01-22-2015, 10:51 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
| ax10 weights.
I just want to know what some of the weights are out there so i have a decent goal. Im trying for under 5 lbs with mine. Im in the mid 5s at the moment and have some more "trimming" to do to get it there. What are some realistic weights?
01-23-2015, 01:10 AM | #2 |
| Re: ax10 weights.
I'm running 3lbs 8ozs rtr.. But it's not about the weight. Build it and crawl it. As you change wheels for lighter ones or get aluminum hardware, cross braces, etc, etc, over time. The weight comes off and it just ends up what it ends up. Some guys like light, some are shooting for heavier. IMO. The biggest gain in weight savings/performance gain is wheels. If ur running VP DH wheels, they are heavy and hard on the drive train. Lighter wheels allow everything to work/perform better. |
01-23-2015, 01:33 AM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: brisbane
| Re: ax10 weights.
1395 grams-3.07545Ib RTR
01-23-2015, 09:26 AM | #4 |
| Re: ax10 weights.
Sweet baby jesus thats light. I have never had a light rig before so i figured why not. I am running my mayhem monsters on it right now, and i think i have a couple other ways i can shave weight
01-23-2015, 10:48 AM | #5 |
| Re: ax10 weights.
I bet you loose a pound with changing them wheels out!
01-23-2015, 10:50 AM | #6 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: ax10 weights.
If you're talking a stockish AX10 chassis, you'll never get that low. If you're talking an aftermarket chassis, 4lbs is easily attainable.
01-23-2015, 04:36 PM | #7 |
| Re: ax10 weights.
This ax10. Harley chassis, titanium lowers, graphite uppers, carbon fiber servo mount, delrin tubes, plastic knuckles(for now) and cs. Delrin duuuuuuuude d mount for the rear. Stock axial rear axle. Hd over/unders. Hr spool front, iron cross back. Stainless tie rod and drag link. I am debatin on carbon fiber or delrin wheels to help drop my weight. Oh and mips. |
01-25-2015, 12:30 AM | #8 |
| Re: ax10 weights.
Ok so update, with plastic rims im at 4lbs 8.7oz without a battery
01-25-2015, 08:05 PM | #9 |
| Re: ax10 weights.
Im hoping for mid 4s
01-25-2015, 08:57 PM | #10 |
| Re: ax10 weights. |
01-25-2015, 11:08 PM | #11 |
| Re: ax10 weights.
How in the hell do you get it that light!!!
01-25-2015, 11:40 PM | #12 |
| Re: ax10 weights.
Hell where do i start. Starting point the chassis is a HULKSTA ENGINEERING Joker chassis all CF has the gear box built into chassis, all the gears in gearbox light weight xr10 gears. both front and rear link mount r CF, all the links r 7075 ally.Run 7 grams a side in front knuckle weights. Ally bolts through out whole car. Hulksta CF rims with Super Skinny cut'n'shut Voodoo's. Elec's - Sidewinder Micro CC bec 35t Brood stuby and hitec 7950. Link to build thread. Crawl ANZ - View topic - " THE JOKER" |
01-26-2015, 07:41 AM | #13 |
| Re: ax10 weights.
So basically carbonfiber everything, and a ccc trans
01-26-2015, 09:19 AM | #14 |
| Re: ax10 weights. |
01-26-2015, 02:29 PM | #15 |
| Re: ax10 weights.
Nice
ax10 weights. - Similar Threads | ||||
How to make weights for your ax10. | Schmidt | Axial AX-10 Scorpion | 11 | 09-22-2012 03:16 AM |
AX10 knuckle weights? Oh yeah! | Erik D_lux | Axial AX-10 Scorpion | 52 | 03-10-2011 08:34 PM |
ax10 beadlock weights | newmexicocrawler | Tires and Wheels | 0 | 02-05-2011 07:17 PM |
