11-12-2013, 04:45 AM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
| driveshaft issue
Hey guys, I set out to build a crawler and ended up with a sporty AX10 thing. SCX axles, SCX trans with HR dig unit. It has 4WS and I doubt it will ever see a real competition. Its built for fun. The issue I have is with the rear shaft. The HR dig unit really limits the diameter of the shaft I can use at the trans. I had a stock axial shaft in there and after a few bounces its destroyed. What is a good solid strong shaft that will fit here? I have a set of worn junfac shafts but I don't like them as they don't like to slide very well when under load and this DIG needs the shaft to slide easily. Any help would be appreciated Joe |
11-12-2013, 05:14 AM | #2 |
| Re: driveshaft issue
Well never mind on the driveshaft issue. I just seen that VP has their hurts shifters on sale for $69.99 shipped so I have one ordered. No black in stock so I went silver
11-12-2013, 08:39 AM | #3 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Anyway for strong drive shaft, MIP is unbeatable but they are heavy. Junfac is actually quite good except a bit of slop. Other than that, Maxx shaft is light and strong.
11-12-2013, 10:52 AM | #4 |
I have MIPS and junfacs and traxxas stuff but on the HR dig unit there isn't much room at all for anything much larger then a stock axial shaft. I don't really like the HR dig so I ordered the VP hurtz dig. I can run any shaft on that and it's a better unit from what I see.
driveshaft issue - Similar Threads | ||||
AX10 driveshaft ring issue | Philfy | Axial AX-10 Scorpion | 2 | 05-04-2012 01:58 AM |
Ugc fastback ....driveshaft issue | day215 | Axial AX-10 Scorpion | 15 | 12-26-2010 01:09 PM |
Driveshaft rings issue | DrtRacr440 | Axial AX-10 Scorpion | 9 | 08-19-2009 05:20 PM |
Driveshaft issue | Mav-1981 | General Crawlers | 10 | 05-16-2009 08:59 PM |
MIP Driveshaft and Axial Slipper Clutch Clearance Issue | kawika | Axial AX-10 Scorpion | 8 | 06-30-2008 07:56 AM |
