04-09-2014, 02:06 PM | #461 |
| Re: Dlux Sportsman build |
04-09-2014, 02:09 PM | #462 |
04-09-2014, 05:02 PM | #463 | |
| Re: Dlux Sportsman build Quote:
MOA style skid = 2 hex standoffs and a thin skid plate, no holes for mounting a transmission. However in this particular case, Erik is using his 7075 1 piece skid | |
04-09-2014, 08:18 PM | #464 |
Yeah, we are just talking about a skid that has the trans mounted to it vs one that does not.
04-09-2014, 09:57 PM | #465 |
Rock Crawler Join Date: Feb 2012 Location: OC
Nice work on this E. Makes me want to start 2.2s again. |
04-09-2014, 10:03 PM | #466 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Great job transferring over to the new chassis, looks awesome. |
04-18-2014, 07:58 PM | #467 |
I could tell that I didnt like this car being lightly loaded on the knuckle weight. I had to get more on but I didnt want as much as my 2.2 so I made a "budget" version. 6 .8oz total with this new setup including the now half cut brass knuckle. I have been driving it for a bit and I am loving it. If it had clod stall and dig, it would climb as good as my Berg, for sure. I also did 1.6oz of rear weight, way down low but I dont have pics right now, sorry. |
04-18-2014, 07:59 PM | #468 |
04-19-2014, 07:02 PM | #469 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
i like the CF slugs holders .. |
04-20-2014, 09:34 AM | #470 |
Thanks man! They seem to be perfect for a car that does not want to be super heavy or spend as much money as the brass is. |
06-19-2014, 01:59 PM | #471 |
Time for a bit of updating on this thing. Ever since I went to the Loaded dice weight setup I had to make some compromises to make everything work. First was a wider wheel to fit the weights inside. I actually like the wider wheel but the problem came when the tire would now rub the steering links. I was already running a NON zero ackerman and in order to fit the wider wheel/tire, I had to bring the steering arm holes in even further which made me realize that I like a true zero ackerman or really close to it. With the steering arms I had to make for this, it really hurt my steering and turning radius so, I put some hub spacers on, put the original arms back on, and now I am too wide and also dont have the ackerman I am looking for. So, I want to make some changes to get back to zero ackerman (or close to it) and I also want to be a bit narrower. I am shooting for 10.5" with Rovers. This front axle should turn out pretty cool and I am expecting it to be an even bigger deal in many other ways.... Big progress today. |
06-19-2014, 02:25 PM | #472 |
Thank goodness you have the right guy for the job working on it or it'll never work |
06-19-2014, 03:15 PM | #473 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
08-25-2014, 07:57 PM | #474 |
Been over two months. What's the hold up ❓‼️
08-25-2014, 08:13 PM | #475 |
Customer's, and being the Fastest dam shipper Evahh!!!
08-26-2014, 07:38 AM | #476 |
Rock Stacker Join Date: Mar 2014 Location: Portsmouth
such a nice build. looks great and congratz i just bought my first crawler and its a ax10 scorpion and i plan on converting it to a sportsman. any first timer advice other the get out the bank card Last edited by Jfannin; 08-26-2014 at 08:21 AM. |
08-26-2014, 09:27 AM | #477 |
| Re: Dlux Sportsman build Another company Axle has been 90% done for a long time. Just waiting on more parts that have been on serious back order. Its cool though, been working on other cool things that should be out soon (Sorry, MOA only). My advice would be to drive it and focus on durability rather than performance at first. In the beginning, you will be holding the car back and once your skill improve, then focus on performance as the car will most likely be holding you back. Above all, make sure you keep it fun, whatever that includes. |
08-26-2014, 05:22 PM | #478 |
02-11-2015, 08:46 AM | #479 |
| Re: Dlux Sportsman build Well... it’s been a long time coming. These axles have actually been done a really long time but I was waiting for parts to become available so I could make its big brother version. Check this thread for the big brother version: EighteenZero8 replacement axles |
02-11-2015, 08:47 AM | #480 |
First, I took the VP Currie center section and wanted to make some small changes. First the Currie center is a decent amount bigger than stock so I wanted to shave all I could off the bottom for better clearance. Stock 2.128" Shaved 1.978". Total of .150" off the bottom is pretty good! In fact, better than a stock AR60 housing! Next was the pinion bearing. Stock is 11mm, I went to 13mm. This is a must IMO to upgrade this for long bearing life and also so your gears will last. Last edited by Erik D_lux; 02-11-2015 at 08:57 AM. |
Dlux Sportsman build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
Dlux Wraith Build | Erik D_lux | Axial Wraith | 95 | 09-03-2012 11:09 PM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
