09-17-2015, 05:26 PM | #41 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Re: Blandon' Boxer Build
Looks like your ready |
09-17-2015, 06:07 PM | #42 |
You need more blue screws, yup blue screws to go with the green body I need to hire you for my bench shots, that thing looks sexy sitting there. Now get out and scratch that dog up! |
09-17-2015, 06:11 PM | #43 | ||
| Re: Blandon' Boxer Build Quote:
It doesn't get any better then that right there! I just ran mine at World's, for the first time.. Absolutely beautiful performing motor! Solid Powah and smooth as smooth can be! Builds looking Killer, but I'm with Bobbob.. Go get it wrecked! ;) | ||
09-17-2015, 08:27 PM | #44 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
Thanks Guys! Glad you like the 13t Puller Troy, and glad it didn't melt to the rocks at Worlds...lol. I have heard nothing but good things about the XX wire and this has gotta be one rocking motor in a sporty!! Can't wait to fire it up. I did have to throw some blue screws on my C-Class wheels Robbob, just couldn't help myself with that pearl green paint!! |
09-17-2015, 08:29 PM | #45 |
Thanks Purp for another great set of Silver Doo's! |
09-17-2015, 08:31 PM | #46 |
This might be the most steering I've had on any rig. I just need to do my electronics smash and she is ready to roll!!
09-17-2015, 08:42 PM | #47 |
A winning combination with Robbob wheels and PURPMART done tires! ;) It looks like you have a little positive caster, on your outside tire? Maybe the angle of the pic? |
09-17-2015, 09:15 PM | #48 | |
Yup, upper links probably about 8-10mm to long. Tilt that front axle back about 25* and she'll steer even better | |
09-17-2015, 09:17 PM | #49 |
Did you roll the axle forward to clear the servo and shock bottom? If thats the reason then you could try the angled axial pieces, the ones that throw the ball off center. Should give enough clearance if I remember from pics of Troys build. |
09-17-2015, 09:28 PM | #50 |
Yeah, Barry Thinks it's how it should be, for drive line angle.. But throws off other things. It's OK, if the beef tubes get set right. Now it would just be a matter of shortening the links. Easy easy.. Yes sir Robbob! Like this.. |
09-18-2015, 03:01 AM | #51 |
Rock Crawler Join Date: May 2007 Location: Norwich
There it is, below the servo, at the end of that shock...... That is one sweet looking rig |
09-18-2015, 06:10 AM | #52 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
That thing is sick, sweet build!
09-18-2015, 11:16 AM | #53 |
Rock Stacker Join Date: May 2014 Location: Germany
Perfect, man... Nice build Gesendet von meinem D6603 mit Tapatalk |
09-18-2015, 07:52 PM | #54 |
My father is a retired machinist with access to a really nice CNC machine so I decided a great way for him to use up some of that extra time is to make me some cool parts!! I gave him the dimensions of some 7075 preload rings I wanted and here is what he came up with. They are 5mm wide, tapped to 10mm-1 and a knurled edge. They serve no other purpose than just looking cool but what the hell.
09-18-2015, 09:03 PM | #55 |
RCC Addict Join Date: Aug 2013 Location: South East
Looks great and very excited to see this coming together for you.
09-18-2015, 09:12 PM | #56 |
| Re: Blandon' Boxer Build |
09-19-2015, 01:42 PM | #57 |
Shortened up my front upper links last night and took out a lot of that positive castor, steering is definitely a little better. The servo is close to the bottom of the shock but not touching. I think I will still order the axial bent rod ends to get a little more space. I will post some pics of last nights progress later. Electronics are smashed and ready to be tested and Puller is mounted.. |
09-19-2015, 02:29 PM | #58 |
Looks like a madian voyage for sunday |
09-19-2015, 03:10 PM | #59 |
09-22-2015, 05:09 PM | #60 |
Receiver, Holmes BR mini, and Castle BEC smashed together
Blandon' Boxer Build - Similar Threads | ||||
Boxer Build 2014 Sporty | McTwist | Axial AX-10 Scorpion | 54 | 10-13-2015 07:24 AM |
Boxer Sporty Build | all24 | Axial AX-10 Scorpion | 30 | 10-20-2014 04:04 PM |
Fordsuperduty's p40 boxer build | fordsuperduty | Axial AX-10 Scorpion | 29 | 04-01-2014 02:25 PM |
bashin boxer build | bashin calfee | Axial AX-10 Scorpion | 54 | 03-15-2014 09:45 AM |
