02-19-2014, 08:49 PM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Wheels 5th demension sucker punch with a Dlux twist
Looks good... minus the new slider plates are the inner SP side plates stock thickness? Or is it a whole new chassis?
02-19-2014, 08:53 PM | #22 |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
| Re: Wheels 5th demension sucker punch with a Dlux twist |
02-19-2014, 10:36 PM | #23 | |
| Re: Wheels 5th demension sucker punch with a Dlux twist Quote:
What I meant was... is the g-10 material slider & chassis plates the same thickness? Looks like the slider plates are thiner..wasn't knocking the double shear slider.. After i re-read my post it sounded negative and wasn't meant that way. | |
02-19-2014, 11:40 PM | #24 |
Yeah. Side plates are 1/16"
02-20-2014, 04:23 AM | #25 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: Wheels 5th demension sucker punch with a Dlux twist Quote: |
02-20-2014, 06:25 PM | #26 |
Rock Crawler Join Date: Feb 2013 Location: york
02-20-2014, 06:53 PM | #27 |
02-20-2014, 07:37 PM | #28 |
So you guys are running a non 0 Ackerman knuckle arm?
02-20-2014, 07:57 PM | #29 |
02-20-2014, 08:04 PM | #30 |
| Yes sir and I'm slowly learning the advantages of the Ackerman affect. Blipping the throttle while turning sharp seems to be more affective and the bucking from the universals is reduced a noticeable amount. Although full on steering at speed is not quite as sharp its not by much. Wheels and my setups are inside of 0 Ackerman so the out side tire turns just a tad sharper than the inside tire. Sent from my C811 4G using Tapatalk |
02-21-2014, 03:32 AM | #31 |
Quarry Creeper Join Date: Feb 2009 Location: French Guiana
HI, I profit that you speak about the non 0° Ackerman, for you ask a question. I understand the principle, but if the arm is in front of the axle (as on the Axial or this rig), it functions contrary, no? Is there a reason with that? |
02-21-2014, 05:44 AM | #32 |
02-21-2014, 06:49 AM | #33 | |
Sent from my C811 4G using Tapatalk | |
02-21-2014, 07:32 AM | #34 | ||
If you want to compare axle widths, you cant go off of inside tire, out side tire or anything else unless you guys have the exact same setup. To compare axle to axle, you need to measure the wheel mounting surface to wheel mounting surface. Quote:
You may have that inside to inside dimension but I guarantee your mounting surface is wider. Why would it be better? | ||
02-21-2014, 07:43 AM | #35 |
02-21-2014, 07:52 AM | #36 |
For a bit more detail on these simple, narrow AR60's, here is what you need to get them rolling. REAR: Rear axle is straight up stock with the exception of the hubs. Thanks to a post by JeremyH, I found some pin on RC4wd hubs and then I mill the hex pin hole to make them even narrower. The mounting surface to mounting surface is 9.35". And it gave Wheels approx 10.5" overall with Rovers. I will be modifying and selling these modified hubs. Even if the hubs are not modified, they can still get you really narrow. Maybe Wheels can chime in but I think they were about 1/4" wider before modding? Billet wheel hub for OEM Stamped 1.9 Wheels FRONT: The front is a hair more complicated. Everything from the chubs inward is stock then we are using OFNA shafts, Dlux NARROW knuckle setup and custom 0 offset hubs. This is giving a mounting surface to mounting surface measurement of 9.7" The OFNA shafts can be done 2 different ways. First is to put an ofna stub shaft on a AR60 inner axle. The other way, which is turning out to be much better so far, is to grind a tang on the inner OFNA shaft. The OFNA material is leaps and bounds better than the Axial stuff so this is the direction we are leaning. Last edited by Erik D_lux; 02-21-2014 at 11:17 AM. |
02-21-2014, 08:01 AM | #37 | |
OFNA shafts Dlux Knuckles Dlux Wheels | |
02-21-2014, 08:03 AM | #38 |
Its .300, not .250 and thats using your measurement.... who knows how accurate that is.... OFNA shafts, Dlux NARROW knuckle setup and custom 0 offset hubs. I would be flattered by using Dlux wheels but any flat faced wheel would work. |
02-21-2014, 08:08 AM | #39 | |
Is these OFNA Shaft something you can buy at like A-Main-Hobby? Or are they something you are selling. Plus would people need a different Tie Rod? | |
02-21-2014, 08:12 AM | #40 |
I am sure you can buy them at A main. They are OFNA 40657. If you buy them and run them straight out of the package, they will only get a bit over 50* of steering and you need to modify the tang. If you get them from me, you get the full 70* steering and I can do the tang too. Not sure on the tie rod. Depends on what youre running now. |
Wheels 5th demension sucker punch with a Dlux twist - Similar Threads | ||||
cboggs' 5th D Sucker Punch | cboggs | Axial AX-10 Scorpion | 299 | 10-06-2018 02:24 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
Chevotafun 5th D Sucker Punch | chevotafun | Axial AX-10 Scorpion | 33 | 08-22-2014 03:49 PM |
