08-21-2013, 05:57 PM | #41 | |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
| Re: Margouillat AR60 Quote:
Thanks | |
08-25-2013, 07:19 PM | #42 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
I notice your motor is on the left hand side (when view from above and front point away from you). Can you put the motor to the RHS so to help the torque twist? I took a look at the R2 tranny, I think you can swap the motor to the other side by taking out the end plate and flipping (inside out) it and the motor should be on the RHS.
08-26-2013, 07:18 PM | #43 |
Hi, I like the AR60 axle, because it is easy and simple to change their direction of rotation, while turning over the spool simply It is simpler and rapid than modify the transmission This to rig is just a prototype, it's not a project which will be finalized in the immediate future, I will make still much change and to test various solutions |
10-19-2013, 11:09 AM | #44 |
Hi, After one long period, I decide to continue this project. I benefit from it for to test an idea that I trail since years, a tranny contrarotating. The idea is to have the 2 driveshafts which go to the axles, which turn in opposite direction, the goal being to decrease the torque-twist. I saw, there is a few times, a thread of Egressor' AX-10, which also had tested this solution and seemed satisfied about it. That consolidated me in the idea that the principle was viable. I thus arranged a contrarotating R2-V2, history to test all that The principle being simple, it is enough to add a second exit of tranny, directly pulled by the first. They thus turn in opposite directions. On the pic, the bottom shaft goes to the front axle, and the top shaft go to the rear axle. The surplus of weight is very tiny, that is to say approx. +20g… In situation. After some adjustments, the principle seems viable, the torque-twist with quasi disappeared But, once more it is not a miracle solution. A contrarotating tranny does not make disappear the torque-twist, with it only. It is always necessary to carry out many adjustments… What is interesting, it is that the torque-twist is very clearly decreased in reverse. I go to continue my tests |
10-19-2013, 11:19 AM | #45 |
Less torque twist in reverse direction? Have you considered reverse polarity on the motor and copping of the diff fear I the axle housing to see if that has a positive effect?
10-19-2013, 11:30 AM | #46 |
Hi TheSCorpionKing Yes, less torque twist in reverse direction For example, in reverse (with OD and UD gear) if you turn the front wheels, a rear wheel raises ground. Now, in reverse, the rig is always perfectly flat, even if I turn the front wheels. I make a vid to compare, my AX-10 sportman and this rig... |
10-19-2013, 09:08 PM | #47 |
RCC Addict Join Date: May 2013 Location: York, PA
Nice work. I'm very interested to see what the ultimate result will be. Also interested in your video. My friend's rig lifts a tire in reverse just as you describe. Mine does not. We weren't sure why. His motor is in the same position as yours, mine is opposite. Perhaps that's the underlying cause. |
10-20-2013, 10:44 AM | #48 |
Rock Crawler Join Date: Feb 2013 Location: york
My rig was lifting a tire in reverse after reading this I mounted my motor in the opposite direction and the torque twist was almost completely eliminated
10-20-2013, 10:58 AM | #49 |
Hi, Two significant factors must be considered:
10-20-2013, 12:09 PM | #50 |
I have OD/UD gears installed
10-20-2013, 04:23 PM | #51 |
Hi, Today, I worked on front damping. The position of the front shock on the AR60 axle is very spaced. The rig is very stable but unflexibility in crossing. I thus test different inking of shock and more closer. I also shortened the shaft of the shock , to limit it. I wish to keep the green springs Losi Now, it's enables to pass this kind of obstacle: With the inking of origin, it was reversed systematically. But it lose some stability in side hills, I will have to find a compromise |
11-16-2013, 04:18 PM | #52 |
Bonjour, Today I received the parts from Tomi, as usual it is super clean and precise It's 2.5mm CF. The whole of the parts: First assembly On this project, the skid is very complex, but it enables me to minimize frictions, without having to reduce the width of the trany. It is inspired by the SCX-10 or the Losi. Assembly of the front axle. The part surely still will evolve, probably on the level of position of the shock. And the trany She weight 95g (with skid). The finalized skid And finally, the crawl it in its natural environment The final weight is of 1,505 kg RTR - 3 lb and 5 oz (without the 115g - 4 oz of weight distributed in the 4 wheels). The weight should quickly go down under the 1,500 kg with some optimizations. Tomorrow, probably first tests @+ Last edited by TotoRax; 11-16-2013 at 04:37 PM. |
11-16-2013, 04:37 PM | #53 |
Rock Crawler Join Date: Jan 2011 Location: At home
Looking good Love your builds ... truly innovative Last edited by Haastnooit; 11-17-2013 at 12:13 AM. Reason: I cant write simple words correct the first time ;-) |
11-16-2013, 04:41 PM | #54 |
| Re: Margouillat AR60 |
11-16-2013, 04:50 PM | #55 |
Rock Stacker Join Date: Mar 2013 Location: UK
I love seeing the love sweat n tears in these builds. Get it done |
11-16-2013, 04:59 PM | #56 |
Fantastic work here. As Banners said in another post, not many out there making their own stuff. Most just log into Paypal and wait for the mailman...... This rig is full of unique, simple, complex, brilliant ideas. Keep up the good work and we'll keep watching, in awe. |
11-16-2013, 05:07 PM | #57 | |
Thank you for your comments Quote:
11-16-2013, 06:05 PM | #58 |
Quarry Creeper Join Date: Feb 2011 Location: Germany
Whenever you post up new stuff, i'm speechless. Absolutely amazing craftsmanship. |
11-16-2013, 09:24 PM | #59 |
Looks fantastic as usual. Have you had more time to rest the counter rotating transmission?
11-16-2013, 10:20 PM | #60 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
Your ideas and the implementation are admirable, Stefane. Impressively work |
Margouillat AR60 - Similar Threads | ||||
Margouillat SportsMann | TotoRax | Axial AX-10 Scorpion | 134 | 07-29-2013 08:01 PM |
Le Margouillat. | TotoRax | Axial AX-10 Scorpion | 36 | 03-04-2012 06:42 PM |
Ar60 threads | demonoid369 | General Scale Talk | 1 | 07-19-2011 04:48 AM |
