07-06-2013, 02:01 PM | #221 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Some more shots on another line … |
07-06-2013, 02:04 PM | #222 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
this is very hot !!!!!Ronald good rocks nice weather en a lot of fun there in Spaarnwoude,i sent monday the SSS-R to you Jan (SuDo Clan Holland) |
07-06-2013, 02:11 PM | #223 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Cool thanks Jan Some insane sidehilling … Drove it in of the ledge behind, she would cling on just fine but I couldn’t stick this and drive out … there is a small ledge, I think it can be done ... next time I will try again ... lol This ended up taking a nasty fall, no damage luckily |
07-06-2013, 02:14 PM | #224 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Last set pics off today's crawling … I always like a good downhill run … And some oversight pics of my favorite crawl spot, it is about a half hour drive away. It is not real rock but as the Netherlands is not famous for rock I feel real lucky to have this … |
07-06-2013, 11:58 PM | #225 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Well Ronald, We have to drive someday soon over there!!! One downside of driving there is: NO CHARGING!!! It looks better then thought |
07-07-2013, 06:19 AM | #226 |
Get more batteries I got 8 small 450 packs, used 4 yesterday but spend a lot of time waiting on the stock AX10 Driving is great .... both moa and shafty ... you will like it for sure |
07-07-2013, 06:56 AM | #227 |
Rock Stacker Join Date: Mar 2013 Location: UK
It may not be natural rocks you have there but it still looks like a great playground. Congratulations on the build and getting it on the rocks. I would not have the patience
07-23-2013, 05:39 PM | #228 |
Rock Stacker Join Date: Mar 2013 Location: Amsterdam
Well hello there ! I'm just getting into crawling, Amsterdam based... Where would this pretty site be located if I may ask ? |
07-24-2013, 10:21 AM | #229 |
It is located in recreational park "Spaarnwoude". If you look in google maps for "snowplanet velsen-zuid" you will get the right location |
08-12-2013, 02:05 PM | #230 |
All is going well with the SuDu, no problems at all .... MAN, I LOVE THIS RIG !! The chassis and linksetup is really awesome and drives very well, to be honest she is by far my favorite rig right now I got the same exciting feeling about this rig as when I first stepped up from shafty to moa ... Minor tech update: The loaner servo will return to my partsrig, now installed is a new 7950. Stepping up the game a little bit by adding 6 kg/cm of force to the steering Now to get a new RX to so I can use my 4PL ... |
08-22-2013, 03:13 PM | #231 |
Another minor update ... I just finished installing a smaller E-tray I received from Tomy this week . The smaller one I drew up is about 20 mm shorter then the stock NCD E-tray to better suit my layout. Useable mounting surface is retangular 36 x 45 mm ... after placing the electronics back I noticed it could have been even shorter Last edited by Haastnooit; 09-18-2013 at 01:04 PM. Reason: added pic |
08-23-2013, 09:10 AM | #232 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
Truck looks like it works real nice in the pics. My ringer is setup very similar but i will be changing the front driveshaft to mip. I bet over the last month, I have snapped atleast a half a dozen front wildboar driveshafts. I dont get any twisting before snapping either, it just snaps clean in an instant, and always while upside down. This has been a very well thought out build thread with a lot of good information and pics. Thanks for taking the time to post it all and hope to see some running video.
08-23-2013, 09:41 AM | #233 |
Rock Crawler Join Date: May 2011 Location: SoCal
Your driveshaft failures, have they been in the splined section of the male half? Many of us have epoxied aluminum or carbon tubes or rods inside that section to beef them. Would that have helped in your case?
08-24-2013, 07:36 AM | #234 |
Nice design Ronald,Tomi send 1 to me Jan |
08-24-2013, 08:33 AM | #235 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Yes, the splined section. I thought about trying that driveshaft mod but with the severity of the instant breakage, I just dont trust it.
08-24-2013, 04:21 PM | #236 | |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Quote:
Does NCD have a site, or is there any site I can check the products they're offering ? | |
08-25-2013, 12:58 AM | #237 |
NCD does not have site. Just pm tomy over here on rcc. Verstuurd van mijn HTC One X met Tapatalk |
09-03-2013, 02:12 PM | #238 |
Minor update again ... Went crawling last saturday at the location shown in the pics above, it was the rematch for my buddys rig which is now a BWD SSS-R. He was really stoked after finding out his rig could follow mine on much more climbs as before ... Way more fun he said ... Now I am starting to tease him with the lack off steering on his stock axles ... I ran six 450 packs this time, because I did not bring more. Running out off juice ended the crawling, next time I bring all eight with me. Still no single issue with the SuDu, though I popped the right upperlink off the ball at the axlemount. During cleanup I noticed some tire damage. In the shaving proces of the tires I cut the big lugs with lexan scissors first. I made one cut to deep and had to glue a piece back in. It was the front tire and on the inside as well. Rubbing of the tire was loosening the edges off the glued in piece. I had to change it to the rear and reglue the edges. While switching foams and hubs front to rear I decided to change to a narrower setup, wheels are now .8" wide. |
09-04-2013, 12:21 PM | #239 |
Pic of the damaged and repaired tire ... |
09-13-2013, 03:06 PM | #240 |
I got a small update planned for my SuDu which will shed some weight for sure. I will probably add the weight to the knuckles cause I like the weight as is right now. Current RTR weight 1704 gram. During the build I collected some parts I did not install yet, I still have two shiny new Grip-lok V1 spools and a whole bunch aluminium revo balls ... AND ... I was able to order a new RX for the 4PL so I will redo my electronics as well |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
