10-26-2013, 08:17 AM | #281 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne
I see a narrowed shock mount and more upper shock attachment points. At the cost of some additional pieces and probably a minor weight gain. What performance advantages are you going after? Did you perhaps stand the shocks up a little? It looks like there's some extra clearance above the motor. Could the upper structure be lowered for a little CG improvement? Or are you out of room on the spur gear? |
10-26-2013, 01:18 PM | #282 | |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Quote:
Weight on the OG Sudu1 is about 54 grams with all steel hardware. Weight of the SuDu1 FL prototype is about 69 gram with all steel hardware, using thicker 2.0 mm CF and the extra chassis spacers. When using all aluminium hardware (not for the lowerlinks) the weight will drop to about 62 gram. Very competetive weight I would say … As mentioned before shock and link positions are identical to the OG SuDu as to Tomi’s request. However the position of the front mounting point of the sidebraces is moved up about 4 mm in order to get rid off the machined delrin chassis spacer for slipper users. The sidebraces therefore are about 4mm taller then the OG SuDu at the front mounting point and equal in height at the rear mounting point of the sidebraces. The space above the motor has increased the same amount in front as well and is also equal in height at the back of the chassis. Lowering the small area of the chassis that’s is taller then the OG design will not bring a noticable CG improvement and would disturb the fluent chassis top line we wanted. | |
10-26-2013, 02:06 PM | #283 |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL
Thank you Ronald for doing such a great job on the Sudu FL. Both Douwe and I have been working on and off during the autumn on drawing a new fresh looking chassis around the original Sudu One geometry. We never got to a point where we were truly satisfied with what we had drawn up. Having seen some of Ronalds work on his custom parts I figured why not ask him to have a go at it. Luckily Ronald was interested and it did not take long before he presented 4-5 sligthly different options and we decided on this one. We did not want to do any dramtic changes to the geometry as the Sudu One chassis has proved to be a very good performer. Weight has increased some. But we are still looking at one of the ligthest 2.2s chassis's on the market. I believe only the original Sudu One is lighter if compared to other popular chassis out there. Increase in stiffness is dramatic! I have always been a fan of simple and straightforward designs. It took me a while to say yes to the triple sheer rear end of the FL. Going double sheer would save a few screws and spacers and thus weight but we would loose some of the added rigidity. So here it is - a new fresh looking, clean design Sudu One FL. Last edited by Tomy; 10-26-2013 at 02:21 PM. |
10-26-2013, 02:08 PM | #284 |
Rock Stacker Join Date: Aug 2011 Location: Milan, Italy
Long time no see, bad times behind and ahead too, but getting back and seeing those updates is heart warming. Best compliments, the new chassis looks great!
10-26-2013, 04:10 PM | #285 |
Rock Stacker Join Date: Mar 2013 Location: UK
FL? Flipping lovely! I think I may have seen what santa's bringing me - my good lady has asked me to think what I want for chrimbo, I'm thinking I may have found it |
10-30-2013, 02:13 PM | #286 |
Thanks guys Apreciate it. Here are some more pics of the new SuDu1 FL chassis. Tomy is waiting for some new CF to arrive to NCD headquarters to be able to make the first serie for testing. Hope to have it here soon … |
11-16-2013, 04:12 AM | #287 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL Well due to some snags in CF delivery things got delayed for a few weeks. Tomy’s regular supplier changed the fabrication method on the CF they make. Resulting in a more brittle CF, less suited for use as chassis material. So we needed to look elsewhere to find a new CF supplier that could deliver the CF in the quality we like. Looks like we found a good alternative for now, Tomy is still working to get the original supplier to make sheets the old way for our purpose of usage. I really hope he will get them convinced as the old CF quality, strength, cost ratio was absolute second to none. Though the new CF is a real close comparism . From the sample materials Tomy was able to make 3 FL chassis’ which will ship to team members this weekend … Some fresh pics to hold you over to next week … |
11-16-2013, 12:58 PM | #288 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
These look beautiful Ronald. I'm lucky enough to have the V1 and the design fit and finish are impeccable. I'm sure this will be a smash hit!
