03:29 PM |
And so it begins... | Slow_Joe | 2.2 Scale Rigs | 5 | 08-02-2009 08:40 PM |
It Begins..... | Canadian Crawler | Tamiya TLT Crawlers | 15 | 11-24-2006 10:10 PM |
and so it begins | mississippijeepfreak | General Crawlers | 3 | 07-06-2006 04:27 AM |
