Thread: Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL
Old 04-05-2013, 01:32 PM   #101
Those are looking great Ronald. I also need a pair of these.
Do I spot the new body....?
To bad you have to remove a bit of the rear to lower the body even more
send from my HTC One-X
douwe is offline   Reply With Quote
Old 04-05-2013, 01:46 PM   #102
Default Re: Haastnooit's AXR10 2.2s NCD SuDuOne
Yes ... it is the new body ... and you are right Douwe, the sponsorname is probably going to be cut off ... oops sorry ...
Haastnooit is online now   Reply With Quote
Old 04-05-2013, 01:59 PM   #103
E.Y. Designs
Cool thanks I see you have the new body Got a pic of the whole rig with the body mounted?
EverettY is offline   Reply With Quote
Old 04-05-2013, 02:17 PM   #104
Nope ... I have not mounted the body yet ...
I am still undecided on how to place electronics, after I got that one figured out I will mount the body ... I can get good progress when my driveshafts get here, I am hoping to lower the E-tray somewhat.
But I got pics of the uncut body just sitting on the rig though ....
Old 04-06-2013, 01:52 PM   #105
Well …. EverettY’s question kept buzzing in my head …. And made me very curious how the body would sit on the rig. Eventually I couldn’t resist anymore and started work on trimming and mounting the body this afternoon … Specs, pics, chitchat below …
Warning extremely pic heavy !!
The body
Parma Xciter
RockThrasher paint
Gunnar bodymount set
HPI washer M3x6x0.5 mm
I hit up RockTrasher here on the board to paint me up a sweet body for this build … and he really came trough with this one … It is based on a lid he did before, which I really liked ... So it is the same concept, but a little different, I love the pink flames, chrome skulls and carbon look … This is by far the sweetest body I ever owned … Thanks Jason !!
I always hated those little pins that are normally used to mount a body, I saw the Gunnar bodymounts in severall builds in the past but never could find them for sale. Untill recently Gunnar started to offer them for sale again, I immediately jumped at them and got a #3 comp kit with 3/16” aluminium spacers.
I ordered 3 extra spacers to replace all stock delrin chassis spacers. As to Gunnar’s advice I ordered the spacers 1mm shorter (=49mm) and use some 0.5mm washers between the spacers and CF chassisplates. Here some pics of the bodymounts on the rig …
And finally pics of the body mounted on the car, I did not shorten the mounts yet as bodyheight may have to be altered due to electronics placement ….
Weights:
I always wondered what a painted body weighs, now I finally know … now I am curious how that compares to a cab and full set of bodypanels … ?
Old 04-06-2013, 04:31 PM   #106
E.Y. Designs
Very nice I love that cut on the XCiter body... Did you keep the NCD Logo part though?
Old 04-06-2013, 06:35 PM   #107
Very nice body and weight Ronald. Looks to good to scratch
At that weight you still need to add electrics and a battery and knuckle weights if required when a runner too dont you?
I still have to swap out my delerin cross braces to alloy myself.
Rig is looking great
Oz Bruiser is offline   Reply With Quote
Old 04-07-2013, 12:40 AM   #108
Tomy is offline   Reply With Quote
Old 04-07-2013, 01:00 AM   #109
Thanks Everett, I am sorry to say .... I lost it ... I cut the body a little bit at a time, tried to save the NCD logo but couldn't make it work
Thanks Oz, yes still need to add electronics (+60gr), servo (+65gr), lipo (+46gr), driveshafts (+30gr) and KW (+100gr) ... So I guestimate she will end up at a RTR weight of in around 1711gram ...
Originally Posted by Tomy View Post
Thanks You like ....
Old 04-07-2013, 01:16 AM   #110
Nice body Ronald , and nice pictures as well,the pictures of my body i place it
toninght
Jan
vovo is offline   Reply With Quote
Old 04-07-2013, 01:21 AM   #111
Yes, me like.
I am not a flames and skulls fan but I do appreciate such a clean and detailed painting job. Very impressive!
Old 04-07-2013, 01:33 AM   #112
So nice. So +@%$%&! Nice
Old 04-07-2013, 08:35 AM   #113
toninght
Jan
Thanks Jan ... Are you going to make a thread about your SuDu ? Would be cool .....
Yes, me like.
I understand what you are saying, all bodys I ever made/had for my onroads, offroads or crawlers always had a very simple and clean paintjob (kinda like my SA) which is more or less my trademark ... Never so extravagant as this one .... BUT .... I like it .... perhaps I am changing
Thanks ... glad you like it
Old 04-07-2013, 08:58 AM   #114
Cleanest build i've seen in a while, very very nice Ronald, made any choices on the elec. department yet?
crawl rookie is offline   Reply With Quote
Old 04-07-2013, 10:36 AM   #115
Truck looks great.
63comet is offline   Reply With Quote
Old 04-07-2013, 12:41 PM   #116
Thanks guys, apreciate it All electronics are allready taken care off, I will use all spares that I have. The servo will probably be a "loaner" though ... I could use one more good servo ...
[edit] No progress on placement if that is what you meant ...
Old 04-08-2013, 07:48 AM   #117
Was never a fan of the Parma xciter, I think I may have changed my mind looks fantastic
FesterUK is offline   Reply With Quote
Old 04-09-2013, 03:33 AM   #118
Hey nice build very informational I was wondering where do you get the brass threaded inserts?
laxjj14 is offline   Reply With Quote
Old 04-09-2013, 04:13 AM   #119
Here are a few sources for you:
Brass Inserts - Tonys Screws LLC
m3 brass insert | eBay
Old 04-09-2013, 09:22 AM   #120
Thanks, as I am in europe I got the brass inserts (F4/1-B-M3) from Insertsdirect.com on ebay ...
But most common place in US to get them would probably be Mcmaster-Carr ...
Second link leads to where I got mine ....
Tags
axr10 axle, sudu, suduone, xr10 mod
Haastnooit's AXR10 2.2s NCD SuDu1 / SuDu1 FL - Similar Threads
Haastnooit's YTC Secret Agent 3.5 Haastnooit Axial XR10 85 04-24-2022 12:04 PM
Team NCD Su Du One Oz Bruiser Axial AX-10 Scorpion 132 12-21-2013 04:34 PM
NCD SuDu one crawler douwe Videos! 2 11-28-2012 02:36 PM
Mini AXR10 Axles?... justinart24 Tools, and Procedures 6 10-15-2012 09:28 AM
Haastnooit's Old Skool YTC BJ4 Haastnooit Axial XR10 15 09-02-2012 06:57 AM
