12-22-2013, 03:08 AM | #361 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL
Anyone else noticed this before ... The XR10 uni's on my OG Sudu and the FL have different length threaded stub shafts. XR10 uni's on the FL, very long threaded part ... XR10 uni's on the OG Sudu, short threaded part ... |
12-22-2013, 05:49 AM | #362 |
I'm with ya Ronald. I noticed it back when I got new ones and after cutting them down on my wraith uni's, I just figured they use the same ends for both and the wraith uses longer ones for wider wheels and different wheel offsets and scale hubs that go on them?
12-24-2013, 04:48 AM | #363 |
Things did not go like I hoped, I made very slow progress the past few days. I got a lot of things keeping me busy and I have to divide my time between all ... Last night I got some time in on the FL and installed the NCD tranny in the chassis, just a matter of swapping the skidplate. Offcourse the whole thing fits like a glove and looks very well in there It is mounted in the back with the long shaft towards the front. Sadly no pics ... my daughter (4) and I decided to use my A0 background paper to do some freestyle painting on, earlier in the day I will share some pics later I planned on using MIP shafts as I have short+long driveshafts for a typical 60/40 setup with AX10 tranny in the spare parts. But that won't work, the front will fit, but seems to botttom out under full compression and the rear is too long and can't be used at all. The short front MIP will work in the rear though. I need new driveshafts and decided to try my luck with the SDI driveshafts ... following ZZR 1100 Racer on this one I lost a lot of time last night correcting one of the through holes in the RC4WD long driveshaft. You will have to drill them out to 2.5mm to fit the scrub-pin. Unfortunately one hole was offcenter and also misaligned, not straight through but with an angle. I got some AX10 stock shafts installed now for mock up, so I can proceed with electronics placement. I shortend the front 12 mm and the rear 10 mm. |
01-08-2014, 11:31 AM | #364 |
Today I am back to work after a nice vacation, now I can get some new paper to re-make my photocorner .... Hopefully back in the game tomorrow with a recap of past few weeks small progress ... |
01-08-2014, 04:17 PM | #365 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
Hi Ronald, Do you have Some tips for my new tranny? |
01-10-2014, 02:41 PM | #366 |
Assembly of the NCD tranny for the SuDu is very straight forward. Just two things to be aware of: 1) one of the hex spacers is .5mm longer and should be used at the top of the housing plate in the countersunk hole 2) shimming of the outputshaft. As the ring and gear are pressfit on the outputshaft there are differences in dimensions between sets. So you will have to find the best way for your set |
01-19-2014, 12:25 PM | #367 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
fritzthefly's titanupgraded shafts are ready to ship. You will get them the next days - i will ship them out tomorrow, Ronald!! |
01-19-2014, 05:34 PM | #368 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Hey Haastnooit....I went to NordicCrawlerDesign web site and cannot find any reference to the tranny you just built...I'd like to have one but cannot find any info on it.....can you help with this please? Thanks |
01-19-2014, 06:30 PM | #369 | |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
Cheers Rino Sent from my GT-I9505 using Tapatalk | |
01-19-2014, 08:12 PM | #370 | |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL Quote:
I hope you can include the Rc4wd gears in your package, I'd prefer a one stop shop. Thanks Rino...I'll be patient | |
01-20-2014, 03:01 AM | #371 |
RCC Addict Join Date: Oct 2008 Location: Finland
I have got a lot of feedback on the NCD transmssion from Rino and one other test driver based in Canada. I will soon post more information on the transmission and make it available for you. |
01-20-2014, 09:18 AM | #372 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL |
01-20-2014, 09:22 AM | #373 |
I hope to have the FL up and running by the end of this week. When the SDI driveshafts arrive I will finally have all the parts to finish the car . Look forward to the first tests after hearing about Rino's experiences with the NCD tranny ...
01-20-2014, 10:17 AM | #374 | |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
But maybe its to cold for you. Don't hope so. I hope I receive my tranny tomorrow, so I can mount it before the comp also... Verstuurd vanaf mijn EndeavorU met Tapatalk | |
01-20-2014, 02:02 PM | #375 |
| Re: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL For now, a little more detail here: NordicCrawlerDesign Transmission |
01-20-2014, 03:02 PM | #376 | |
01-20-2014, 04:34 PM | #377 | |
RCC Addict Join Date: Nov 2011 Location: the not so white north
Also want to thank Ronald even thou I haven't asked him anything this thread has been a huge help!!! Once all my pieces are here I will start a build thread. Keep up the good work NCD! | |
01-20-2014, 09:33 PM | #378 | |
Chassis, links, tranny, link mounts and servo/electronics tray....all for one low price..... I wonder if any of your testers have tried it on another skid besides NCD ??? | |
02-17-2014, 12:42 PM | #379 |
Well ... it has been a while since I updated my thread. Mainly because I kind off lost the motivation/reasoning to build/have a second 2.2s rig. So last week I decided to abort the build of the (almost done) new rig. Not a great update I know ... But now I can focus on my first love again, so I am not sad I allready sold the complete axles and offcourse I am keeping the FL chassis and NCD gearbox to swap over in a couple of weeks. First I will go out crawling again for a loooooong time |
02-17-2014, 12:53 PM | #380 |
Hey Ronald, serge and I decided to go to spaarnwoude soon. So maybe we can do some crawling together Verstuurd vanaf mijn EndeavorU met Tapatalk |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
