joshsmith512 oldschool to newschool sudu So i have been wanting to update the 4lb 13 oz ff4 which has served me rather well, quite a few first and seconds. So after alot of looking, i hooked up with tomi and douwe from nordic crawler designs. These guys are the friendliest and most helpful i have dealt with on rcc. So the goal is to get around 4lb flat. Here is the breakdown of parts i will be gleaning from the oldschool ff4. Front axle- ax10 housings with creation fab wide splined v2 tubes, vp wraith knuckles and chubs, bonusline locker( wow what a pig but oh so tight), xr unis, vp razors, ncd weight holders custom designed to work with dlux weights, mip front center drive custom drill press lathed for weight reduction(9 grams), bc upper link mount, 7990 the beast, ti tie rod and just got finished getting rid of all the black oxide screws for sexy new red aluminum ones. Chassis is the new sudu one from ncd- what a piece of cf goodness Trans- hr alum case with hr alum gears, bwd motorplate, wraith outputs, and the 13t crawlmaster speed demon:twisted: Rear axle- ax10 with fresh red aluminum hardware, vp razors, a i have never seen another one like it no slop alum locker, plastic lockouts, oldschool d mount, and a wildboar rear drive shaft, ti links, ud gears Aluminum hr red pivot balls throughtout Was running slash proline shocks, now switching to proline scalers with cap mod for now Brxl of course, castle bec, 4pl, creationfab receiver bypass , gens ace 450or cbp 450or600 Slw v4 lightened with ci closed cell and soft outers, and ci khaos rovers A couple of before shots http://i1007.photobucket.com/albums/...127_202036.jpg http://i1007.photobucket.com/albums/...127_201918.jpg http://i1007.photobucket.com/albums/...127_201850.jpg So the beginning of the rebuild http://i1007.photobucket.com/albums/...ps03224fb7.jpg 49 grams http://i1007.photobucket.com/albums/...ps45fd6e29.jpg http://i1007.photobucket.com/albums/...ps3b750c2f.jpg Heavy trans in http://i1007.photobucket.com/albums/...psdba8a52e.jpg Rear axle http://i1007.photobucket.com/albums/...ps93473eff.jpg Got the rear axle on but have run out of time for tonight, see you all tomorrow"thumbsup" |
Re: joshsmith512 oldschool to newschool sudu Great choice on parts! Cant wait to see it together. |
Re: joshsmith512 oldschool to newschool sudu Looks great! I'm trying to find a good time to come up and comp with you guys... And I'd love to see this there too as I'm planning on building one after I get the mini and 2.2 Pro running "thumbsup" So you going to get any NCD wheels for it ever? |
Re: joshsmith512 oldschool to newschool sudu Looking good Josh "thumbsup" |
Re: joshsmith512 oldschool to newschool sudu Quote:
Re: joshsmith512 oldschool to newschool sudu got the roller together links worked out great as the wheelbase is 12.4999999999:ror:. found the front mip is just a hare long so lunchtime project tommorow cut and weld. heres a few pics. http://i1007.photobucket.com/albums/...psfc4a093c.jpg ride heigth at 3 http://i1007.photobucket.com/albums/...ps7236b3df.jpg massive amounts of steering even with the huge khaos's http://i1007.photobucket.com/albums/...ps79effdce.jpg http://i1007.photobucket.com/albums/...ps81717443.jpg madatory flex shots http://i1007.photobucket.com/albums/...psde5e449e.jpg balance point just a whisker in front of the front link http://i1007.photobucket.com/albums/...ps31eff324.jpg so 4lb 2 oz without esc, battery, rx and body. so it looks like i might be a little over 4lb. but still low 4lbs once tomi ships the ncd cf rims. 4 flat is probably obtainable without the heavy khoas's, but i love the way they have worked and have been the only tire i have run for a while on my sporty. hope to have most of the electronics wired tonight. |
Re: joshsmith512 oldschool to newschool sudu forgot also have some alum tube comin for lightweight braces and will probably make some uppers as well. |
Re: joshsmith512 oldschool to newschool sudu i love those rear upper links looks great"thumbsup" |
Re: joshsmith512 oldschool to newschool sudu Nice looking SuDu man!!!! Nice with all the aluminium!!! |
Re: joshsmith512 oldschool to newschool sudu Well was wiring some 16 gauge onto the brxl, finished and wired the rest just to plug in and get flashing red led only doh. Getting the wp brxl in now, no not heavier:cry:. Went to cut the mip female side and just as i cut it realized i had turned it down to far to weld it. So back to the drawing board on the front driveline, do you guys think a wildboar with stiffner in the front center will hold up to a 13t cm on 3s? Or stick with mip. Suggestion welcome. |
Re: joshsmith512 oldschool to newschool sudu If you want to lose some weight, why not use Castle Micro Sidewinder?? I would say at least an oz lighter than WP BRXL, from memory, my MSW plus BEC is only about 30 grams. Also loose your alloy tranny housing would save a few grams too. That's overkill unless you run brushless for FOFF application. I like your links, nice bent on the rear upper. |
Re: joshsmith512 oldschool to newschool sudu I use a junfac driveshaft up front. They have all lengths of driveshafts. And not to expensive. |
Re: joshsmith512 oldschool to newschool sudu So got a few parts and some progress made. Wheelnuts 3 grams http://i1007.photobucket.com/albums/...ps7dba6398.jpg http://i1007.photobucket.com/albums/...ps22c116e4.jpg Brxl wp 49 gram. Mamba micro, bec, rx bypass, receiver and wiring all shrunk up 40 grams http://i1007.photobucket.com/albums/...psa44ad274.jpg http://i1007.photobucket.com/albums/...ps7b57e8c4.jpg Rtr weight without body http://i1007.photobucket.com/albums/...ps4f9388d6.jpghttp://i1007.photobucket.com/albums/...psc6955241.jpg |
Re: joshsmith512 oldschool to newschool sudu Build looks good, Josh. "thumbsup" I hope to have your wheels ship today. |
Re: joshsmith512 oldschool to newschool sudu Yeah, well mines at 3.908lbs with the alum Kusk rtr! Shootin for 3.5. Better get to work sucka!:flipoff: |
Re: joshsmith512 oldschool to newschool sudu How's going on with this build?? Like to see what wheels you got from tomi. The weight can be much lower ;) |
Re: joshsmith512 oldschool to newschool sudu Sweet build so far. |
