10-10-2013, 07:45 PM | #141 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Re: Dlux Sportsman build
Looks good man, are you just using regular ol pen springs in the shocks?
10-10-2013, 07:48 PM | #142 |
This car is getting a decent amount of steering. One of my biggest concerns of going to a Wraith axle was the wider mounts. I liked the Wraith mounts though since you can switch them up or down for a different ride height. I also liked how the shock was stacked on top of the link vs the AX10 that was side by side. The AX just seemed much harder to get around. With as much steering as I had, my tires were eating the link mounts pretty hard. As a really simple fix, I decided to put the links and shocks in board (front only) of the mounts. Even after doing that, my tires were still hard into the mounts so, I decided to move the furthest hole as close in as I possibly could and then I cut off the rest. Then some simple web trimming on the housing All done and actually a lot more clearance Thats about as much steering as I think I can pull out of this car. Hitting the link mounts in the back, hitting the diff cover in the front. |
10-10-2013, 07:53 PM | #143 |
| Re: Dlux Sportsman build Thanks! They were a bit more work than the standards for sure. No, I just dont have my springs yet. They will be mini t. |
10-10-2013, 08:12 PM | #144 |
Looking good mang. The drag link looks just as bent as the rear lowers. Is the servo gonna sit 86 style?
10-10-2013, 10:43 PM | #145 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Some of our original links were bent on multiple planes. I hated every second of it. Such a pain to replicate!!! I was wondering if you would have link Binding issues? I had the same issues with my ar60's during my original mockup. |
10-10-2013, 10:51 PM | #146 |
Newbie Join Date: Jul 2012 Location: Central Utah
Look at that steering! Wow! Do you think you can sneak your servo behind the axle and between your link like on your berg?
10-11-2013, 06:24 AM | #147 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Dlux Sportsman build |
10-11-2013, 07:04 AM | #148 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Nice build mate.. I love seeing something different from the norm and your always good for that |
10-11-2013, 08:22 AM | #149 | |||
| Re: Dlux Sportsman build Quote:
Thanks man! Its funny how people are constantly working on similar ideas and they just happen to surface at the same time. Its nice to see your build and how you did things very differently. | |||
10-11-2013, 08:38 AM | #150 |
Great minds think alike |
10-11-2013, 11:08 AM | #151 |
10-11-2013, 03:01 PM | #152 |
Rock Crawler Join Date: Feb 2013 Location: york
I noticed that the outside tire is steering further than the inside tire, I've noticed the same with my Ax60B axle and assumed it's due to the steering arms on the knuckles not being 0 ackerman. Do you plan on addressing this issue? The little bit I've driven my rig since the Ax60B mod it does seem to affect the steering a bit.
10-11-2013, 03:35 PM | #153 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
With as much steering as your getting are you worried about the wild oscillation with the speeding up and slowing down of the universal. Even on my sporty when I had crazy steering it would damn near feel like it was going to rip the front end clean off. I ended up going back to the cheapie Chinese kunckle and chubs because they just did not get that far. Kind of self limiting.
10-11-2013, 09:04 PM | #154 |
I wonder if having the universal joints rotated 90* from each other, would that oscillation cancel each other out a bit, or maybe in the same orientation allowing that oscillation to be timed in sync with each other.
10-11-2013, 10:03 PM | #155 |
10-12-2013, 12:12 AM | #156 |
| Re: Dlux Sportsman build Why would it not have an affect? If the shafts spin at the same speed, and the Nile at which the operate is the same, they would speed up and slow down at the same rate if aligned, and at opposing rates when the universal joints and aligned 90* from each other. The way I look at it, I believe you could at least get more predictable handling by understanding how the universal joint alignment affects things. Last edited by TSK; 10-12-2013 at 12:15 AM. |
10-12-2013, 08:42 AM | #157 | |||
I actually made my own bolt on arms for this project just to get the exact ackerman that I wanted. I wanted to milk the front axle for all that I could get so I adjusted the arms until both tires were at max at full throw. Quote:
Worse case, I dont like it and I can dial it back to where I do, like you did. Quote:
I dont notice the downsides while doing obstacles. I will take the great angles and bouncing and hopping as I think they are great tools. | |||
10-12-2013, 09:54 AM | #158 | |
10-13-2013, 07:32 PM | #159 |
Got some more significant and difficult work done, the driveshafts. I am loving the way they turned out both functionally and looks. I wanted an ultimate beefy shaft, tons of angle capability, relatively lightweight and most importantly, NO SLOP. I have used a couple different types of shafts in the past and it seemed like there was one trade off or another with each type. 76g for both, not too bad. |
10-13-2013, 08:18 PM | #160 |
No question of "where's the beef"
Dlux Sportsman build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
Dlux Wraith Build | Erik D_lux | Axial Wraith | 95 | 09-03-2012 11:09 PM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
