11-18-2013, 08:10 PM | #1 |
| Hittman's 2013/2014 Boxer Build
Here we go again.. Parts: Axles: Front: Axial ax10 cases Axial OD gears Axial xr10 universals Creation Fab wide premium splined tubes Vanquish xr10 chubs Vanquish xr10 knuckles CW 7075 steering arms Dlux xr base weight (cut down) HittmanFab boomerang front plate Rear: Axial ax10 case Axial UD gears Axial lockouts shaved EyeBallEngineering lw al. D-mount ClassisCutCustoms choker collars (rounded) Transmission: Axial ax10 case Axial lw motor plate Hot Racing al. Gears Lw middle shaft Axial hardened outputs (lightened) Duratrax 32p 60t spur Chassis/suspension: ClassisCutCustoms boxer chassis Misc. lw cross braces HittmanFab 7075 lowers HittmanFab 4mm rear uppers Misc front uppers (soon to be 4mm carbon) Rpm rod ends w/ lw traxxas balls Axial scx10 shocks Axial machined pistons Wheels/tires: Misc... Waiting on wheels and then I will be using narrowed silver Voodoos Electronics: Holmes lw 540 can with 13t crawlmaster arm and checkpoint endbell Holmes BR-mini Hitec 7980 Futaba 2106 rx Castle bec set at 7.2v Misc: 6 7/8" articulation 3" ground clearance at lower links/ 2.5" at middle of chassis (ride height) 3lbs 7.9oz rtr Boooooooooomerang Holmes esc and bec Battery Rear.. 11" Front 11 7/16" |
11-18-2013, 08:11 PM | #2 |
| Re: Hittman's 2013/2014 Boxer Build
So far the boxer is awesome. The geometry is set up very well. The rig walks lines the El Niņo used to struggle with. The knuckle weight seems perfect, and the lockout weight is nice to have. The quality of the carbon is top notch, and the machining is top notch. Everything fits together perfect and clears nicely. In the first comp the rig did good. On the second course my brass inserts pulled out of the rear axle.. Allowing the uppers to flop and the rear driveshaft to come out. I was able to make it through gate 8, but that still destroyed my day. I was still able to pull off a second place finish, which I am happy about. Our next comp is on the 8th of next month.. I am hoping to have new wheels, tires, front uppers, and a new body by then. I have a body on the way right now.. And I think the paint job I have in mind will look really good Last edited by Hittman; 11-18-2013 at 09:12 PM. |
11-18-2013, 08:18 PM | #3 |
RCC Addict Join Date: Aug 2013 Location: South East
Looking good.......
11-18-2013, 08:54 PM | #4 |
Quarry Creeper Join Date: Apr 2013 Location: The New Mexico
Nice design on the electronics plate.
11-18-2013, 09:12 PM | #5 |
Thank you gentlemen |
11-18-2013, 11:13 PM | #6 |
Looks killer. Except for those green uppers in the front. |
11-18-2013, 11:16 PM | #7 |
| Re: Hittman's 2013/2014 Boxer Build |
11-19-2013, 07:35 AM | #8 |
Been there.... |
11-19-2013, 07:53 AM | #9 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
its about time u put this up looks good man . I have the axle mount things to an do the move the shocks up that much. you have your shocks layed back way more than me in the front with a softer spring on there . I couldn't get the gc like that |
11-19-2013, 07:53 AM | #10 |
but im running a 50/50 set up as well
11-19-2013, 08:34 AM | #11 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
I like it, the problem is I have to compete against it. |
11-19-2013, 09:07 AM | #12 |
11-19-2013, 04:50 PM | #13 |
Quarry Creeper Join Date: Mar 2012 Location: Living on the edge
Looking good Hittman.
11-19-2013, 05:14 PM | #14 |
Where the video!?
11-20-2013, 12:09 PM | #15 | |
| Re: Hittman's 2013/2014 Boxer Build Quote:
Haha.. you have something new too. It will give you a much better chance. Gracias On the rocks... | |
11-22-2013, 05:02 PM | #16 |
RCC Addict Join Date: May 2013 Location: York, PA
Your track width numbers are blowing my mind. Your rig is so much wider than the conventional "standard". Any thoughts on your motivations, and results vs under 11". I loved the stability I had with 11"+ width, but felt I got hung up on the axle so often, it was not worth it. I've since narrowed it to 10-3/4"' roughly, and feel it crawls much better. I've got an open mind, however, and would like to hear your opinion. |
11-24-2013, 06:38 PM | #17 |
Since I destroyed my beater body last comp,, it was time for a new one. A bit different this time It looks much different in the sun. I will try and get a few pics this week. |
11-24-2013, 06:42 PM | #18 | |
Personally I like it, and my trigger finger is accustomed to getting the diff past stuff. | |
11-24-2013, 07:39 PM | #19 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Came together quick and looks great!
Hittman's 2013/2014 Boxer Build - Similar Threads | ||||
Boxer Build 2014 Sporty | McTwist | Axial AX-10 Scorpion | 54 | 10-13-2015 07:24 AM |
Hittman's SMASH Build | Hittman | Axial XR10 | 994 | 02-28-2015 09:21 AM |
Hittman's 2013/2014 Bulldog Pitbull | Hittman | Axial XR10 | 278 | 08-06-2014 03:45 PM |
bashin boxer build | bashin calfee | Axial AX-10 Scorpion | 54 | 03-15-2014 09:45 AM |
2013/2014 alrc #1 | BTF | Alabama | 60 | 11-14-2013 12:39 PM |
