07-24-2014, 07:45 PM | #21 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time.
56/10 seems to be the gear ratio that works well for me and a few others. Yes, trimming those front uppers is the ticket. I've never seen torque twist in the front. Only the rear. Mirroring the trans or turning the trans around to put the motor on the other side is the best defense against torque twist. Not pinion angle bud. Sent from my iPhone using Tapatalk |
07-25-2014, 05:26 AM | #22 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
^ drive it in reverse if you wanna see front axle tt. 56/10 wont work with the stock trans will it?
07-25-2014, 06:05 AM | #23 |
Do the same with your rear pinion angle, it DOES affect tt.
07-25-2014, 06:41 AM | #24 |
It might just be me not seeing the pics correctly on my phone, but it looks like you have your rear uppers bolted directly into the posts of the housing. If that is the case, you'll need to brace that area. A cross brace (between the two posts) at minimum...would be best to have something that bolted to the inner face of the housing as well. Nice looking rig! |
07-25-2014, 07:56 AM | #25 | |
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. Quote:
07-25-2014, 07:57 AM | #26 |
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. |
07-25-2014, 08:17 AM | #27 |
07-25-2014, 09:34 AM | #28 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. I am going to have to disagree with Rowdy. The reason you want driveline angles equal and opposite is for phasing. With a CVD driveline you should be OK. Plus because your not driving at highway speeds you would not notice it. I set up my shafty with the joint up and out of the way. I had a Jeep with about 600 hp small block that kept shitting u joints. 2.5 degrees in axle pinion change was all it took to correct what had been thousands of dollars in damage from multiple destroyed drivelines from u joint failure. Once I was schooled ( NHRA Pro Stock driver who is local to me helped me with set up and ended my issues) I never had another problem. |
07-25-2014, 10:48 AM | #29 | |
07-25-2014, 10:49 AM | #30 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
This makes me very curious, this pinion angle thang. I tucked my universals up above the links so they would be out of harms way, smoother underside, and a more in line angle for the transfer of energy from the tranny. Torque twist for me is within an acceptable range (less would be better.) I am doing a chassis upgrade soon on the sporty & maybe a pinion angled parallel to the ground setup is in order to see for my self. |
07-25-2014, 11:43 AM | #31 | |
The benefits of keeping the driveline out of the way far outweigh any perceived notion of stability. | |
07-25-2014, 12:12 PM | #32 |
I guess I'm doing it all wrong then cause I normally try to keep the front flat and the rear clocked up so that the driveshaft and rear yoke are inline. The build looks like it's coming along great. Keep in mind there is no "wrong" way to build it. Just do what you want with it and if it doesn't work, try something else. Keep at it Oh and by 56/10 he is referring to 32p gears. |
07-25-2014, 12:26 PM | #33 | |
The rear up and out of the way is best. It would be great on the front also, but it makes the throw of the servo really funky because of the clocked back knuckles and the forward leaning servo. Also many people keep the rear clocked up because if you have a slanted skid ( unless you machine the skid to straighten the tranny angle) , you have to in order to keep the transmission joint from binding | |
07-25-2014, 12:27 PM | #34 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
I also run the front flat and the rear clocked up a bit. I have noticed there is a limit to how far you can go on the clocking where it will make the car unstable if you go to far. A sway bar will also help control torque twist to some degree, but that's not why we run them.
07-25-2014, 12:56 PM | #35 |
I was just giving setup advise from the winningest chassis ever, designed by a multi time national champion, enough evidence for me. Good luck and have fun.
07-25-2014, 01:13 PM | #36 | |
Front flat NO doubt about it, and SLIGHT tilt of the rear axle is my advice, take it for what it's worth and see what works for you. Last edited by ROWDY RACING; 07-25-2014 at 01:16 PM. | |
07-25-2014, 01:40 PM | #37 | |
So are you running a gatekeeper? If not, why. Is your chassis and links AL? If not why? Are you running stock width AX-10 axles? If not why not. They were all designed by what you call the most winning chassis ever. And OH my I hope your car is 8 pounds, like the gatekeepers were. I hope you toss your bully axles in the trash and go back to stock width ax10 axles with a mechanical dig. Because gatekeeper says so. Or you could step out of 2008. Just like Gatekeeper did, and run a Ytown car. | |
07-25-2014, 01:50 PM | #38 | |
I was just giving advise, no need to start an argument. Love you Ted. Last edited by ROWDY RACING; 07-25-2014 at 01:53 PM. | |
07-25-2014, 04:45 PM | #39 |
07-25-2014, 04:49 PM | #40 |
Reinventing my AX10...(again) Sucker Punch Chassis time. - Similar Threads | ||||
Crawllife's 5D Sucker Punch | Crawllife | Axial AX-10 Scorpion | 175 | 04-16-2015 11:43 AM |
Rottenbellys sucker punch. | rottenbelly | Axial AX-10 Scorpion | 14 | 03-09-2014 05:22 PM |
