02-02-2016, 09:15 PM | #301 | |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Re: Papa's BWD Nightmare S Light weight gives the rig several advantages: less strain on the drivetrain, more wheel speed with the same amount of power, more agility on the rocks, the ability to "float" over holes, less breakage on tumbles (it happens), and maybe the most important of all is to be able to put the weight where you want it, which is down low. Quote:
02-02-2016, 09:16 PM | #302 |
| Re: Papa's BWD Nightmare S |
02-02-2016, 09:16 PM | #303 |
Quarry Creeper Join Date: Nov 2012 Location: Blue Ridge
I may try it, I've always had heavy rigs. Sent from my SCH-I545 using Tapatalk |
02-02-2016, 09:24 PM | #304 |
| Re: Papa's BWD Nightmare S I've been at this since heavy rigs were the rage and it took me a long time to make the switch. I was used to a heavy rig and light rigs just didn't "feel" right to me. I have to say, though, after building this rig and making an effort to make it lightweight I am now a believer. It really didn't take long to see what I'd been missing. I could've shaved a little bit more weight off here and there, but compared to what I used to run, it's a featherweight.
02-02-2016, 10:53 PM | #305 |
Quarry Creeper Join Date: Jan 2009 Location: Cerritos
Looking like that rig is going to shed some good weight!
02-03-2016, 07:19 AM | #306 |
Mounted up and ready to go into rig: Last edited by papabash; 09-16-2017 at 06:17 AM. |
02-03-2016, 07:58 AM | #307 |
Pebble Pounder Join Date: Jan 2016 Location: Athens
I have to get a new spur so I can do the slipper eliminator z did you shorten your top shaft so it don't run the the G10 brace ? Sent from my iPhone using Tapatalk |
02-03-2016, 08:20 AM | #308 |
02-03-2016, 08:21 AM | #309 |
| Re: Papa's BWD Nightmare S Sent from my iPhone using Tapatalk |
02-03-2016, 08:14 PM | #310 |
Me likey that blue
02-03-2016, 08:54 PM | #311 |
where can i find xr10 rear shafts
02-03-2016, 09:12 PM | #312 |
02-04-2016, 04:53 AM | #313 |
02-04-2016, 05:30 AM | #314 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
I was told that wheelie king shafts would work but I never figured out which one. Most of the links people posted were dead ends. Maybe you can find it,if so please post a part number.
02-04-2016, 05:45 AM | #315 |
Wheels king quit making them Sent from my SCH-I545 using Tapatalk |
02-06-2016, 08:15 AM | #316 | |
| Re: Papa's BWD Nightmare S Quote:
But for a good place to put info... VP Currie axle shafts, XR width, would be a make-shift way to go. I believe they need cut down and tang'd.. Options are good tho.. | |
02-08-2016, 06:15 PM | #317 |
Which mini t springs do you use, front or rear Sent from my SCH-I545 using Tapatalk |
02-08-2016, 11:41 PM | #318 |
| Re: Papa's BWD Nightmare S Both. I use front Mini T springs on the front and rear Mini T springs on the rear. Page 6, post #120 explains. This combination has worked well enough I have not had a reason to change.
02-09-2016, 12:55 AM | #319 |
03-21-2016, 09:45 PM | #320 |
Quick question, i got my rig together and running. love how it crawls but when i back up it lifts the LR tire. How can i solve this?
Papa's BWD Nightmare S - Similar Threads | ||||
Papa's Wraith Re-Build | papabash | Axial Wraith | 72 | 04-17-2014 07:31 PM |
Papa's BrATMOBILE | papabash | 1.9 Scale Rigs | 48 | 03-01-2014 03:34 PM |
Papa's BWD G10 Sporty | papabash | Axial AX-10 Scorpion | 62 | 06-17-2013 10:14 AM |
Kratos Bwd "Nightmare" build | Kratos | Axial XR10 | 31 | 06-10-2013 03:24 PM |
