02-19-2014, 06:21 AM | #21 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Re: Snipers Prodigy |
02-19-2014, 04:15 PM | #22 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Looking Great Brother!! It even looks better in person!! |
02-19-2014, 04:52 PM | #23 |
| Re: Snipers Prodigy
I got the axles mounted up, lowers are VP Ti, uppers are slow Ti for now, but I may need to adjust the lengths of the uppers a little still, but the links I had laying around , good for first mock up. Everything clears great as I suspected, I can even move the trans further forward , which I AM going to have to try. I do have a slight rub on the driveshaft and front upper link mounting hardware, but if I turn the screw around and put the nut on the outside it will clear fine. Truck weighs 2.017 lbs, 915 g, and balances on the front lower link mount rod ends, with a servo,battery,electronics on the front axle knuckle weight should not be needed.and truck should be in the lower 3 lb range I AM hoping. Not that I AM a fan of superlight trucks, but just to show it can, and if I want it heavier, I can add weight where I want it to be. My thoughts where I want the servo and battery mounted up |
02-19-2014, 07:24 PM | #24 |
Trying to have Fun Again Join Date: Apr 2006 Location: In your fridge stealing a beer
| Re: Snipers Prodigy
Looking pretty good. When are the transmission going to be ready? I need one for my prodigy.
02-20-2014, 03:34 AM | #25 |
| Re: Snipers Prodigy
I want to beat on the trans for a bot to make sure it is going to work, and then they will be available
02-20-2014, 03:36 AM | #26 |
02-20-2014, 10:14 AM | #27 |
Rock Crawler Join Date: Sep 2008 Location: Mid Mo.
| Re: Snipers Prodigy
Rick Rig is looking great. Glad to see you stuck the motor out the front. I think its benefits will out weigh the negatives. |
02-20-2014, 06:06 PM | #28 |
02-21-2014, 08:14 AM | #29 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Snipers Prodigy
Super cool servo mount. Should allow multiple options for links, with good geometry any way you choose to build it. Awesome. |
02-21-2014, 09:00 AM | #30 |
02-21-2014, 10:27 AM | #31 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Re: Snipers Prodigy
Yep...thats awesome!!
02-21-2014, 05:45 PM | #32 |
| Re: Snipers Prodigy well it gets even better I got the battery mount tonight. carbon piece, i was feeling a bit too much green. it mounts with standoffs with the same holes as the servo. the battery sits low beside the servo on the right side, the electronics will be on the left side when all done. top view bottom view side view the tab on the front of the battery mount goes into a hole drilled into the axle truss to support the front of the mount. |
02-21-2014, 07:14 PM | #33 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
| Re: Snipers Prodigy
nice looks good
02-22-2014, 01:34 AM | #34 |
| Re: Snipers Prodigy
Nice Idea.
02-22-2014, 08:03 AM | #35 |
| Re: Snipers Prodigy
I'm loving this setup. With the servo mounted the way you have it, it looks like guys could use it on the narrowed AR60's commonly seen. The battery couldn't fit where you have it, but the servo would still be sitting very low and in a great position. Has me considering AR60's for sure...COG is way better than what I have. Very interesting/inspiring. |
02-22-2014, 08:10 AM | #36 | |
Rock Crawler Join Date: Feb 2013 Location: york
Sent from my C811 4G using Tapatalk | |
02-22-2014, 10:13 AM | #37 | |
| Re: Snipers Prodigy Quote:
Not interested in the rowdy truss; but maybe the housings. I'm still trying to figure this all out before I make a move. | |
02-22-2014, 03:41 PM | #38 |
02-22-2014, 05:08 PM | #39 |
| Re: Snipers Prodigy
Knew you'd figure it out.
02-22-2014, 05:30 PM | #40 |
Awesome what's the track width of the front axle? Sent from my C811 4G using Tapatalk |
Snipers Prodigy - Similar Threads | ||||
Red Rockcrawlers PRODIGY SPORTSMAN | Red Rockcrawler | Axial AX-10 Scorpion | 58 | 02-13-2014 02:35 PM |
CTG - Drifting with Prodigy D | Crawler Ted | Non Crawler RC's | 1 | 02-10-2014 09:56 PM |
