01-01-2013, 03:28 PM | #101 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
| Re: Krawl's shafty "The Villian S"
Looks like an 86jeep steering style set up, maybe some really trick and light weight CF servo mount is in the works.
01-01-2013, 08:10 PM | #102 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
| Re: Krawl's shafty "The Villian S" They are the same Correct Cut and re-flat the long ar axle..takes about 5 minutes |
01-01-2013, 08:16 PM | #103 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Krawl's shafty "The Villian S" |
01-02-2013, 12:04 AM | #104 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
VERY NICE build so far Jeremy. Ya got about 2 months & change to have her crawlin. I have a feeling she's gonna be force come March. J.D. |
01-03-2013, 12:16 PM | #105 |
01-04-2013, 11:00 AM | #106 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| Re: Krawl's shafty "The Villian S" Looking good so far. So what's your reason for narrowing the axle this way? I have one I have been working on that shortens up just the long side as well. I am only doing it to keep the drive line from being such a pain in the ass. Although I am still going to try and use a full width because I want there to be as little scrub as possible. But the drive line angles with such a wide axle make it hard to have a narrow chassis and the links not collide... |
01-04-2013, 11:17 AM | #107 | |
| Re: Krawl's shafty "The Villian S" Quote:
I wonder how wide it would be to use a stock XR10 on the other side? It would be great to no have to cut the uni. Last edited by sally1800; 01-04-2013 at 11:21 AM. | |
01-04-2013, 11:21 AM | #108 |
It would have to be nearly as short as the other side. Probably putting it narrower than an XR10. The short side of the wraith is only a little shorter than an XR10 uni. So the diff would only be offset by around a half inch
01-04-2013, 11:47 AM | #109 | |
i narrowed it in this fashion because the full width is simply to wide in my opinion. you could use full face wheels with a narrow hub but then you would be right back into the links when steering. this way i narrow the spread at the axle for the axle side lowers (which has more to do with the geometry i am trying to attain) as well as gives me the full steering capability (60*+) that i am looking for without touching the links while using a 350 hub. i also get the benefit of the offset pumpkin that will give me more under axle clearance at any given position than flat. hope that answered your question. | |
01-04-2013, 11:47 AM | #110 |
01-04-2013, 11:50 AM | #111 |
01-04-2013, 11:54 AM | #112 |
01-04-2013, 11:56 AM | #113 |
01-04-2013, 12:11 PM | #114 | |
The width would force you to run a narrower offset wheel, then killing off any scrub. That's also another thing I want out of less scrub on an RC. Stronger steering. Seems that's been whats helped the supers only use 1 servo Last edited by Chris_The_Battery_Man; 01-04-2013 at 12:14 PM. | |
01-04-2013, 12:19 PM | #115 |
Like anything else it's a trade off, he seems to be willing to have the scrub to achieve everything else he is after.
01-04-2013, 12:21 PM | #116 | |
you could have + or - scrub with wide or narrow axles. so sticking narrow offset wheels on a wide axle doesn't eliminate scrub all together. also, the scrub is not really what keeps your tires out of your links either, it is room. you are right about the steering being quite a bit stronger though that is a welcomed side effect of have proper steering geometry. | |
01-04-2013, 12:22 PM | #117 |
01-04-2013, 12:23 PM | #118 |
Interesting. Appears there is more into it than I thought. Perhaps I will have to sit down with my buddy who's an alignment tech, and get some knowledge Yeah, the power is certainly better. I seem to never have enough on my rigs. Even with the super cool Futaba BLS157HV I still feel there could be more on my 2.2. Perhaps the sporty will be fine with 420 and limited scrub |
01-04-2013, 12:25 PM | #119 | |
01-04-2013, 12:31 PM | #120 |
Have you started the rear axle?
Tags |
molly whop |
Krawl's shafty "The Villian S" - Similar Threads | ||||
Krawl's "THE NEXT LEVEL" SUPER AGENT #1 | krawlfreak | Superclass Crawlers | 323 | 03-13-2014 02:08 PM |
Krawl's "SECRET AGENT" turned "DOUBLE AGENT" | krawlfreak | Axial XR10 | 1361 | 12-05-2013 08:25 AM |
Krawl's RC4WD Build Off Entry " The Overlandy" | krawlfreak | 1.9 Scale Rigs | 51 | 04-17-2013 05:47 PM |
4xFord's "Super Villian" Team Y-Town build | 4xFord | Axial XR10 | 174 | 02-01-2012 02:01 PM |
"TWIN FREAK" Super Shafty First run video | v84x4 | Videos! | 7 | 03-28-2011 06:40 AM |
