07-17-2014, 07:03 PM | #1 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| Question about the new (to me) underdrive bevel gear set
I went to change the rear out to an underdrive and I found that the new gears don't have the loading pins like the old ones did. This doesn't seem nearly as well made. Am I missing something here? I don't want to depend on the four tiny 1.5mm (or whatever they are) gear bolts to transmit all the force of the drive to the axles. What needs to be done here? Is there some new upgraded part that I am missing? Thanks |
07-17-2014, 07:08 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: Norway
this looks good to go on the locker, or you could change the locker with a spool
07-17-2014, 07:13 PM | #3 | |
| Re: Question about the new (to me) underdrive bevel gear set Quote:
This spool maker has included holes for the drive pins. Are the drive pins not that big of an issue? I've run these stockers since I got the rig back in '08 this way. http://www.rccrawler.com/forum/axles...-fi-spool.html Last edited by Master Basher; 07-17-2014 at 07:17 PM. | |
07-17-2014, 07:23 PM | #4 |
The screws hold just fine, non issue, only the shitty stock pot metal gears have those pins.
07-17-2014, 07:27 PM | #5 |
| Re: Question about the new (to me) underdrive bevel gear set |
07-17-2014, 07:28 PM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I haven't used the pins either...no problems.
07-17-2014, 07:28 PM | #7 |
07-17-2014, 07:28 PM | #8 |
Ur good to go man. The 4 screw's will do just fine.. Loctite them in an forget about it. Them 4 little screw's hold lots of gears together in crawlers and Big powered rock bouncers. |
07-18-2014, 10:55 AM | #9 |
^loctite dont work on plastic yo.
07-18-2014, 12:07 PM | #10 |
Those pins take no load. They are there to locate/center the spider gear shaft in the diff housing when running an open diff.
07-18-2014, 12:51 PM | #11 |
07-18-2014, 01:29 PM | #12 |
07-18-2014, 01:30 PM | #13 |
07-18-2014, 01:41 PM | #14 |
^^ Crawl much!? I kid I kid.. I ran my stock axle ring, pinion, an lockers for 2 years.. The 2nd year was 4s on a 35t, 16t an even brushless, before I up graded.. Some get lucky and they hold up.. But the slop is Horrible! |
07-19-2014, 03:45 AM | #15 | |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
I stripped a set of stock ring and pinions in one take off, then continued to trail, and they came back where the truck wouldn't propel its self on flat ground. | |
07-21-2014, 04:03 PM | #16 |
Don't forget to use a new paper gasket between the spool and ring gear. |
07-22-2014, 06:58 PM | #17 |
07-25-2014, 04:51 PM | #18 |
RCC Addict Join Date: Aug 2007 Location: Seattle
07-25-2014, 06:02 PM | #19 |
| Re: Question about the new (to me) underdrive bevel gear set I noticed that with no gasket in place the case doesn't touch the ring gear because the stock locker is too thick. That would put even more bad forces on the 4 small screws holding the thing together. Ideally, the case touches the ring gear and the screws are torqued enough to utilize friction between the gear and the case to turn the diff. Even more ideally, the "locating" pins fit snugly into the locating holes and take all the force. The plastic case holes are too sloppy for this to occur (imho), but a metal locker (aftermarket) may be made like this. I would say it is important to have the case half screwed tightly to the ring gear, and my diff wouldn't do that without a gasket. Otherwise, the screws (tiny little things too) are subject to the torque and will break eventually. |
Question about the new (to me) underdrive bevel gear set - Similar Threads | ||||
Wraith Heavy Duty Bevel Gear Set - Underdrive REAR - ISSUE | slimfire | Axial Wraith | 11 | 01-24-2013 04:03 AM |
