02-21-2014, 08:25 AM | #41 | |
Rock Crawler Join Date: Feb 2013 Location: york
Sent from my C811 4G using Tapatalk | |
02-21-2014, 08:28 AM | #42 |
| Re: Wheels 5th demension sucker punch with a Dlux twist
I suppose I see that as a downside. I like the outside turning sharper.
02-21-2014, 08:34 AM | #43 |
| Re: Wheels 5th demension sucker punch with a Dlux twist Yep...me too. In most cases the outside tire is going to be the one with weight being applied to it. The only possible downside i can see to having the outside turn sharper is the tendency...on some rigs...for that tire to try to walk up and under the axle causing the inside tire to lift. This can be worked around though...and is typically more of an issue on a rig with front dig.
02-21-2014, 08:51 AM | #44 |
Thank for all the info guys. I see what you guys are saying. Sent from my C811 4G using Tapatalk |
02-21-2014, 11:19 AM | #45 |
Edited my post to reflect that the rear axle is 9.350" from mounting surface to mounting surface.
02-21-2014, 07:14 PM | #46 | ||
| Re: Wheels 5th demension sucker punch with a Dlux twist Quote:
One big gain by doing this is the amount of scrub or lack there of. You need to buy knuckles and knuckle weights so why not just buy these ones that give you more options? I guess I see it being significantly easier and significantly better. To each their own though. | ||
02-21-2014, 08:32 PM | #47 |
I don't know where to even start. lol. Almost that entire post is incorrect. |
02-21-2014, 08:36 PM | #48 |
| Re: Wheels 5th demension sucker punch with a Dlux twist |
02-21-2014, 09:36 PM | #49 | |
As for the universals I use ofna stubs I already had on the wraith inner for a couple reasons. 1 I already purchased the wraith universals from ittybitty with the axles I planned on running. 2 I knew the wraith inner would be slop free with the FI spools I'm running (which end up causing a weird wobble till I clearanced them a bit). - Only issue with track width was trying to achieve 0 Ackerman which required a skinny wheel which pushed the width out a bit cause of tire bulge. | |
02-21-2014, 11:30 PM | #50 |
I did have to modify the stubs to accommodate the zero offset these knuckles offer.- The universals well if I didn't already own both parts off my universals (OFNA stub wraith inner) I'd have OFNA unis all the way.1 they work much better with ax10 chubs 2 They are made of much better metal.- Yes my minimum track width is 10 3/4. I personally see no reason to be narrower.- As far as 8* vs non 8* I'm fairly sure the track width would be within a 1/16th of each other, but let me check the chubs before you hold me to it.- Sent from my C811 4G using Tapatalk Last edited by chris.martell; 02-21-2014 at 11:43 PM. |
02-22-2014, 07:29 AM | #51 |
RCC Addict Join Date: May 2013 Location: York, PA
It would seem that my questions, concerns, and difference of opinion has come out all wrong. I never meant to bash anybody's efforts, ideas, methods, or particularly this build. I've deleted my posts since I no longer find them to be of a constructive nature. Sorry for cluttering your thread Wheels7. Last edited by MRCrackhead; 02-23-2014 at 09:41 PM. |
02-23-2014, 10:36 PM | #52 | |
ULTRA CUSTOM FABRICATION Join Date: Oct 2012 Location: 801
Back to the car. a couple pics out playing | |
02-24-2014, 07:44 AM | #53 |
Bad a@$ dude I'm so jealous you have rock to drive on. Car is bad @$$ as well. Hows it performing. Sent from my C811 4G using Tapatalk |
02-24-2014, 11:55 AM | #54 | |
With the very little drive time I got it felt good. But found I needed some tuning for sure. I hope to get some more drive time this week | |
03-12-2014, 08:38 PM | #55 |
03-12-2014, 09:42 PM | #56 |
How re you liking the sway bar? I just recently finished installing mine but haven't had the time to run it yet. And the more I see that paint job, the more bad ass I think it is. |
03-12-2014, 10:38 PM | #57 |
| Re: Wheels 5th demension sucker punch with a Dlux twist I haven't gotten to drive this car as much as I would like but so far its working great! I couldn't image driving any shaft driven car without one. Unless your running droop. There are a few ways to eliminate tourqe twist. Running the sway bar does this and more. |
03-13-2014, 07:45 AM | #58 |
Sucker......
04-18-2014, 11:22 PM | #59 |
04-19-2014, 01:55 AM | #60 |
What a minute. Team Dlux? What the fudge is going on here... |
Wheels 5th demension sucker punch with a Dlux twist - Similar Threads | ||||
cboggs' 5th D Sucker Punch | cboggs | Axial AX-10 Scorpion | 299 | 10-06-2018 02:24 AM |
Tapped-out's 5th Dimension Sucker Punch | tapped-out | Axial AX-10 Scorpion | 109 | 08-11-2015 03:17 PM |
Chevotafun 5th D Sucker Punch | chevotafun | Axial AX-10 Scorpion | 33 | 08-22-2014 03:49 PM |
