07-23-2014, 03:06 PM | #1 |
Newbie Join Date: Dec 2009 Location: Amsterdam
| Off-center spur-gear ?
Hi, my long-awaited rig sprang to life, once the juice was added for the first time - what a joy! She made some runs, and once back on the bench for a check up - I noted the Novak 55t was moving like it had a slightly bent shaft. It turned out to be the spur running slightly off center I will be opening the gearbox when I have time again, but it seems like an odd problem to have, the spur installed on the gearbox turns the shafts all nice and easy by hand, so I'm trying to estimate what to expect to be the problem when opening her up. Any thoughts are welcome - thanxs |
07-23-2014, 03:33 PM | #2 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Off-center spur-gear ?
1.Spur is out of round. 2. Some have spacers to keep the spur centered so it could be missing or the spur is not installed correctly. 3. Bent shaft. 4. A bad bearing or a bearing not seated fully. 5. Dirt or something in the gears. |
07-23-2014, 03:41 PM | #3 |
Thanxs, I guess I'll have to wait a bit longer with getting it dirty, while finding the root cause. Cheers |
Off-center spur-gear ? - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
r2 2 speed binding in center spur gear | gardenwelder | General Scale Talk | 0 | 11-09-2010 12:42 PM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
