08-27-2013, 07:19 AM | #61 |
Still tuning. Waiting on a bracket to Reduce front knuckle weight amount. Front shocks 5mm internal limit, no external limit Rear Shocks 5mm external limit, in internal limit Still working spring rates out back Had these Gray DE Racing wheels a while. Ill get a hub support if some kinda on there before too long. My black DE's have the KL Design CF hub supports. Reduced Gold Voodoos with 5.25" Crawler Innovations foams. 3.7oz with 725hub 4lbs 3oz Sent from my thumbs. |
08-27-2013, 08:57 AM | #62 |
I talked to KL the day I talked to you.. Lmk when ur ready for hub support. :thumbup::cool:
08-27-2013, 07:32 PM | #63 | |
Truck was doing some odd stuff on sidehills and some drop downs. Swapped out the rear springs for silver MRC's. much better. Fronts are sill silver MRC's. Hangar 9 arm already bent after 10 or so packs. Carter Fab & Machine wheel nuts. These ain't gunna come loose by theirselves. Run them on 2.2 scalers with good results. Sent from my thumbs. | |
08-28-2013, 10:08 PM | #64 |
done and ready!
08-29-2013, 07:37 AM | #65 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: Szczerba's 2.2s Villian
Cf is making the buggy wheel supports?? Sweet!!! Not that I want to give Troy my money but.... |
08-29-2013, 07:41 AM | #66 |
I'll take a set or two. |
08-29-2013, 07:59 AM | #67 | |
| Good deal. Just in time. Thanks for making these. Quote:
I have come to like the DE Racing wheels. Especially with some hub support. I have sold off all my comp beadlocks. Sent from my thumbs. | |
08-30-2013, 11:20 PM | #68 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Shane If you add a chassis cross brace where the front shocks mount, is it going to interfere with the electronics tray under full compression? Can't tell from your pics. |
08-31-2013, 10:50 AM | #69 | |
This is just how I have mine setup. There are several ways to do it so do just look at mine. Lol Sent from my thumbs. | |
08-31-2013, 12:10 PM | #70 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
So is that pic of 4.19 lbs going to be your final RTR weight or are you still messin' around with KW and such? Can we get a pic of your CG balance point? Is there anyway you could bend an offset in that H9 arm so the rod end could bolt up on the backside and be more directly under the splines? Might cut down the stress on the arm. |
08-31-2013, 02:44 PM | #71 | |
| Re: Szczerba's 2.2s Villian Quote:
I don't think I could put the drag link on the inside of the servo arm. I think it hits the servo. I plan on putting the GH arm back on. | |
10-13-2013, 07:59 PM | #72 |
Had a great time at Crawlapalooza #7. Thanks to sponsors, organizers, judges and staff. Courses were fun. A couple mental mistakes on the last course threw my scores for a loop. I ended up 3rd for the day and took home some sweet cash money in my pocket. Truck was working awesome! I did a little suspension tuning on it the night before and it seemed to make a big difference. Sent from my computer-phone. |
10-13-2013, 08:10 PM | #73 |
Great job Shane! Can't beat "getting paid" for what ya love to do.. |
10-13-2013, 08:19 PM | #74 | |
Knowing the Disney rocks and the way a shafty drivetrain pulls, I opted for the rover tire setup. CI 5.25" foams. Vanquish base knuckle weight on each front. Truck felt good. | |
10-15-2013, 02:18 PM | #75 |
A Crawlapalooza picture surfaced from RolandRockShop
10-17-2013, 05:38 PM | #76 |
A couple videos from RolandRockShop at Crawlapalooza #7. Rig was working good but the driver still needs some work. I ran rovers, which I have not ran in months on this rig. I was trying to slow crawl them like my Voodoo's. I think I need to go up a couple tooth counts on the pinions for those rollovers. Or don't roll over. http://www.youtube.com/watch?v=W7cq-RxXSoY http://www.youtube.com/watch?v=mWKDfhcctaA .... Last edited by Szczerba; 10-17-2013 at 05:54 PM. |
Szczerba's 2.2s Villian - Similar Threads | ||||
Rowdy's Team Y-town Villian | ROWDY RACING | Axial AX-10 Scorpion | 627 | 01-03-2017 04:30 PM |
Bc and kam2040 build a Villian | Bc Paints | Axial AX-10 Scorpion | 181 | 01-11-2014 04:14 PM |
traxxas villian IV | mudn_1 | Non Crawler RC's | 0 | 07-09-2012 07:53 AM |
Got A Traxxas Villian From A Junk Pile......... | Robb | Non Crawler RC's | 1 | 09-20-2008 10:45 PM |
