02-27-2014, 11:08 PM | #81 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: Margouillat AR60
I bow to the Master...awsome, awsome, awsome... The answer about the question to the torque twist will be very interesting. |
02-28-2014, 02:16 AM | #82 |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
Thank you for your comments For the torque twist, I have some a little but I must re-examine the adjustment of the shocks and the upper link geometry. It is only a first prototype to check that the idea is viable and to test, but it functions already very well (for the moment ). |
02-28-2014, 05:26 AM | #83 |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
Hi, once again, i'm just Realy nice rear axel was thinking about something with CF tube, you've done it with No tube realy nice looking !!! will you protect under it ? |
02-28-2014, 11:55 AM | #84 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I really like the bodiless s class. I wish they would allow it in comps here.
02-28-2014, 01:30 PM | #85 |
That is just BONKERS! Looks like you may have been an architech in a past life |
02-28-2014, 01:50 PM | #86 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Wow. These are Nice. Crawling is going back to the early days... Everyone is making their own custom parts.... Verstuurd vanaf mijn EndeavorU met Tapatalk |
02-28-2014, 01:51 PM | #87 |
Rock Crawler Join Date: Jan 2011 Location: At home
Wow .... really great looking axle Very innovative as usual |
02-28-2014, 02:31 PM | #88 | |||
thank you for all your comments Quote:
Just to laugh, one of my first to crawl here, the Crawler'Pillar !!! Most expert will recognize wheely king axle and trany With my exotic trany Thanks Quote:
Yes, I think surely with a plastic sheet. | |||
02-28-2014, 06:39 PM | #89 |
Is the roof panel fitted into slots in the cross brace?
02-28-2014, 07:01 PM | #90 |
| Re: Margouillat AR60 |
03-02-2014, 06:51 PM | #91 |
HI, Thus I could make some tests. First assessment that functions very well. I have to make some modifications on the position of the rear lower and upper links and the shock on the axle. some pics in the natural habitat of the rig To prevent that the axle hang, I have just to add a plastic sheet to round the shape of the axle, as a result that does not block more!! I replaced the 2 halfshafts by only one length shat. That makes it possible to align the various elements of the axle well so that it functions correctly. I made the new shaft with a steel stem of 5mm, that functions well, but it weighs very heavy: +40g It will quickly be replaced by one in titanium I have also to remake my parts in delrin, they are placed at the end of axle and serve as bearing. The delrin is very well for this application, it is car lubricated and resists very well in time. Now, it turns very well, even better than with the AR60 axle |
03-02-2014, 11:46 PM | #92 |
Pebble Pounder Join Date: Aug 2011 Location: NSW, Australia
| Re: Margouillat AR60 Beautiful work.
03-03-2014, 07:13 AM | #93 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Good Work Stephane Go for a AL Tube Shaft on the rear that should turn our around 10-20g for the shaft |
03-03-2014, 08:04 AM | #94 |
03-07-2014, 12:17 PM | #95 |
Hi, I make a new support of rear lower links Now the rod ends of the link and shock are well in the axis and function perfectly freely some is the movement. For the fixing of the shock absorber on the frame, I use a old tip (found in this forum), a head of pastic shaft to offer more freedom of movement to the rod ends. New rear upper link * And much of work on the position of the shock and the rear upper links… After much of tests, the rear axle functions very well, they are cool |
03-07-2014, 06:18 PM | #96 |
RCC Addict Join Date: May 2013 Location: York, PA
Super cool stuff man. That's a really good idea with the shock mount. Acts as a stand-off, and doesn't add any extra length to the shock. Your axle is turning out very awesome. Can't wait to see the next post, and the one after that, and the one after that......... |
03-07-2014, 06:50 PM | #97 |
03-08-2014, 06:52 AM | #98 |
Rock Crawler Join Date: Feb 2013 Location: york
You always amaze me with the stuff you do! Is there any plans of a front axle to match? Sent from my C811 4G using Tapatalk |
03-08-2014, 07:03 AM | #99 |
Thanks, for front axle, I reflected but the project is not succeeded yet... not yet !!
03-23-2014, 07:26 AM | #100 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
I look forward to all of the innovation and design that you put into your projects. I think you must be a mechanical engineer.
Margouillat AR60 - Similar Threads | ||||
Margouillat SportsMann | TotoRax | Axial AX-10 Scorpion | 134 | 07-29-2013 08:01 PM |
Le Margouillat. | TotoRax | Axial AX-10 Scorpion | 36 | 03-04-2012 06:42 PM |
Ar60 threads | demonoid369 | General Scale Talk | 1 | 07-19-2011 04:48 AM |
