03-23-2014, 04:31 PM | #101 | |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
| Re: Margouillat AR60
Hi, Quote:
This week, I am finally to decide to made an idea that I have in the head for a long time, of the full CF rim. I just replaced the spacers by a round in CF on my old rim. It is extremely solid, probably more than with the spacers and it is 3 or 4g of gained… The rims weighs 10g and probably less with one more specific design I wait my tires to test them on the rocks!! | |
04-28-2014, 11:08 AM | #102 |
Hi, Some news. I received the rear titanium shaft. Thanks to CREEPERBOB Only 18g compared to 42g of the steel shaft. New front shock, I prefer the BigBore to the shock of SCX10. After many, many tests, I found the good geometry of rear links to manage the torque twist. This rig was very, very long to develop and to regulate but now it functions with wonder, a true pleasure to drive… A litle video here |
04-28-2014, 03:31 PM | #103 |
RCC Addict Join Date: May 2013 Location: York, PA
I'm so excited when I see a new post from you at the top of the board. Never know what to expect, never disappointed.... Awesome video. Rig looks fantastic! |
04-28-2014, 04:05 PM | #104 | |
| Re: Margouillat AR60 Quote:
That was a nightmare to regulate it but now that it functions well, it is very pleasant | |
04-28-2014, 04:39 PM | #105 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Beautiful work on the rear axle. Looking forward to how you handle the front axle.
04-29-2014, 02:12 AM | #106 |
Fantastic work as always. The rig looks like it is performing like a champ |
04-29-2014, 06:03 AM | #107 |
Hi, Thanks for your comments For the front axle this will be long, there is much difficulty of surmounting |
04-29-2014, 08:03 AM | #108 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
I'm sure you'll come up with something great .
04-29-2014, 08:47 AM | #109 |
Always fun to watch you work. |
05-03-2014, 12:31 PM | #110 | |
Rock Crawler Join Date: Jan 2011 Location: Portugal
Love all the work you do on your car. Very inspiring. What is the thickness of the carbon fiber on your back axle? | |
05-03-2014, 03:45 PM | #111 |
Hi, Thank you for your comments The 2 parts do not have the same thickness. In front, I use 2.5mm CF and in rear, 1.5mm |
05-05-2014, 04:12 PM | #112 |
Hi, I am to decide to made the supports of weights. This part is complicated to make for me because I use hub very small and there is thus very little place. Therefore, I started from a profile aluminum in L Afert some cut In situation With one half flat washer to start, I expect narrow M22 flat washer to supplement ballasting. It is necessary to count 12/13g by half-flat washer approx. With wheel Although this part exists already done everything, I preferred to do it for several reasons. Already with the horrible time for the delivery, I am not on receiving them before Big in Jully. Then, I fear that on the version commercial, the central hole is too small and that my hub blocks. Thus as long as has to make, I did them This is my delrin hub I expect the flat washer to finalize ballasting front and rear and remplace the VP rim by CF rim. Last edited by TotoRax; 05-05-2014 at 07:09 PM. |
07-29-2014, 06:57 AM | #113 |
Pebble Pounder Join Date: Dec 2011 Location: françe
congratulations on your first place to shafty french nats |
07-30-2014, 02:07 AM | #114 |
Thanks David, But the CCC Team driver are very very close !! You made of great run also!! With my shafty I also ran in the category pro (I don't have 2.2 pro ), and to finish 3eme in the top 10 has me surprised but pleases . Then very difficult finale, where I finished 8eme... My nickname is BadRax on french |
08-03-2014, 11:48 AM | #115 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
Congrats my friend - great driving |
08-03-2014, 12:11 PM | #116 |
| Re: Margouillat AR60 |
08-18-2014, 07:18 PM | #117 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
You can compete without a body in shafty class in France? That should be the rule anywhere. In US, a 12" by 5" by 3" body is required for shafty class. That is such a travesty. That rule will be changed sometime, but I can't say when. Apparently someone thinks it is necessary for now. These mechanical beauties should be enjoyed and run without obstruction.
08-18-2014, 08:46 PM | #118 |
Rock Crawler Join Date: Jan 2009 Location: Great NorthWest
very impressive with a shafty congrats |
08-19-2014, 12:19 AM | #119 | |
Crawler is a category of RC really different. The rules is conceived around the (logical) idea that the beginners will start with a sportman and the more experienced pilots will go to the Pro. Personally, I think that it is the opposite, it is what I noted in France. There are several reasons has that:
Thanks. Last edited by TotoRax; 08-19-2014 at 04:20 AM. | |
08-19-2014, 09:02 AM | #120 | |
Quarry Creeper Join Date: Jul 2013 Location: Kronach, Bavaria, Germany
Congrats to thatvawesome placement:thumbup: Quote:
I don't have a pro, too... Just a shafty. In Germany only experienced drivers like ZZR and Fritzthefly etc. are having a shafty, the "beginners" are all starting with a Pro because Pro rigs are a little capable like edges etc. and you can correct drivemistake more easily with the dig. ;) Also the COG of a Pro is a lower than the COG of a shafty. Begginers are not driving comps at the start, they just want to drive "by their own rules" and in their "freetime" and for this usage a Pro is way better than a Shafty. Sent from my SONY Xperia Z using Tapatalk 2 Last edited by braune; 08-19-2014 at 09:05 AM. | |
Margouillat AR60 - Similar Threads | ||||
Margouillat SportsMann | TotoRax | Axial AX-10 Scorpion | 134 | 07-29-2013 08:01 PM |
Le Margouillat. | TotoRax | Axial AX-10 Scorpion | 36 | 03-04-2012 06:42 PM |
Ar60 threads | demonoid369 | General Scale Talk | 1 | 07-19-2011 04:48 AM |
