11-20-2013, 07:35 PM | #21 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
Man ive been lazy with this thread well a small update since the 7th place at the nationals I've have been having a good run with a 1st and a 3rd at 2 of the last four comp with 2 non events , one was shut down by National Parks and wildlife saying we cant run rc cars at this location and the other was washed out by rain Sent from my GT-I9505 using Tapatalk |
12-04-2013, 05:45 PM | #22 |
| Ok small update part are starting to arrive Sent from my GT-I9505 using Tapatalk |
12-07-2013, 08:02 PM | #23 |
| Ok another pic of goodies r2 gears,pinions and long shaft Sent from my GT-I9505 using Tapatalk |
12-07-2013, 11:56 PM | #24 |
Pebble Pounder Join Date: Mar 2013 Location: Vancouver
| Re: RockMafia's SUDU Sporty biuld
Nice rig, I can't wait to try one of those chassis. What made you change bodies?
12-08-2013, 01:19 AM | #25 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: RockMafia's SUDU Sporty biuld |
12-08-2013, 12:25 PM | #26 | |
No reason for body change , I trimned the xciter body a little to far and it doesnt make spec ,so I messaged Michelle at Krawler konceptz about some skinz thus the hardline body Sent from my GT-I9505 using Tapatalk | |
12-09-2013, 01:11 AM | #27 |
Yes its here the NCD trans Thanks tomi the quality is awesome as usual now to start asembly pics to follow in the next few days Sent from my GT-I9505 using Tapatalk |
12-09-2013, 02:10 AM | #28 |
Ok got board so I have done a test assembly Sent from my GT-I9505 using Tapatalk |
12-09-2013, 02:13 AM | #29 |
Only small problem I have is the gear stick a little in a spot but will look into it in the next few days ive installed the long shaft and used aluminum screw Thats all now atay tuned for more soon Cheers Rino :cool: Sent from my GT-I9505 using Tapatalk |
12-10-2013, 12:00 AM | #30 |
A little more work today swaped the long shaft to short found the space was hitting like tomi said Installed a 0.5mm spacer at the top to fix problem And now its mounted to the skid A small amount of grease and now she runs smoothly Cheers Rino Sent from my GT-I9505 using Tapatalk |
12-10-2013, 01:22 AM | #31 |
RCC Addict Join Date: Oct 2008 Location: Finland
Thanks for the update, Rino. I assembled 3 transmissions last night and found out that the press fitted bushing on the long output shaft is 9.2mm in diamter as opposed to 8.25mm on the short output shafts. When I drew up the transmission I only had access to the shorter shaft. I will change the housing to accept the longer shafts as well. As for the needed shim, it unfortunately escaped me that the spacer will travel a little bit into the countersinking for the flat head screw. I want to keep the hole countersunk on both sides to allow users to mirror the transmission. I will think of a solution to this asap. Tomi PS. your shim on the bottom of the transmission is the wrong way around. Turn it upside down and rotate 180 degrees for an easier installation to your chassis. Last edited by Tomy; 12-10-2013 at 01:25 AM. |
12-10-2013, 01:39 AM | #32 |
This look better :sly: Sent from my GT-I9505 using Tapatalk |
12-10-2013, 02:48 AM | #33 |
Yes, thats better. |
12-10-2013, 05:56 PM | #34 |
Ok new motor has been chosen it will be a Holmes Hobbies puller flow 500 motor 35t weight 5.1 ounces (144g):sly: Sent from my GT-I9505 using Tapatalk |
12-10-2013, 07:13 PM | #35 |
RCC Addict Join Date: Jun 2009 Location: Australia
Great choice Rino. Good to see other quality HH motors in the rigs. Have you run the rig at all yet with the new gb installed with old elecs? Sent from my GT-I9300 using Tapatalk |
12-10-2013, 07:18 PM | #36 |
12-13-2013, 07:32 PM | #37 |
Hey guys aftet a little frustrating morning its together need some teaks derfently need to go long shaft on will get that fixed today see if I can get some drivetime tommmorw Sent from my GT-I9505 using Tapatalk |
12-27-2013, 06:59 PM | #38 |
Ive made my cf upper links I hope they came out ok Sent from my GT-I9505 using Tapatalk |
12-27-2013, 07:06 PM | #39 |
Rock Stacker Join Date: Dec 2013 Location: Fountain Inn
Looking good. Made me a couple extra sets today for mine. Hopefully I won't have to use them.
12-27-2013, 11:36 PM | #40 |
Hi guys changed the upper links and a little tidy up of the rig and it sits around 4 pounds which im happy with considering the gears arent drilled yet and still old motor is in and running a extra half brass ring on the front axles (tomi original brass rings so that equal to 2 rc bros rings ) Sent from my GT-I9505 using Tapatalk |
RockMafia's SUDU Sporty biuld - Similar Threads | ||||
RockMafia's FROG HAS SPLATTERED NOW FASTBACK II | RockMafia | Axial AX-10 Scorpion | 51 | 10-13-2011 04:10 PM |
RockMafia's Rhino-Bull Juice | RockMafia | RC4WD Bully | 50 | 07-17-2011 03:58 AM |
RockMafia's ax10 sportsman rig | RockMafia | Axial AX-10 Scorpion | 0 | 02-06-2011 08:59 PM |
My CXT biuld | budleyh | Large Scale Rigs | 7 | 02-06-2009 09:28 AM |
Another JK biuld | Shaun (yota) | 1.9 Scale Rigs | 3 | 09-15-2008 07:06 PM |
