01-19-2013, 01:52 PM | #21 |
| Re: Gerry´s 2.2s Build
I'm really liking this build. What is your track width with your front wheels setup like that?
01-19-2013, 02:19 PM | #22 |
Quarry Creeper Join Date: Jun 2009 Location: Austria
| Re: Gerry´s 2.2s Build |
01-25-2013, 01:40 PM | #23 |
Between i have the most parts here that i need to finish.... Part List: Super 300 HD´s XR10 Over und Underdrive Felsenfest Shock Bodies flanged bearings ........... Now i have just to wait for the tubes from biggin69 and then the party can go on... |
01-26-2013, 12:56 PM | #24 |
Time to install the flanged bearings - in the new tranny at the new skid The weight: Installed: Random weight RTR: 1420g - 3lb 1.3oz LG Gerry |
01-26-2013, 06:37 PM | #25 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
Lightweight wonder!
01-31-2013, 01:27 PM | #26 |
Today, the last piece for my rear axle comes in: 1x Felsenfest One Piece Rear Axle Shaft made from 5mm Ti Weight check: Rear axle is now done |
01-31-2013, 02:50 PM | #27 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
Very nice and very interesting. Please help me understand - why is the front axle mounted to the chassis, leaving only the rear axle to articulate separate from the chassis? Thanks |
01-31-2013, 03:00 PM | #28 | |
| Re: Gerry´s 2.2s Build Quote:
i designed this chassis 2009 - in this year it was just a try to drive only with 2 shocks on the rear axle. The idea behind - i thought that so could be more traction on the front axle. It´s a little bit special to drive, but i love this feeling and can handle out these kind of setup very good. The second reason was the torque twist - 2009 that was really a problem... Hope you understand what i mean, my english is not perfect If not, don´t shy to ask again... Gerry Last edited by Gerry; 01-31-2013 at 03:04 PM. | |
01-31-2013, 03:12 PM | #29 |
Thanks, I believe I understand. So......does it work? How does it crawl compared to a traditional setup? I asked because I have an AX10 turned class 3 scaler. It does not have a lot of articulation, and I was thinking of modifying the rear axle set up so the rear would flex a lot more.....it would be a little similar to what you did here. |
02-02-2013, 04:14 AM | #30 | |
02-04-2013, 01:34 PM | #31 |
Next step: Today i got the beef tubes, thank you Dan! Here they are: The old CVD´s: The new Super 300 HD´s for the XR10: Weight of the axle before: And after the mod: The difference is not so much and the axle is now wider and bullet proof - just have to do some little things and change the Knuckles against VP Wraith Knuckles... The weight i have now more on the front axle, i will soon loose on an other position |
03-16-2013, 12:08 PM | #32 |
Ok, next step... At the moment i wait on my VP Wraith Knuckles - so i have do some parts on the CAD for lowering the CG: So i can lower the servo a little bit, also the LiPo Between the CFK plates in the middle of the axle i will put the receiver and behind the axle the other electronic... Hope i have time to mill the pcs in the next days... Also i think about another option for mounting the rear upper links - not sure if this will work well, but i think it´s a try worth... Gerry |
03-17-2013, 07:46 PM | #33 |
Pebble Pounder Join Date: Feb 2013 Location: Charleston
This is an impressive AX-10 to say the least. I have always wondered how the solid front suspension crawlers worked. It's cool to see that they actually work pretty well. Did you do the whole transmission yourself? |
03-17-2013, 07:54 PM | #34 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Very nice work, cant wait to see eveeything on the front axle. Thats how i have mine, it works good
03-18-2013, 01:58 AM | #35 |
Thank you guys! The tranny i did myself, but i have to redesign it, the ratio is to less and i don't have some drag brake with it. Good to know that the front parts will work fine, just some steps to finish, then i can go out to test it and i will do a video from it! |
03-18-2013, 12:09 PM | #36 |
How low can you gear your truck without a spur in the transmission? I really do like your front servo plate though. |
03-18-2013, 12:28 PM | #37 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Nice build Gerry... Will you go the the supercrawl?
03-18-2013, 01:25 PM | #38 |
RCC Addict Join Date: Jan 2005 Location: Germany north
03-18-2013, 01:46 PM | #39 |
03-18-2013, 01:58 PM | #40 | |
Yes, i´m there - will arrive on Friday morning by car with 2 other austrian guys... Would be a great event, can´t wait to see you all in person | |
Gerry´s 2.2s Build - Similar Threads | ||||
Gerry´s Axial JK... | Gerry | Axial SCX-10 | 68 | 04-11-2013 12:47 PM |
Gerry´s XR10 - little duck | Gerry | Axial XR10 | 14 | 10-16-2012 09:56 PM |
Gerry´s LCC Mini - The Reborn | Gerry | Losi Mini-Rock Crawler | 27 | 05-10-2012 11:23 AM |
Gerry´s BWD Mantis | Gerry | Axial XR10 | 10 | 09-12-2011 04:12 PM |
Gerry´s XR10 | Gerry | Axial XR10 | 40 | 12-27-2010 05:45 AM |
