05-10-2013, 02:14 PM | #181 |
Rock Stacker Join Date: Aug 2011 Location: Milan, Italy
Cool, will definitely try with revo ends and 5mm cf rod :thumbsup:
05-11-2013, 04:24 AM | #182 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne
Well .... in the waiting room again ... I got my electronics boxed up to be send out for a smash job. For electronics I will be running all the spares that I have. Also I sort off retired the Ole BJ4 by robbing the servo. I got a new servo in the works, but not sure when I will able to get it ... Electronics Tekin FXR Tekin 35T pro motor Hitec HS-7954SH CCbec 10A set at 7.2V Futaba R2106GF RX Meanwhile I will get some minor adjustments and the last little things done and then she finally will be ready for some rocks |
05-13-2013, 02:02 PM | #183 |
I send out my electronics today ... so now it is time to do some little tweaking and finishing up some loose ends. My list of things still to do: 1) Articulation is a little bit more as I like so I am going to add additional limiters to the shocks. Current front and rear is 7.5mm, I will be adding 2mm in front and 5mm on the rear shocks. I will also try out a different postition for the rear shocks (one hole to the back). 2) Mount lipo and make additional cut on the body to clear servo and lipo. I will be lowering the body a bit, if possible. 3) Draw up and get a custom E-tray to better fit my electronics setup, if needed. I think it could be a little smaller with my setup then the stock one is. Hopefully I can lower the E-tray a bit as well. 4) Glue the tires. It is my first time around with CF glue-on wheels, I never glued a big crawler tire before. Let alone glue to CF rims, so a question for all of you: Do you glue the tire the whole way around or multiple spots on CF rims ? Thanks Last edited by Haastnooit; 12-08-2021 at 01:07 PM. |
05-13-2013, 02:23 PM | #184 |
I'd go with thin continuous layer... Wouldn't like to have tire to stretch unevenly
05-13-2013, 02:28 PM | #185 |
Thanks ... that is what I am thinking as well ... BUT ... I do know of some people glueing the tire on like 6 spots or something Little curious what the general opinion is ... |
05-13-2013, 02:44 PM | #186 |
RCC Addict Join Date: Jun 2009 Location: Australia
Hey Ronald depending how many beadlock screws just a small dab on the bead in one or 2 places evenly between the beadlock screws. That way if you have to remove the tyre its not a major issue. Sent from my GT-I9300 using Tapatalk 2 |
05-13-2013, 02:55 PM | #187 |
Thanks Ben, I am running 5 bar wheels so in my case you would do 5 dabs total ? Did you ever had problems with tires coming loose with the dab-method ?
05-13-2013, 03:13 PM | #188 | |
Also be cautious not to over glue. Wipe away straight away as if it dries on the cf it dries white and looks daggy. 5 dabs is fine. Sent from my GT-I9300 using Tapatalk 2 | |
05-13-2013, 03:23 PM | #189 |
That's nice to know, any problem in heavy grippy rocks?
05-13-2013, 03:32 PM | #190 |
Mutsa my advice if your concerned is do the mininum first and you can always pry the tyre bead away from the bead lock ring if extra glue is required. Just an estimate but it seems to take about 10mm each side of a beadlock screw or a dab of glue for the bead to get any movment. As most rigs are light thus the reason for glue on wheels i havent gad enough pressure to pop a bead off. My Sporty still has a conventional bead lock, ive been using glue on with both my pro trucks fine. Sent from my GT-I9300 using Tapatalk 2 |
05-13-2013, 03:48 PM | #191 |
Cool thanks Ben The glue I used in the past on tires of onroad cars was very thin and would run the bead. For the dab method the glue has to be thicker and not run too much ... What particular glue you normally use for the tires ?
05-13-2013, 05:10 PM | #192 |
Ill have to check when i get home tonight. I been using a glue i got from Hobby King, i just recall what its called. Sent from my GT-I9300 using Tapatalk 2 |
05-13-2013, 05:23 PM | #193 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
My favorite is AKA brand tire glue. AKA Racing Premium CA Tire Glue [AKA38001] | Glue, Oil & Cleaners - A Main Hobbies |
05-13-2013, 05:39 PM | #194 |
Am pretty sure its this one Ronald. http://www.hobbyking.com/hobbyking/s...Glue_1_oz.html Sent from my GT-I9300 using Tapatalk 2 |
05-13-2013, 05:56 PM | #195 | |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Quote:
I did what Ben suggested and I did them in 3 places cause I have 3 piece wheels and I think they are going to hold perfectly fine... It was a pain though cause the glue I was using the top was like really fat... | |
05-14-2013, 02:16 PM | #196 |
Thanks guys, I got the glue on order ... and I will try the dab-method |
05-15-2013, 01:29 PM | #197 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
I just got those smw buggy wheels and I'm going to attempt my first glueing as well. I can only see myself making a mess! Ha! Thank you for bringing this up!!
05-16-2013, 12:35 PM | #198 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne |
05-18-2013, 02:32 PM | #199 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne The glue got in today and I finished up the tires, the first wheel I over glued a bit and needed some clean up work afterwards . Luckily my skills improved rapidly all other 3 are much better … I used the glue OzBruiser linked above and applied 5 dabs to each beadring. Past few days I cleared my “to do list”, I added the spacers to the shocks and changed the rear chassis mount position one hole back. The body got a final trim on the front fenders, hood and sides. I was able to lower the body bit … All she needs now is electronics … weights: |
05-18-2013, 02:50 PM | #200 |
Looks great Ronald. Nice weight. Betyour looking forward to driving this now. Sent from my GT-I9300 using Tapatalk 2 |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
