04-01-2013, 08:14 PM | #81 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne
A really impressive build so far I have been running Carbon upper links on my Berg for a long time now and they have held up great I look forward to seeing your rig on the rocks.
04-03-2013, 02:57 AM | #82 |
Pebble Pounder Join Date: Jun 2009 Location: England
Tanks for the info I have a spare set of SCX shocks laying around, might have a play around see if i can get them working nice |
04-03-2013, 07:52 AM | #83 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Very Nice Build! Super clean!
04-03-2013, 01:31 PM | #84 |
Rock Crawler Join Date: Jan 2011 Location: At home
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Thanks guys … apreciate it . I made a little progress today, just finished up shaving the tires and got them mounted on to the rims. Specs, pics, chitchat below … Wheels and tires NCD CF glue-on wheels VP SLW hubs (725/850) HB Rovers (white dot) CI DD foams Mods: - tire shave When I was waiting for parts and my SuDuOne chassis, Tomy gave me a wheel template to fool around with. I spend several hours making designs to hopefully come up with a cool one for this build … My designs are more off a “traditional” type, nothing really fancy I would say … but it was fun to do, some example’s … Classic First and most simple design for use as traditional beadlock or glue-on wheel, V3 is more beefy and meant for a 3-ring beadlock. Stockcar Stockcar wheels are designed for a 3-ring beadlock only. For those who wonder what I mean with a "3-ring" beadlock, a explanation: The 3-ring beadlock design features a recessed center ring and 2 backrings to hold the tire, thus being able to use smaller VP hubs. Sportscar As mentioned before, V1 and V2 Sportscar wheel are meant for traditional beadlock or glue-on, V3 design is designed for a 3-ring beadlock wheel. And the one design I like the most, but I decided to try glue-on wheels for the first time, thus opted for the V2’s for this build . I like the idea that I will be running my own design wheels. The finish on the wheels is awesome, nice and clean cuts all around … thanks Tomy !! These are now my favorite wheels . Team NCD glue-on wheels are normally available with 2 different size of polyamid bars/standoffs, 20 or 25 mm long, making the wheel 0.8” or 1.0” wide. I got a extra set of used HB Rovers for my SA a couple months ago and decided to use those for this build. Before mounting them to the wheels, the sidewalls had a nice “get together” with my dremel … The tires are not glued yet, I only got the 20mm bars and like my wheels to be 1” wide, so I will change to some 25mm polyamid bars when I get them from Tomy (hurry, hurry ). The Rovers are stuffed with some oldskool DD foams, firm inner/soft outer up front and firm inner/medium outer out back. I probably have to get some of those closed cell foams one of these days to keep up with everybody else … for now I will go with what I know … Weights: Last edited by Haastnooit; 04-05-2013 at 05:08 PM. |
04-03-2013, 01:53 PM | #85 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
Nice wheels design Ronald i order next month wheels for my rig. i think the last design from Douwe or Ben i hope that this week my body ready is Jan (SuDoOne Clan Holland) |
04-03-2013, 02:01 PM | #86 |
RCC Addict Join Date: Jun 2009 Location: Australia
Great wheel write up Ronald. Dsigning wheels is very cool. I have really enjoyed it so far with the designs i have sent Tomy. I also love the fact i have my own design on my builds. I have a heap of sketches to finalise. But really like my current design. I tested my glue on's Monday after work and they worked great. Keep up the good work. My spacers as you asked are 1"/25mm. Intrestingly although i use the new clossed cell CI Foams now like many others i also have a selection of old style ci foams. I just shaved a set of rovers myself and used the old style 5.25" duel stage foams and they work very well. Sent from my GT-I9300 using Tapatalk 2 Last edited by Oz Bruiser; 04-03-2013 at 02:05 PM. |
04-03-2013, 02:26 PM | #87 | ||
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne Quote:
I beat you to it with the body, I received mine tonight .... Quote:
I like the Ole Double D's, I believe I got them im all tires accept the BC's | ||
04-03-2013, 02:35 PM | #88 |
i spoke the guy who paint my body, he said this weekend is the body ready and i post than the pictures here and i send the pictures toe you |
04-03-2013, 03:13 PM | #89 |
Cool ... Hope my driveshafts get here soon so I can start thinking about how to place the electronics and set the body as low as possible [edit] And I have get other rear springs .... they don't get a long well with the body Probably switch them to the MRC springs ... Last edited by Haastnooit; 04-03-2013 at 03:17 PM. |
04-03-2013, 03:28 PM | #90 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Great job on the wheels! The tires look tall but i like it.
04-03-2013, 03:39 PM | #91 |
I did mention they were "stuffed" with foams I got these tires used, they came with 5.5 DD foams ... so that is what is in them. Tireheight in front is 133mm, the rear is 137mm with the harder foams ... |
04-03-2013, 11:02 PM | #92 |
RCC Addict Join Date: Oct 2008 Location: Finland
Your 25mm wide spacers shipped on Tuesday together with the updated delrin blocks for your rear 4-link mount. |
04-04-2013, 09:40 AM | #93 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne |
04-04-2013, 10:01 AM | #94 |
04-04-2013, 04:20 PM | #95 |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne You can say that again ... I think it could be a record So after receiving some parts traveling at the speed of light from Tomi earlier today I did some work on the car tonight. I updated the rear 4-link mount with the taller delrin blocks replacing the Oz balls on my current setup On the leftside the OG blocks that normally come with the optional rear 4-linkmount, in the center OG with a added row, and on the right a taller version with the top hole equal in height with my Old setup. The longer screw engagement in the taller blocks, and the bigger footprint make the linkmount much more rigid, as suspected the aluminium spacer is not needed But I left it in just for looks It matches quite nicely with the new aluminium chassis spacers I installed on the rig tonight. Those are part of the Gunnar Bodymount set I got to mount the body I replaced 4 delrin spacers for 5 aluminium ones details on the mount-kit will follow when I got the body mounted ... Also rebuild the wheels with the 25mm spacers to get the desired 1 wheelwidth, I did not glue them however. All the tireglue I have from my onroad days, have turned in to rock. So I have to swing by the LHS to get some new glue Below some pics to show off the new parts |
04-04-2013, 04:53 PM | #96 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Got a better pic of those new rear upper link mounts mounted?
04-04-2013, 06:14 PM | #97 |
The delrin link mounts look good. I didnt get the newer versions you got now originally so i had to improvise. I talked about it with Tomi but i think we both forgot lol . The mounts are a cleaner design than the balls i used. Might have to get some eventually as allows for more tuning options. Sent from my GT-I9300 using Tapatalk 2 |
04-05-2013, 12:20 PM | #98 | |
| Re: Haastnooit's AXR10 2.2s NCD SuDuOne I will get some close-up pics tonight ... Quote:
Nr. 4 is currently installed and equal to the height of your current setup. The difference in height from the bottom to the center of the holes on the even and uneven blocks are different by half the distance between two rows of holes .... hope that was clear and you got what I mean to say I think nr. 5 and 6 are a bit on the tall side ... | |
04-05-2013, 12:48 PM | #99 |
Makes sense. Blocks look great. Well done. Ive already mentioned to Tomi. You have also inspired me to revisit a wheel design i wanted but we didbt try innitially with Tomi. It will be revealed when i have Keep up the good work Ronald Sent from my GT-I9300 using Tapatalk 2 |
04-05-2013, 01:17 PM | #100 |
Close-up pic of the rear linkmount ... Last edited by Haastnooit; 04-05-2013 at 05:10 PM. |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads | ||||
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
