02-26-2014, 08:33 PM | #21 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
| Re: Denc_er's SuDu
Awesome build so far! Where could I find one of these chassises?
02-26-2014, 08:37 PM | #22 |
RCC Addict Join Date: Jun 2009 Location: Australia
02-27-2014, 09:41 AM | #23 | |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: Denc_er's SuDu Quote:
I put a hole in the top side of the axle housing just above the pinion. That way the upper link mount and battery plate cover it up. I tried running loktite and having the screws not all the way tight, and one of them backed out after a few weeks. It completely locked up the front end. And be sure to add extra screws on those burly tubes to keep them from spinning in the housings. | |
02-27-2014, 10:50 AM | #24 |
Newbie Join Date: Apr 2011 Location: Germany
| Re: Denc_er's SuDu
So last week I finished the CFRP links... @sourdojack Those screws for the splined tubes are already installed. I will try to use the locker as spool. At the rear I also have problems, the shafts won't fit to the VP Locker, to short to use the screws... Last edited by Denc_er; 02-27-2014 at 10:55 AM. |
02-27-2014, 11:08 AM | #25 |
| Re: Denc_er's SuDu
And the rear axle... UberToobs from Creation Fab... Those delrin links will be replaced by titan. |
02-27-2014, 11:49 AM | #26 |
What rear axles are you using? Xr short side? I found them to be shorter then my liking as well. I run 2 long side xr axle shafts.. The ubbertubes are a pretty smooth setup! I think I may have ti look unto them when it's time for new rear tubes... |
02-27-2014, 12:08 PM | #27 |
I use the shorter, longer would be 5 mm to long.
02-27-2014, 12:23 PM | #28 |
| Re: Denc_er's SuDu |
02-27-2014, 12:55 PM | #29 |
| Re: Denc_er's SuDu
Yeah, I thought about it, but I don't have the possibility to do it. Perhaps I can visit this weekend a friend having a lathe and mill. |
03-01-2014, 07:11 AM | #30 |
| Re: Denc_er's SuDu
sourdojack: I drilled a hole in the axle housing. But when tightening the shafts with the setscrews, they don't go well. Tried different positions, without some play it won't work fine. Finaly I glued the screws tight to the shafts in the locker, so I can pull out the shafts. Works well. For the hole I uses a tube wih a M3 screw |
03-01-2014, 08:29 AM | #31 |
| I didn't shorten mine at all. They do touch in the center of the spool, but make's a sold rear axle(less slop).. I used my dremel and made the flat of the tang about 2.5mm further up the shaft. For me, it keeps side to side slop at zero and the hex pins out of the lockouts. Which is great since I run the Lattice innovations, Shift hubs. Makes a very free spinning axle. |
03-01-2014, 09:18 AM | #32 |
| Re: Denc_er's SuDu
I will work on the rear shafts... perhaps tomorrow.
03-05-2014, 01:23 PM | #33 |
| Re: Denc_er's SuDu
New parts arrived... spacers and gearbox from tomi. Still waiting for the rc4wd gears. And some titan links and shafts for sdi cardans from fritzthefly. |
03-05-2014, 04:26 PM | #34 |
Stephan Hauser / # 7 Join Date: Apr 2012 Location: Germany
| Re: Denc_er's SuDu
Great parts and pics, Nicolas |
03-17-2014, 04:14 PM | #35 |
Newbie Join Date: Jan 2014 Location: Leipzig, Germany
| Re: Denc_er's SuDu
Yes, both great What is the actual overall length of the SDI shafts? Last edited by s03r3n; 03-17-2014 at 04:53 PM. |
04-19-2014, 03:08 AM | #36 |
| Re: Denc_er's SuDu
Gears, gears, gears.... |
04-26-2014, 10:52 AM | #37 |
| Re: Denc_er's SuDu
So finaly the wheels arrived... All the wirred stuff is missing. Not sure wich motor I will use. |
04-26-2014, 11:16 AM | #38 |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: Denc_er's SuDu
Wow!!! That's a beautiful wheel design. |
04-28-2014, 04:41 PM | #39 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Denc_er's SuDu
This is one of my favorite build threads on rcc. Well done sir.
Denc_er's SuDu - Similar Threads | ||||
Denc_er's XR10 | Denc_er | Axial XR10 | 12 | 02-28-2015 09:18 AM |
My sudu one sportsman | laxjj14 | Axial AX-10 Scorpion | 22 | 05-27-2014 02:55 PM |
Jacks SuDu | Jacksprogis | Axial AX-10 Scorpion | 1 | 06-08-2013 02:45 PM |
Denc_er's T1E XR10 | Denc_er | Videos! | 0 | 04-18-2012 10:03 AM |
