![]() | #61 |
RCC Addict Join Date: Jun 2009 Location: Australia
Looks great Ronald. I like your thinking. I have cf tube in the mail i baught last week. I ordered it locally interstate but it didnt arive before the Easter Public Holidays. I too am looking at doing similar but until my tube arives cant do much. Good clear write up too ![]() Sent from my GT-I9300 using Tapatalk 2 |
![]() | #62 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
Hi Ronald can you make a set for me Jan |
![]() | #63 |
Rock Crawler ![]() Join Date: Jan 2011 Location: At home
| ![]() Let me first find out if they will hold, I don't like to make something for others not knowing if it will hold. I will be happy to make you some later ... ![]() Last edited by Haastnooit; 03-30-2013 at 09:45 AM. |
![]() | #64 |
| ![]() Not so much progress on the car this evening, but still creeping ahead. I checked out the CF links and they look and feel OK, the rodends are secure … I did some minor testing with hands only though. Confident enough to mount them, so that was done … ![]() ![]() Weighed the links first offcourse … together with the delrin links, all links come together at a weight of 61 grams. The chaotic Ti links on my XR come in at 94 grams, both with steel traxxas hollowballs … quite a difference ![]() Spend the most time tonight setting up a bigger “photocorner” to make it easier to get good pics of a fully build car. I made one to maximum the size of my current favorite spot, it is 25% bigger then my old one … It will do for now … tonights test shots: ![]() ![]() ![]() ![]() ![]() |
![]() | #65 |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
Hi, Nice build ![]() ![]() ![]() @+ |
![]() | #66 |
RCC Addict ![]() Join Date: Oct 2008 Location: Finland
Beautiful work on those upper links. A local guy, called R2 here on Rcc, did the exact same thing with his XR10 upper links. I think he said they could take a 30kg load lenghtwise before either rod end would break loose from the cf tube. |
![]() | #67 | |
| ![]() Thanks TotoRax ... Yes those CF links really make everything right ![]() ![]() Quote:
![]() The 30kg number got me thinking about making a CF draglink and tierod if needed .... same method but with a pin added. Also got some 5mm tube ... what do you guys think, can it work ? Or will the CF not withstand any contact with rocks ? Last edited by Haastnooit; 03-31-2013 at 08:25 AM. Reason: never heard of CF kinks before ... | |
![]() | #68 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Can you make me some in the future? send from my HTC One-X |
![]() | #69 |
![]() | #70 | |
Hi, Quote:
![]() Pic after tests of traction ![]() ![]() ![]() I use the same CF link on my crawling since more than one year and they resisted very well. They are always in place | |
![]() | #71 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Very nice work on the cf links.
![]() | #72 |
@ TotoRax: Those are the pics that convinced me in under 1 second .... ![]() @ 63comet: Thanks man ... ![]() |
![]() | #73 |
I wanna be Dave ![]() Join Date: Sep 2009 Location: Eastcoast CANADA
Very clean work ![]() Rob |
![]() | #74 |
| ![]() Thanks Rob … I will keep going at it …. ![]() I have been fondeling the chassis somewhat this afternoon, and watch how the links move when articulating. I noticed some minor flex in the rear 4-linkmount, it is caused by raising the little delrin pieces with the revo balls. To counter this I added a 28mm long aluminium spacer between the delrin pieces. It is made out of a old Axial aluminium link, so diameter is 6mm … de-anodized it offcourse ![]() ![]() That makes it feel waaaaaaay more rigid !! ![]() Tomy is working on some bigger delrin blocks with a added row of holes. Those will allow the screws to have more thread in the delrin pieces as to the current setup. And with the bigger footprint on the CF plate the taller pieces should be stable enough by it self … in case you need to …. you can always add the spacer ![]() Last edited by Haastnooit; 04-03-2013 at 12:31 PM. |
![]() | #75 |
What body are you going to use? Rob |
![]() | #76 |
I am going to run a Parma Xciter ...
![]() | #77 |
![]() | #78 |
Those are very cool ... I got 2 Xciters for this rig ![]() ![]() ![]() |
![]() | #79 |
Pebble Pounder Join Date: Jun 2009 Location: England
Loving this build, will be my bible when I get my SuDu, what lowers are you using on the scx shocks look different to mine?
![]() | #80 |
Thanks FesterUK ![]() For external limiters I like using the Traxxas bushing used to mount the bigbores on the Traxxas vehicles. They are stepped and therefore work very nice with JeepinDoug springcups ...length is 7.5mm. Here is a pic of the SCX10 shocks of my SA3.5 that shows them better ... ![]() |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
