11-11-2013, 04:56 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
| Boxer Build 2014 Sporty
Found this new Boxer chassis in my mailbox the other day. The Boxer is ClassiCutCustoms stab at s 2.2 Shafty chassis. It's made of carbon fiber with a milled delrin skid. Comes with all the cross braces and stainless hardware you need. It's super trick and light. Really dig the milling on the skid. Thanks Barry you did a great job on this one. Chassis with the optional XR steering parts. Skid plate is drilled for an AX10 / SCX10 transmission. It is milled out for light weight. Lateral supports made to clear the stock Axial trans. More to come... Last edited by McTwist; 11-12-2013 at 12:25 PM. |
11-11-2013, 07:18 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: South East
Looking like a good start..... Come on now.... It's been more than 10 minutes...... Isn't that what you said in my thread last week? Hummmmm
11-12-2013, 06:58 AM | #3 |
Lots of progress last night. Photos shortly. Servo / upper link / electronics mounting plates. The servo / upper link plate comes with the holes to mount directly to the axle housing. There are three positions for the upper links to mount. You will need to drill your servo post mounting holes based on your needs. The electronics plate is separate so it is optional to use. If you use it you'll need to find the pacers that work best for your set up. I ended up used some 1/2" spacers I had in my tool box. Sent from my iPhone using Tapatalk Installed Chocker Collars front and rear, put some Mod Tubes in the rear. Mod Tubes and Chocker Collars sold separately. For Chocker Collar and Mod Tube install click here. Last edited by McTwist; 11-12-2013 at 12:39 PM. |
11-13-2013, 09:47 AM | #4 |
| Re: Boxer Build 2014 Sporty |
11-13-2013, 09:53 AM | #5 |
Looking good there fella.....
11-13-2013, 10:52 AM | #6 |
11-13-2013, 08:30 PM | #7 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Good amount of steering!!!
11-13-2013, 08:39 PM | #8 |
11-17-2013, 02:44 PM | #11 |
I ran the Boxer yesterday and I got to say is it rocks! No practice, no tuning prior to the comp just plugged in the batter a went and went it did. Took third for the day. The rig was worthy of first. A little tuning and it's going to be hard to beat. Sent from my iPhone using Tapatalk |
11-19-2013, 04:47 PM | #12 |
11-20-2013, 08:00 AM | #13 |
Guess I need to post up le parts. Chassis/suspension: CCC Boxer Axial scx10 shocks delrin pistons Alum. uppers Delrin lowers Axles: Front: Axial ax10 cases CCC Chocker Collars Axial OD gears Axial xr10 universals Creation Fab wide premium splined tubes Axial xr10 chubs HR Wraith knuckles CCC carbon arms CCC servo/battery mount and electronics tray Rear: Axial ax10 case shaved CCC Chocker Collars HR UD gears Axial XR long shafts HR lockouts Transmission: HR SCX10 32p #SCP38HT03 Billet machined aluminum case construction Super duty metallic slipper system (sucks) Heavy duty 32 pitch 61 teeth steel spur Extended out drive Steel internal gears Wheels/tires: VP DH and SLW .7 Rover white dot Electronics: 37t hand wound arm in some old can Axial A2 ESC bumped up to 3s HobbyKing Futaba rx CC BEC |
11-26-2013, 07:35 AM | #17 |
Bored are you?? Lol You should have a package full of Black Gold tomorrow night if USPS is still running to schedule.....
11-26-2013, 09:13 AM | #19 | |
| Quote: | |
11-26-2013, 12:16 PM | #20 |
Boxer Build 2014 Sporty - Similar Threads | ||||
ClassiCutCustoms 2014 Shafty build | ClassiCutCustoms | Axial AX-10 Scorpion | 247 | 05-12-2015 06:07 PM |
Bulldog Berg Build for 2014 | ClassiCutCustoms | EnRoute Berg | 165 | 07-04-2014 10:10 AM |
BOOSTED's 2014 build The 5th Dimension: MKII begins:pg 11 | boosted4lyf | EnRoute Berg | 239 | 10-10-2013 12:08 PM |
PhantomRS10's '13 Sporty build | PhantomRS10 | Axial AX-10 Scorpion | 12 | 03-20-2013 12:59 PM |
