Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: ZZR's Shafty...NCD's SuDu one FL
Old 12-26-2013, 04:06 AM   #61
Default Re: ZZR's Shafty...NCD's SuDu one FL
The pics from you and Ronald are top
Jan (SuDoClan Holland)
vovo is offline   Reply With Quote
Old 12-26-2013, 05:34 AM   #62
Check gear positions
Haastnooit is offline   Reply With Quote
Old 12-26-2013, 08:02 AM   #63
Stephan Hauser / # 7
ZZR 1100 Racer's Avatar
Originally Posted by Oz Bruiser View Post
Awsome pic's. Makes it look like a work of art.
Thx Ben
Originally Posted by Solitaire View Post
All these new shafty builds certainly have created a lot of renewed interest.
Would it not be advantageous to rotate the skid and get the tranny forward and the motor on the right side?
I choose that position to get a shorter stick at the rear to get more clearence to the rocks. If you look at the birds view from side you could see. Also i would like to have the more of weight of the motor in front. Also i could shorter motorcables.
I choose the motor position because i try to get the same(not really) weight on each side.
Leftside
-Servo about 75g
-most of the gearboxweight because the gears and shaft are on these side about 40g
Rightside
-motor about 130g
-aku about 45g
Not same but better than motor/servo at the same side
Originally Posted by Tomy View Post
Stephan, I am afraid your pics don't do justice to the NCD parts. You make them look much better than they really are.
The pics shows only the reality. The cam i use is only a i phone 4S - not a proficam
Thanks Jan...i also like Ronalds tread and pictures so much
...it was only a test if not so bad pictures could dim the sense
Thanks's Ronald - pictures are edited
Stephan
ZZR 1100 Racer is offline   Reply With Quote
Old 12-26-2013, 06:54 PM   #64
Have you chosen a motor yet Stephan ?
Sent from my GT-I9505 using Tapatalk
RockMafia is offline   Reply With Quote
Old 12-27-2013, 05:18 AM   #65
Hey Stephan,
I guess SM class will be as important than Pro class for 2014...
i hope this SuDu will run next big
I hope mine to
Nice rig, i like the way u take pics...
ps: what is that "box-less" esc ?
> ooops, sorry that looks like Mini BR ;)
True
truespace is offline   Reply With Quote
Old 12-27-2013, 01:39 PM   #66
Perhaps i will take on of my"old" holmes 500' Puller from my pro or something different which is one the way...we will see...
Originally Posted by truespace View Post
Hey Stephan,
I hope mine to
True
Hey my friend - yes, i think the same...2014 2.2S Class will be much more interesting
...and yes you will see this SuDu 1 FL at BIG for shure-hope your's too, Ludo
And you are right - it's holmes mini
Stephan
Old 12-27-2013, 02:50 PM   #67
hello stefan
sfaty nice pleasure to ride together
david511 is offline   Reply With Quote
Old 12-27-2013, 03:28 PM   #68
I also can't wait to drive with you and the other friends on the rocks again, David
Old 12-30-2013, 08:29 PM   #69
Originally Posted by ZZR 1100 Racer View Post
Today i could find time to take some pic's for you guys. Pic's from the new NCD custom transmission box will follow soon...
Shocks are still stolen from my pro rig, because i'm just waiting for my shock's with killercaps from RcBros.
i have to use the red spacers. Otherwise the steering link could push the upper carbonlinks
delrinlinks
4mm titanlinks which fritz made for me...after we finished we spoke about to change to a straight version in front. At rear they are fine.
Stephan
Guten tag Stephan,
great rig you're building there !!! One thing I wanna ask for a long time : where did you get those alu servo mounts ? any part number ? Thx
Emmanuel
CrawlrKing is offline   Reply With Quote
Old 12-30-2013, 08:32 PM   #70
E.Y. Designs
Originally Posted by CrawlrKing View Post
Guten tag Stephan,
Emmanuel
RCBros Servo mounts
RCBros ╗ RC Bros Aluminum Servo Posts
EverettY is offline   Reply With Quote
Old 12-31-2013, 08:41 AM   #71
I don't have anything to add other than, gorgeous build.
helhedded is offline   Reply With Quote
Old 01-01-2014, 05:28 PM   #72
@CrawlrKing - Bonsoir, mon seigneur. Ravi de vous rencontrer si vous le souhaitez.
@EverettY -
Thanks's man - i'm glad that also comp driver from the country of origin of rc-crawling like this
Happy new year to all of you
Stephan
Old 01-01-2014, 05:38 PM   #73
@EverettY -
Stephan
No matter the country of origin clean builds such as this will get respect by me. The German builds will always have a spot in my rc rock crawling heart, however. You guys really push the boundaries and have exceptional craftsmanship skills.
Thank you sir and a Happy New Year to you as well.
Old 01-02-2014, 07:00 AM   #74
Stephan
What is the length of the steering link? (eye to eye)
Lobie is offline   Reply With Quote
Old 01-02-2014, 12:22 PM   #75
It's 176mm from eye to eye using the original red VP Wraith Knuckelsarms.
Old 01-02-2014, 11:31 PM   #76
RcBros Hobbies
RcBro's Avatar
Thats a work of art!
RcBro is offline   Reply With Quote
Old 01-03-2014, 02:09 AM   #77
This is looking better everday
Old 01-05-2014, 06:54 PM   #78
@RcBro - Thanks Will!! Please remember that i'm still waiting for my RcBros shocks with the "killercaps"...first comp is comming soon...
@RockMafia - Thank you
Some weeks before i got some nice parts from Everett of EverettY Design...narrowed Vodoo's. I have to say that everett did a super clean job on them and you could believe that these words are really true!!!
I also got some nice new parts i will put into my SuDu one FL...shifts & slim shifts
I specially like that they run directly off the pin, allowing me to remove hexes and save even more weight. Also they will give me the chance to adjust the offset simply by adding or removing spacers.
The hubs have 6 holes tapped to #4-40 and 6 other holes drilled to 2.5mm, ready for a M3.
At the rear i will go with the slim version - in front i go with the normal version.
The shifts are very cool parts and worth every cent.
I also thought about to have a look at the plastic axial parts for the wraith to use at the rear. i think there is only one point to choose the plastic way...weight saving for every price, For the way i go i will choose the shifts, but i will test the plastic version also.
Stephan
Old 01-08-2014, 05:21 PM   #79
I could see the light...rocks are calling...
I cutted the shafts to fix them with the custom tranny...with the titanshaft i will left 4-5g
Here are my NCD wheels - inside 2.0mm - outside 1.5mm
Narrowed Voodoo's with 6.0 foams and wheel but without shift(102g)
...more will follow soon...
Stephan
Old 01-08-2014, 07:01 PM   #80
They the G3 Cyclones from NCD mate with the offset?
Sent from my GT-I9300 using Tapatalk
Oz Bruiser is offline   Reply With Quote
ZZR's Shafty...NCD's SuDu one FL - Similar Threads
ZZR's...now it's a REMEDY 3.5 ZZR 1100 Racer Axial XR10 322 08-25-2019 02:05 PM
Alex's SuDu 2.2s. AlexG Team Losi Comp Crawler 70 05-20-2014 02:20 PM
Fester's SuDu FesterUK Axial AX-10 Scorpion 21 05-31-2013 10:50 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
