03-04-2013, 09:45 AM | #21 | |
RCC Addict Join Date: Jan 2009 Location: O.C
| Re: ** Paystin's "El Nino 3" sporty build Quote:
It's Spainglish, he's from the "hood" ya know! | |
03-04-2013, 12:35 PM | #22 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
Looking good buddy I'm hoping to have my sporty done by Friday morning |
03-04-2013, 03:16 PM | #23 |
Rock Stacker Join Date: Feb 2012 Location: Modesto
Haha yea I forgot your not Marc. Haha well good luck to the both of you and see you have an advantage of already living here in Cali you should do great! Best of luck -Steven |
03-04-2013, 08:42 PM | #24 |
I hope you don't mind but I got another question Sorry but I'm trying to get every thing I need for the rebuild when I get this chassi So I was woundering how you like the sidewinder and is it true it does not have a drag brake?? Thanks and what foams are you runing ? Thanks for all your help I hope you don't mind all the questions thank you very much! -Steven |
03-04-2013, 10:38 PM | #25 |
No worries. The Sidewinder ESC has a good drag break. You need the Castle link to program it up to 213% crawler break but it works just fine. I have a Holmes Hobbies BRXL that I will install after the comp along with another 35T motor. I just ran out of time so I installed the setup from my Honcho to get it running. With the limited testing I have done so far, the setup works but the motor lacks a little bit of torque. I am running Crawler Innovations closed cell foams in the front (5.5" soft outers) and stock Rover foams in the rears. So far so good with this setup. |
03-04-2013, 11:06 PM | #26 |
Ok cool thanks very much the info is extreamly help full I may have some other questions I really hope you don't mind thanks very much for all the pass help and in the future thanks-steven
03-05-2013, 01:41 PM | #27 |
Rock Crawler Join Date: Jan 2011 Location: At home
Looks great Just curious ... is the body sitting at it's lowest possible ?
03-05-2013, 06:59 PM | #28 |
| Re: ** Paystin's "El Nino 3" sporty build I was waiting for someone to say something about the body.. I have since lowered it almost another 3/8" from these pics by removing some of the spacers from the body mounts. I am happy with how it sits now while allowing room for the servo and battery to flex up when articulating. I'll have some better pics this weekend.
03-05-2013, 07:02 PM | #29 | |
I wanna be Dave Join Date: Oct 2007 Location: 801
I cheated and just mounted my body an inch or two back from center | |
03-05-2013, 09:36 PM | #30 |
You were just to lazy to make new holes. |
03-05-2013, 10:18 PM | #31 |
| Re: ** Paystin's "El Nino 3" sporty build Don't be giving away all my secrets!!! Now when I win this Friday the new fad will be to mount your body offset like I did because it helps with coefficient drag and the variable valve timing of the suspension ergonomics. Asshole! |
03-06-2013, 11:35 PM | #32 | |
And thanks for all your help chaotic! | |
03-11-2013, 06:57 AM | #33 |
Back from the West Coast shootout after a tireing weekend of "fun"! Unfortunately the weekend didn't turn out quite how I had hoped (from a results standpoint) but the event was a big success. Our resident photog Josie wasn't able to get around to take any action shots of my sporty before my day was cut short. After two good courses to start the day and on my way to third, this little snapolla ended my day. The front output shaft on the tranny sheared right off and took me out of the running. The truck was working really well up until that point and I was bummed that the day was over. Setup wise, I'm pretty close on it. I'm going to mess with the link placement just a bit and turn down the drag break slightly to help the rear settle a bit on decents. I do have to upgrade a few parts to try and avoid breakage again but other than that, I'm keeping it easy and fun with this one. I've never driven in snow before so that made the day a lot more interesting for sure. |
03-11-2013, 07:01 AM | #34 |
Bummer about the breakage, stock Axial outputs?
03-11-2013, 07:03 AM | #35 |
| Re: ** Paystin's "El Nino 3" sporty build |
03-11-2013, 07:05 AM | #36 |
RCC Addict Join Date: Nov 2008 Location: Frederick
03-11-2013, 07:06 AM | #37 |
03-11-2013, 07:16 AM | #38 | |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
03-11-2013, 09:10 AM | #40 |
** Paystin's "El Nino 3" sporty build - Similar Threads | ||||
Swezy207's sporty build "Buster" | swezy207 | Axial AX-10 Scorpion | 14 | 07-29-2013 01:08 AM |
Paystin's Chaotic "Switch" | paystin | Axial XR10 | 154 | 11-14-2012 05:54 PM |
Chaotic Crawlers "One-off Nino" XR10 | nonstopboost | Axial XR10 | 17 | 09-09-2010 08:03 AM |
"Chaotic Crawlers" 2009 Comp Nino | Chaotic Crawlers | Losi Mini-Rock Crawler | 7 | 01-11-2009 10:11 PM |
