03-11-2013, 09:24 AM | #41 |
RCC Addict Join Date: Jan 2009 Location: O.C
| Re: ** Paystin's "El Nino 3" sporty build
Thanks for all of the replys guys. I'll look into them all and pick one up. It was good to meet you too Jeremy. Sorry our local Wal*Marts don't sell jackets but who needs one of those when it's snowing anyways? |
03-11-2013, 09:27 AM | #42 |
Haha! I did have some troubles with that store... |
04-08-2013, 11:45 PM | #43 |
Rock Stacker Join Date: Feb 2012 Location: Modesto
hows it going, anything new with the rig?? thanks-steven |
04-08-2013, 11:51 PM | #44 |
I was present for his awesomeness crawling it at the club. |
04-09-2013, 02:36 AM | #45 | ||
| Re: ** Paystin's "El Nino 3" sporty build Quote:
I did change the setup a bit and it wasn't necessarly for the better. I took about 2/3 of the weight out of the front and moved the links a bit along with the front shocks. I was getting a lot of front lift (torque twist) that I didn't have before. I am going back to the old shock/ link setup and try that with less weight up front to see how that goes. I'll get some pics up tomorrow of how it sits now. | ||
04-09-2013, 04:55 AM | #46 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Can you take those pics of it in yer living room...say around 7am this morning please. A shot of the couch would be AWESOME |
04-10-2013, 10:08 PM | #47 |
sounds good pictures would be great when you get the time thanks-steven |
04-11-2013, 08:57 PM | #48 |
Sorry for the delay on pics, been a less than stellar week on the home front. Here's a few of the current setup and some from the comp this past weekend. After the West Coast Shootout I took apart the front axle and remounted the Creation Fab axle tubes. My caster was way off and I wanted another screw or two per side to make me feel batter about holding together. It's much more solid and I'm not getting the "oversteering" of the knuckles I was before. The steering tie tod now acts as a stopper from allowing the knuckles to go to far in one directions I changed out the VP DHII wheels with four slugs in them for the old Nordic Crawlers knuckle weight system. Tomy originally made me two sets so I put one on my XR10 and now one on the sporty. I use VP rings that I already had and I just had to drill a couple of new holes to line them up with the weight holders. One full large, one full small and half of a large weight on the insdie of the knuckle. I wasn't as happy with how it stayed down at the comp on Saturday but I had also changed the front shock position (back one) and the links (raised the rear one hole). I am going back to the original setup (pictured above) and try the weight that's in there now. I'm still not sold on Boss Claws but I think the rears need a softer foam in them to get me more comfortable with them. I'll got through the extras I have and see what works. Last thing is I added the Robinson Racing output shaft/ gear to the tranny. I should have listened to smarter people and gone with the Crawler Innovations ones instead. The Robinson Racing one is really heavy and the set screws for the drive shafts do not like to stay engaged on the output. I'll either have to drill holes in them to fit an Axial through pin or get the CI ones instead. |
04-11-2013, 10:30 PM | #49 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Go CI big boy, hell I'd invest in the complete 32p set up comes with out drives, maxx shafts, 32p spur etc. it'll turn that drive train into a tank. Rig looks pretty.
04-11-2013, 10:34 PM | #50 |
Are the set screws backing out?
04-11-2013, 10:42 PM | #51 | |
The shafts are so hard that the set screw just doesn't bite hard enough into them. I might try to drill them out first but the CI's will get the call if that doesn't work. | |
04-11-2013, 11:20 PM | #52 | |
If you can't get hold of those Axial through pin, you can use a hpi Savage set screw pin for the drive shafts. It's what I used on Lisa's wraith. | |
04-12-2013, 01:21 AM | #53 |
Thanks Bryce! I'm going to try the drill thru this weekend and see how it goes. I'm hoping my super secret connection over at Axial still has some lying around. |
04-12-2013, 01:26 AM | #54 |
| Re: ** Paystin's "El Nino 3" sporty build |
04-12-2013, 01:44 AM | #55 |
04-12-2013, 02:35 AM | #56 |
Instead of set screws (which tend to have the bullet point tip) I like to use button head screws since they tip has a more square cut and you can typically crank down on them much harder with the bigger hex driver. Apparently some shrink wrap will help prevent them from backing out as well. I always get sketched out having to drill holes in small parts like that. I always fear it gonna go off center and just screw the part up. So I'd do my method until the CI goods arrive. |
04-12-2013, 04:49 AM | #57 | |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
I usually grind them down if they have the points. Nothing a dremel can't fix. But I do agree on the tiny hex holes, I hate those. I always feel like I'm going to round out the hole or my driver. | |
04-22-2013, 11:32 PM | #58 |
Hey great build as i mentioned before getting ready to build mine but can you tell me about your shocks bodys, oil , ect. thanks so much any updates??-steven |
04-23-2013, 07:49 AM | #59 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
Get this rig dialed yet? What's the hold up
04-23-2013, 12:08 PM | #60 | |
I can tell ya that his shocks are plastic bodied SCX10 shocks with either silver MRC springs all around or MRCs out back with silver Mini-T's up front...unless thats changed. Oil's probably around the 30-35w range. I recommend using the Axial bent link ends on the front shocks to help clearance the servo arm & 4-link plates but its not COMPLETELY necessary. Hope that helps. Im sure Chris will chime in when hes got the time but didn't want ya waiting in case he cant log on anytime soon. J.D. | |
** Paystin's "El Nino 3" sporty build - Similar Threads | ||||
Swezy207's sporty build "Buster" | swezy207 | Axial AX-10 Scorpion | 14 | 07-29-2013 01:08 AM |
Paystin's Chaotic "Switch" | paystin | Axial XR10 | 154 | 11-14-2012 05:54 PM |
Chaotic Crawlers "One-off Nino" XR10 | nonstopboost | Axial XR10 | 17 | 09-09-2010 08:03 AM |
"Chaotic Crawlers" 2009 Comp Nino | Chaotic Crawlers | Losi Mini-Rock Crawler | 7 | 01-11-2009 10:11 PM |
