Thread: Gerry´s SuDu One FL - CF Axle <3lb Shafty
Old 02-04-2014, 08:06 PM   #81
Default Re: Gerry´s SuDu One FL - CF Axle <3lb Shafty
These axles look amazing... But can you drive??
sourdojack is offline   Reply With Quote
Old 02-09-2014, 05:16 AM   #82
Originally Posted by Postclanker View Post
I've been reading and reading and reading....nobody really posts a pic of how and where they mount their electronics.
Can you please share a pic of that when you get that far?
Yes, i will post up some pics in the evening with the electronic in it
we will see
Ok, the roller is done - lower links are made from Ti, the upper links are made of CF:
And the overall weight of the roller incl. the servo:
968g are about 2.13lb - not bad i think
Gerry is offline   Reply With Quote
Old 02-09-2014, 05:27 AM   #83
Top job mate
Sent from my GT-I9300 using Tapatalk
Oz Bruiser is offline   Reply With Quote
Old 02-09-2014, 07:32 AM   #84
Are you planning to run the servo without the bottom case like that?
Front upper link geometry looks a little crazy. Seems like simply driving forward will squat the chassis down until the shocks bottom out.
Good progress, otherwise.
MRCrackhead is offline   Reply With Quote
Old 02-09-2014, 10:08 AM   #85
Hi,
I am not convinced… if you add the weight of various of missing elements : motor 300g (10.5oz) + liPo 100g (3.5oz) + ESC + Bec 150g (5.3oz) + body 100g (3.5oz) + paint for body 30g (1 oz) + wire 80g (2.8oz) + and what I forget 50g (1.8oz) = 1780g (3lbr 14.8oz). it's largely more than the 3lbs envisaged You will have to stop…
F***ing nice work!!
TotoRax is offline   Reply With Quote
Old 02-09-2014, 11:25 AM   #86
Originally Posted by TotoRax View Post
Hi,
F***ing nice work!!
You need to check your weight estimates, Steph! Motor is max 175g, lipo is 50g, ESC and BEC are probably much less than 150g etc.
Tomy is offline   Reply With Quote
Old 02-09-2014, 12:01 PM   #87
Lightbulb Re: Gerry´s SuDu One FL - CF Axle <3lb Shafty
Couldn't agree more Tomi
My puller 500 is only 4.3oz no where near 10.5
Battery 2oz
Esc/bec 2.5oz with wire
Body 1oz
9oz is what I see being added plus whatever knuckle weight
Which I don't see much being needed on this amazing rig
So yes it will be over 3lbs but who care what he did here is just awesome
chevotafun is offline   Reply With Quote
Old 02-09-2014, 12:57 PM   #88
Nah, I can still see this coming in at just under 3 lbs even with an ounce each side for knuckle weights. Time will tell.
Solitaire is offline   Reply With Quote
Old 02-09-2014, 01:24 PM   #89
It´s happened! The roller is now full electrified and RTR
And now, let us check the weight from the RTR rig:
I would say - goal reached
But for sure, if i add some knuckleweights (and i´m sure i would) - maybe i´m over the 3lb - but that´s not important any more
I hope i can test tomorrow the Shafty, if all will work fine i will shorten the wires and will post up some pics of all the details!
In the front i have to use a bit longer shocks, then also the upper front links will fit how the should
I´m so happy!
Old 02-09-2014, 02:03 PM   #90
Top job Gerry. Great to see the mix of NCD snd your own creation. Goes together like it was ment to be. Cant wait to see this in action. Im sure there are many guys who will want your axels not to mention the guys already using their NCD SuDu's
Old 02-09-2014, 03:11 PM   #91
@ Tomy, chevotafun and Oz Bruiser
I had hoped that the nonsense of the weights that I announced (like 30g - 1 oz for paint for body or 80g - 2.8oz for wire), would be understood like humor.
But irony of my post to disappearing with Google translation Promised, I did not try any more to make humor
@ Gerry
I quote my last post
Originally Posted by Totorax
F***ing nice work!!
Old 02-09-2014, 03:21 PM   #92
That is a gorgeous quality build. Very professional looking. Two thumbs up
OpenDiff is offline   Reply With Quote
Old 02-09-2014, 04:47 PM   #93
Very nice mate
Sent from my GT-I9505 using Tapatalk
RockMafia is offline   Reply With Quote
Old 02-09-2014, 07:28 PM   #94
www.ottsix.com
It's alive!
crawl-o-matic is offline   Reply With Quote
Old 02-09-2014, 07:58 PM   #95
Looking great Gerry! Nice an light. Perfect setup IMO.. Light rig, then add weight where you need it. I can't wait to see more, and hear how it runs
Hittman is offline   Reply With Quote
Old 02-10-2014, 12:07 PM   #96
Congrats!
grover is offline   Reply With Quote
Old 02-10-2014, 01:33 PM   #97
Stephan Hauser / # 7
ZZR 1100 Racer's Avatar
I think that rig is to light for the 2.2S Class. You have to start at 1.9
...but normally it's not a to bad work on these
Hope to see you soon on the rocks
ZZR 1100 Racer is offline   Reply With Quote
Old 02-17-2014, 04:07 AM   #98
Hi,
I now even could see it in Action - amazing.
And here is the "proof".
More Details shall be provided by the builder ;)
Cheers
Daniel
daniels is offline   Reply With Quote
Old 02-17-2014, 05:54 AM   #99
That, or I take things too seriously.
Old 02-17-2014, 12:56 PM   #100
Looking great Gerry Absolutely the next level
@Totorax: I got your humor first time I read it ... nice one Thanks Tomi
Haastnooit is offline   Reply With Quote
Gerry´s SuDu One FL - CF Axle <3lb Shafty - Similar Threads
ZZR's Shafty...NCD's SuDu one FL ZZR 1100 Racer Axial AX-10 Scorpion 178 03-14-2015 12:57 PM
MOA front axle Shafty rear axle Timberline Axial XR10 12 06-25-2012 06:27 PM
Which shafty solid axle is best suited to run Jumbo Kongs? BoilermakerFan General Crawlers 8 01-21-2005 01:24 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
