07-29-2016, 09:29 PM | #121 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
| Re: Blandon' Boxer Build
Another change I decided to make was to add a little more knuckle weight. I added 1oz per wheel to see if that will help keep the front end down a little. The rig is really light coming in at just a hair over 3lbs with battery so adding a little weight should work out nice and it will still be under 3 1/2lbs.
07-29-2016, 09:36 PM | #122 |
I also lucked out and won some Krazed Builds Limited Edition wheels that Robbob made up just for NENC. These are the XA's and they are bad ass looking. Switched over my Voodoo's and foams and will be running these now. Sent from my iPhone using Tapatalk |
07-30-2016, 03:29 AM | #123 |
Another issue I noticed when putting the truck back together was that I ripped out the screw that goes through the support post on my DesTroy plate. Because there is a decent amount of space between the C hub and bottom of the Beef tube before the axle I was able to drill it and install a 3mm brass insert and now I can tighten it down nice and everything is solid. Sent from my iPhone using Tapatalk |
07-30-2016, 04:36 AM | #124 |
Truck is all put back together and ready to go! I'm loving the way these new wheels look on here, they are almost too nice to scratch up. Gonna try to sneak out and get some practice with the 2.2s and 2.2m today and off to comp tomorrow. Sent from my iPhone using Tapatalk |
07-30-2016, 06:59 AM | #125 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
Cool nice going. I run Hulkstar plates front and rear and i broke last year at PA ripping my front plate from the axle. One of the other drivers recomened that i drill and tap the beef tube and use a brass insert in the plastic and i must say it bullet proofed it The wheels are pimp |
10-27-2016, 05:16 PM | #126 |
Been a while and really no changes to the truck. We had a comp in August and I tied Stankulas for 1st, a comp in September and had a 1st for that one. The truck has been running smooth and solid and couldn't be happier with it! Now I have to make a small change! When I saw that Robbob came out with weight holders that fit my Rcbros brackets.......well I just had to have some!!! My current set up is pretty standard edition and has worked well.. Sent from my iPhone using Tapatalk |
10-27-2016, 05:23 PM | #127 |
These are the Krazed 1100's from Krazed Builds (Robbob). They are delrin slug holders that fit the pinewood derby tungsten slugs and the mounting holes are tapped for 3mm screws so it's very easy to attach to the Rcbros brackets. Sent from my iPhone using Tapatalk |
10-27-2016, 05:29 PM | #128 |
The tungsten slugs are a nice tight fit and definitely aren't going anywhere. Now the weight is lower inside the wheel and I spaced them out to push them as far to the outside of the wheel as possible.. . . . Sent from my iPhone using Tapatalk |
10-27-2016, 05:43 PM | #129 |
Im liking ..... On mine I actually used the brass RCBros weights as my spacers. It allows me to tune my weight as I go. I can add slugs or take them out when I practice and tune. Slick rock (less traction) more weight ...... RI/Darien rock (more traction) less weight. I never stop tuning as I drive lol. |
10-27-2016, 06:13 PM | #130 | |
| Re: Blandon' Boxer Build Quote:
12-20-2016, 07:45 PM | #131 |
Newbie Join Date: May 2016 Location: Perth, Australia
Ive loved reading this build it helped me out with my boxer build any more updates since your last post? Are you still running the j concepts body
02-06-2017, 12:52 PM | #132 |
| Re: Blandon' Boxer Build Sorry, just caught this post. I've been pretty busy lately and not on here very often. Glad this thread helped you out! I always try to take tons of pictures whenever I do a build thread because whenever I've had questions about things I always looked to other people's threads and the pictures people post have helped me tremendously. I really haven't made any changes to the truck, its dialed in nice right now and have been very happy with it! I still have the J Concepts body but I have been running the trusty old Xciter body!
Blandon' Boxer Build - Similar Threads | ||||
Boxer Build 2014 Sporty | McTwist | Axial AX-10 Scorpion | 54 | 10-13-2015 07:24 AM |
Boxer Sporty Build | all24 | Axial AX-10 Scorpion | 30 | 10-20-2014 04:04 PM |
Fordsuperduty's p40 boxer build | fordsuperduty | Axial AX-10 Scorpion | 29 | 04-01-2014 02:25 PM |
bashin boxer build | bashin calfee | Axial AX-10 Scorpion | 54 | 03-15-2014 09:45 AM |
