06-08-2015, 03:42 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Weird Gears
Has anyone tried these? Event the pinion and spur teeth are cut at an angle.
06-08-2015, 07:13 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Weird Gears
Nope, haven't seen those yet. Helical gears are supposed to be stronger...who makes 'em? |
06-08-2015, 07:24 PM | #3 |
| Re: Weird Gears |
06-08-2015, 10:29 PM | #4 |
Pebble Pounder Join Date: Feb 2015 Location: Mount Morris
| Re: Weird Gears |
06-09-2015, 05:47 AM | #5 |
Rock Stacker Join Date: May 2014 Location: Australia
| Re: Weird Gears
They are commonly called pineapple gears are are supposed to be stronger and quieter
06-09-2015, 06:15 PM | #6 |
| Re: Weird Gears
So from the thread EP showed. One guy bought them and liked them. Others don't like them, but never used them. I bought a set and will try as soon as I break something.
06-11-2015, 03:37 PM | #7 |
Rock Stacker Join Date: Mar 2013 Location: Amsterdam
| Re: Weird Gears
The advantage of helical gears: - slightly more contact area so in theory stronger - They engage more gradually so run quieter / smoother - load is theoretically more distributed over gear teeth The disadvantage: - sliding friction in meshing teeth thus slightly less efficient in power transfer - thrust along the axis of the gear -> more pressure on the bearings Most important though is the material. Helical gears made of weak material will suck just as normal gears of weak material will suck. So basically I'm interested in what these gears are made of. I'd love to give helical gears a try if they're made of hardened steel. If they're made of China butter, I'd rather not ;) |
06-11-2015, 07:00 PM | #8 |
| Re: Weird Gears
Pygmy you got me curious. I scraped one of the gears with a stainless scale. I am leaning toward the China butter. Curled off a chip with the rule. Harder than aluminum, but no where like the old bully gears.
Weird Gears - Similar Threads | ||||
RC4WD Gears or Axial Light Weight gears. | OFFROADRCKOREA | Axial XR10 | 39 | 10-29-2012 02:20 PM |
***Giveaway*** - Mann Gears - HD Replacement Berg Gears | mann0mann | EnRoute Berg | 72 | 06-20-2010 07:24 PM |
