02-22-2014, 06:03 PM | #41 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Re: Snipers Prodigy |
02-22-2014, 06:04 PM | #42 |
Rock Crawler Join Date: Feb 2013 Location: york
Not sure if your intrested in non 0 Ackerman but it helps with that a lot. Sent from my C811 4G using Tapatalk |
02-22-2014, 06:36 PM | #43 |
Also just curious will you be able to put any weight up front? Sent from my C811 4G using Tapatalk |
02-22-2014, 07:11 PM | #44 |
| Re: Snipers Prodigy
I can run knuckle weights
02-25-2014, 05:58 PM | #45 |
02-27-2014, 10:25 AM | #46 |
| Re: Snipers Prodigy
I like what you did with the flat on the length of the shaft...that'll definitely help some guys out.
02-27-2014, 06:40 PM | #47 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
It will never work Rick.... I will come over and dispose of it this weekend like a true friend. |
02-27-2014, 07:07 PM | #48 |
| Re: Snipers Prodigy
well i saw some room for improvement with the trans setup. I moved all the gears lower in the chassis, so much that the final gear is sunk down into the skid cutout. along with this i used the stock prodigy skid turned around backwards, and made an adapter plate that uses the axial hole pattern, and has multiple mounting locations spaced .250 apart. in this pic the trans is moved as far forward as the mounting plate allows. |
02-27-2014, 07:50 PM | #49 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Re: Snipers Prodigy
Pretty awesome stuff Rick!
03-01-2014, 03:49 PM | #50 |
| Re: Snipers Prodigy
I needed to adjust the output shaft and shorten the front drive shaft, I also had to remove a small amount of material from the skid to clear the final gear of the trans, this only needs to be done when the trans is in its furthest forward mounting holes. shot of tire clearance with VP 225 hubs full lock shot of the stock skid with the material removed where needed A couple of flex shots to show clearance close up of the mounting plate installed balance point of the truck, it can be easily moved further forward, the rear rim and tire package is on the heavy side, 175g each also this is with zero added weight in the front, the front and rear wheel tires all weigh the same. |
03-02-2014, 08:10 AM | #51 |
03-02-2014, 08:24 AM | #52 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: Snipers Prodigy
That's one crazy looking setup with the motor positioned out the front of the chassis. Looking forward to see what you come up with next.
04-24-2014, 05:36 PM | #53 |
04-24-2014, 05:40 PM | #54 |
| Re: Snipers Prodigy
Nice to see another shaved diff rig. What's your track width? |
04-24-2014, 05:45 PM | #55 |
04-24-2014, 05:47 PM | #56 |
04-24-2014, 05:54 PM | #57 |
04-24-2014, 06:05 PM | #58 |
04-24-2014, 06:10 PM | #59 |
Rock Stacker Join Date: Oct 2011 Location: middle of Mo. where
| Re: Snipers Prodigy
Lookin good Rick! You always come up with some cool shtuff.
04-24-2014, 06:27 PM | #60 |
| Re: Snipers Prodigy
Thanks guys, It's 3.5 lbs right now, About a pound lighter than the pro truck |
Snipers Prodigy - Similar Threads | ||||
Red Rockcrawlers PRODIGY SPORTSMAN | Red Rockcrawler | Axial AX-10 Scorpion | 58 | 02-13-2014 02:35 PM |
CTG - Drifting with Prodigy D | Crawler Ted | Non Crawler RC's | 1 | 02-10-2014 09:56 PM |