11-16-2013, 01:55 PM | #289 |
Thanks David The Xciter you did for me will look good on this one |
11-16-2013, 04:01 PM | #290 |
Attention all SuDu drivers .... check the Sudu vendor thread for interesting news |
11-16-2013, 09:11 PM | #291 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
jusy read it that is great news being that i just purchased a sudu for my first shafty build..
11-17-2013, 01:39 AM | #292 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL |
11-24-2013, 02:29 PM | #293 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL I got a nice box of parts in on friday, other commitments kept me from getting on with it untill this afternoon. The box contained a nice stash of new parts ... the new SuDu1 FL chassis, delrin lower links, linkplates front & rear, glue-on wheels and my bigbore shocks. Contents Nordic Crawler Design SuDu1 FL kit: CF 2mm chassisplates: - base chassis (2 pc) - rearend plates (2 pc) - side braces (2 pc) Delrin skidplate, milled out Delrin chassis spacers: - 50 mm (2 pc), threaded - 40 mm (4 pc), threaded - 12 mm (2 pc) - 7 mm (4 pc) - 3 mm (4 pc) Black oxide M3 hardware - 25 mm (8 pc) - 20 mm (2 pc) - 12 mm (2 pc) - 10 mm (4 pc) When numbering the chassisspacers from the front to the back, assembly would be like: 1) 50 mm spacers + 10 mm screws 2) 50 + 7 mm spacers + 20 mm screws 3) 40 + 12 mm spacers + 25 mm screws 4) 40 + 7 + 3 mm spacers + 25 mm screws 5) 40 + 3 mm spacers + 12 mm screws 6) 40 mm spacers + 10 mm screws I changed the hardware on the nr. 1 and 6 spacer to attach and space out the bigbore shocks. I only had the #2660 left in my spare parts and to get them to work lengthwise they needed the shockcap mod. The shockbodys got a nice shave as well, thanks Tomi for the nice work ! I managed to fully assemble the chassis, shocks, links and mate her up with the axles I already prepared. No tranny yet …. I hope to have the new NCD lightweight tranny here soon … Some pics … Last edited by Haastnooit; 11-25-2013 at 11:20 AM. Reason: added the skidplate to the contents ;-) |
11-24-2013, 02:47 PM | #294 |
Superclean as always, Ronald!
11-24-2013, 02:58 PM | #295 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
...exact list and beautiful pictures...looking forward what's going on, Ronald
11-24-2013, 03:08 PM | #296 |
Thanks guys Apreciate the good words I will be "freestyling" this build a bit more as usual, as time will be limited the upcoming weeks. Besides most parts I allready have here ... just some crucial driveline parts are missing (wink wink Tomi ). I got back in the box and just finished the Queen V2.1 wheels and put a new set of shaved Sedona's on with old style DD foams in them. Pics to tell ... |
11-24-2013, 03:19 PM | #297 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Looking great. Sharp and clean as usual. :thumbup:
11-24-2013, 07:44 PM | #298 |
I agree! Ronald's threads are as good as they get. From the pics to the tech. I always look forward to the updates!
11-25-2013, 03:41 PM | #299 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL Thanks for the kind comments No major progress today … BUT … I settled on link and shock positions, I think this will be my starting point for the FL. Front uppers: chassis, middle hole Rear uppers: chassis, middle hole / linkmount, rear upper hole Front lowers: axle, inside between the tabs Rear lowers: axle, outside outside the tabs Front shocks: chassis, front hole / axle, outside between the tabs Rear shocks: chassis, top last hole / axle outboarded outside the tabs The shocks are spaced out from the chassisplates by 6mm at the front and 10mm at the rear. Currently build with Losi 30wt up front and 50wt in the rear and Losi mini-T pink springs all around. Now for some pics … |
11-25-2013, 10:32 PM | #300 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Looking good Ronald!. Wish you could come to one of the comps en compete with us one day. Sent from my HTC One X using Tapatalk |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
