Thread: AX10 Fastback II
Old 02-27-2013, 06:31 AM   #1
Default AX10 Fastback II
I bought a stock AX10 off a friend. I have tuned on it some to make a better crawler. Then I started looking for a chassis to upgrade too. And I found the Fastback II, I decided this would be a great platform to build off of.
This is how it was set before the chassis swap.
This picture shows the 4 link that I set up on it.
Justynkace is offline   Reply With Quote
Old 02-27-2013, 06:41 AM   #2
Talking Re: AX10 Fastback II
This was the last crawl I took it on before the new chassis was to be installed.
Here is a down hill shot on the same course. (This is my personnel rock course at my house)
Old 02-27-2013, 07:00 AM   #3
Default Re: AX10 Fastback II
Here is the build as of last night. I still need to do a good set-up. I just got it together and put it on the shelf till I can tune this thing. I need longer upper front links, I still need to put my new rear 4 link plate on to clock the rear axle, and make a new set of links for the lower rear links. I will try to find time tonight to get a couple links made. I am going for about 2" from the ground to the skid. So far so good. I really like how this chassis shows off the dig unit.
Old 02-27-2013, 07:11 AM   #4
There is something missing here. What happened to your shock mount crossmember?
daddy_ja is offline   Reply With Quote
Old 02-27-2013, 07:27 AM   #5
I am going to make one out of aluminum and not use the delrin cross member. Like I said I just got it together last night. It is far from being finished. This is just a starting point.
Old 02-27-2013, 07:43 AM   #6
but one from alu comes in the package.the esc doesn't look to good there,and u should get a servo/battery plate froms STRC,Vanquish or other producers,and yes....those plastic links looks horible.nice rig though,also have a FastbackII that i called "Punisher"
Kitty is offline   Reply With Quote
Old 02-27-2013, 08:43 AM   #7
My kit didn't come with a alu or any thing for the shocks. and I plan on getting the battery on the front axle. And I am going to get a Holmes BR-XL with a 35 or 45 turn motor. The ESC on it now was just to drive it around my house. Yea tonight I plan on replacing some of the links(The plastic must go). I just threw what I had together to get a idea what I needed to do to improve on. This rig is far from done, just give it time. After I get a set of links on it I like, I will post the length of the links for a starting point for other to go by.
Old 02-27-2013, 02:27 PM   #8
If your kit didn't come with it, email Juan.
Old 02-27-2013, 11:31 PM   #9
yes,got idea,give a mail to UGC to tell that,maybe they will sent u one
Old 02-28-2013, 04:56 AM   #10
Juan has one on the way for me. He sent it yesterday for me.
Old 02-28-2013, 07:12 AM   #11
That's great. You are going to love it! Extremely capable comp shafty chassis!
99xjlove is offline   Reply With Quote
Old 02-28-2013, 08:23 AM   #12
Proverbial threadkiller
Trubble's Avatar
Originally Posted by Justynkace View Post
.....I will post the length of the links for a starting point for other to go by.
Originally Posted by DickyT View Post
5/16 delrin lowers, 1/4 aluminum front, delrin rear uppers. Front lowers are 4 1/4 eye to eye, rears are 5 1/16.
Trubble is offline   Reply With Quote
Old 02-28-2013, 11:18 AM   #13
Originally Posted by Trubble View Post
My links are going to be a little different lengths. That is the size I started with, but I going for a little different wheel base then DickT done.
Old 03-06-2013, 10:38 AM   #14
I got my front shock brace in. And it is now on the crawler. I will post pic's of it tomorrow.
Old 05-25-2013, 06:06 PM   #15
Updates? link lengths? Pics? Considering ordering this chassis, my only issue is links. I'm no engineer, so any help would be appreciated.
jollyjeeper is offline   Reply With Quote
AX10 Fastback II - Similar Threads
My AX10 build: Stock to Fastback II paul6ppca Axial AX-10 Scorpion 26 09-12-2011 06:44 AM
